MUMUDVB Dicrypt only 1 TUNER at the time
Postby zebiden » Wed May 31, 2017 10:33 am
Hi every one .i am using MUMUDVB 2. it work perfect to decrypt for 1 tuner any tuner from my TBS 08 but not the 4 tuner all together. i am using OSCAM DVBAPI
any time i start the comand [email protected]:/etc/mumudvb# sudo mumudvb -d -vvv -c card0.conf
then [email protected]:/etc/mumudvb# sudo mumudvb -d -vvv -c card1.conf
It dicrypt only one tuner at the time
i get this error a
c (dvbapi) ERROR: No free id (MAX_DEMUX)
2017/05/30 22:25:32 047B5BF2 c (-) -- Skipped 1 duplicated log lines --
2017/05/30 22:25:32 047B5BF2 c (-) -- Skipped 10 duplicated log lines --
this is my config that work only for one tuner.
card=0
tuner=0
autoconfiguration=full
freq = 11596 #11495
pol =V
srate = 30000 #45000
coderate= 8/9 #3/4
coderate=auto
delivery_system=DVBS2
multicast_ipv4=0
multicast_ipv6=0
unicast=1
autoconf_radios=1
ip_http=192.168.1.50
port_http= 9981
common_port=1234
# ---------- CAMS ----------
cam_number=1
scam_support=1
ring_buffer_default_size=32768
decsa_default_delay=500000
send_default_delay=1500000
autoconf_scrambled=1
new_channel
---------------------the secong tuner config -------------------------
card=1
tuner=0
freq = 11675
pol =V
srate = 30000
coderate= 8/9
coderate=auto
multicast_ipv4=0
multicast_ipv6=0
unicast=1
autoconf_radios=1
port_http= 9982
common_port=1234
cam_number=1
scam_support=1
new_channel
#new_channel
zebiden
Re: MUMUDVB Dicrypt only 1 TUNER at the time
Postby xiaocao » Wed May 31, 2017 3:34 pm
hi ,
if you want to do unicast streaming via http protocol . i suggest you to use tvheadend whcih also can connect oscam via dvbapi .
two mumudvb to connect one oscam with dvbapi ,it may need some config .
best regards!
xiaocao
Postby zebiden » Wed May 31, 2017 5:11 pm
Hi xiaocao thank you for your replay .i am using multicast it is working with the same config and (OSCAM DVBAPI ) i find that mumudvb is mor stable then tvheadend and the tvheadend to use udp multicas.
my problem is that oscam dvbapi accepte multiple connection to dicrypt only from one transpander so i have 4 tuners mumudvb scan the 4 tuners all the channels are there in the list ,but the dicription is only one tuner .
any time i start 2 or 3 mumudvb prossese oscam give this
2017/05/31 05:10:36 38881F1D c (dvbapi) ERROR: No free id (MAX_DEMUX)
2017/05/31 05:10:37 38881F1D c (-) -- Skipped 28 duplicated log lines --
zebiden
Postby xiaocao » Wed May 31, 2017 6:14 pm
hi ,
the configuration file of oscam.conf is like this :
[dvbapi]
enabled = 1
au = 1
pmt_mode = 4
request_mode = 1
boxtype = pc
best regards !
xiaocao
Postby zebiden » Thu Jun 01, 2017 2:08 am
i dont know if the problem come from oscam or mumudvb to support multi connection in dvbapi and multitranspander
zebiden
Postby zebiden » Thu Jun 01, 2017 2:11 am
i try it different dvbapi config,and all of them worked for multiple channels but only one transponder only one tuner not multi tuner
zebiden
Return to MOI Pro
