Scan failed, please check the settings and re-start scan
Postby ProTechEx » Thu Aug 28, 2014 3:02 am
Hi there ,
i have the MOI+ with TBS 6680 (DVB-C Tuner).
When i am trying on "Tuning Settings" a AutoScan "Scan For VDR", then i get the Error Message:
But when i am Scan Manual without "AutoScan", then the Channel will e found.
Is there an Bug in the "C-tunning-settings.html" ??
ProTechEx
Re: Scan failed, please check the settings and re-start scan
Postby diabloss » Fri Aug 29, 2014 6:19 pm
first make sure Tvheadend not runing
diabloss
Postby krmlk » Fri Apr 01, 2016 4:50 am
I have almost same problem and tvheadend doesn't run
krmlk
Return to MOI+
