Hello.
I have TBS Moi Pro with TBS 6904 dvbs2 quad tuner card @ firmware v1.0.0.11
It is any way to install dddvb drivers? I mean that is not now installed in firmware.
But when I use Astra (5.60 or 5.62 rc9 or 5.63) I search just one transponder and choose just one FTA channel with 2-3 Mbit/s @ input. http stream works fine.
As output i choose resi dvbc modulator, choose that one fta channel to dvbc multiplex but in log i see: "resi. buffer overflow"
do you have any idea how to fix it?
Any help will be strongly appreciated.
Here is github repository of dddvb drivers.
https://github.com/DigitalDevices/dddvb/releases
But when i download them to the TBS i can't use "make" or "make install" to add this here.
Here is "how to" install dddvb drivers:
Vorgang
Führen Sie in einer Konsole / Terminal folgende Befehle aus:
Aktuellen dddvb Treiber herunterladen und entpacken:
cd /usr/src
sudo wget https://github.com/DigitalDevices/dddvb ... .26.tar.gz
sudo tar -xf 0.9.26.tar.gz
Treiber bauen:
cd dddvb-0.9.26
sudo make
Module installieren:
sudo make install
Reihenfolge fürs laden der Module festlegen:
sudo mkdir -p /etc/depmod.d
echo 'search extra updates built-in' | sudo tee /etc/depmod.d/extra.conf
Dem System die neuen Module und deren Abhängigkeiten bekannt geben:
sudo depmod -a
Für Max S8 die Datei ddbridge.conf angelegen:
echo 'options ddbridge fmode=x' | sudo tee /etc/modprobe.d/ddbridge.conf
ersetze x mit der Nummer der verwendeten Betriebsart (siehe unten)
Treiber laden:
sudo modprobe ddbridge
_______________________________
thank you for your help.
best regards, Peter
log from astra:
Nov 20 23:35:22[TA3 #1] PAT tsid:3207 version:1
Nov 20 23:35:22[TA3 #1] PAT PMT pid:1007 pnr:5107
Nov 20 23:35:22[TA3 #1] PAT crc32:0xEC7579CB
Nov 20 23:35:22[TA3 #1] SDT tsid:3207 version:1
Nov 20 23:35:22[TA3 #1] SDT pnr:5107
Nov 20 23:35:22[TA3 #1] SDT provider:
Nov 20 23:35:22[TA3 #1] SDT service:
Nov 20 23:35:22[TA3 #1] SDT crc32:0x73D68328
Nov 20 23:35:22[TA3 #1] PMT pnr:5107 version:1
Nov 20 23:35:22[TA3 #1] PCR pid:1017
Nov 20 23:35:22[TA3 #1] VIDEO pid:1017 type:0x02
Nov 20 23:35:22[TA3 #1] VIDEO descriptor:0x02031A485F
Nov 20 23:35:22[TA3 #1] AUDIO pid:1027 type:0x03
Nov 20 23:35:22[TA3 #1] AUDIO descriptor:0x030167
Nov 20 23:35:22[TA3 #1] AUDIO lang:slo
Nov 20 23:35:22[TA3 #1] PMT crc32:0x4DCC0216
Nov 20 23:35:22[TA3 #1] SDT tsid:3207 version:16
Nov 20 23:35:22[TA3 #1] SDT provider:Towercom
Nov 20 23:35:22[TA3 #1] SDT service:TA3
Nov 20 23:35:22[TA3 #1] SDT crc32:0xA14951BB
Nov 20 23:35:23[TA3 #1] Bitrate:2082Kbit/s
Nov 20 23:35:23[TA3] Active input #1
Nov 20 23:35:25[TA3 #1] resi. buffer overflow
Nov 20 23:35:27[TA3 #1] resi. buffer overflow
Nov 20 23:35:30[TA3 #1] resi. buffer overflow
