TBS 6908 working weirdly!
Postby phkarmur » Fri Sep 07, 2018 3:23 pm
I have TBS cards connected to machine and it was working fine, but after keep running RFScan (24x7) and Blind Scan (once in a day), its loosing its accuracy of result and gives weird result.
Issue will fix if I power cycle machine but it wont fix if i reboot or reinstall driver!
So i have no idea why this is happening and how to fix this, and I am sure signal is fine. Can anyone please help me to get rid of this?
I tried to contact TBS guy too but even he cant fix it!
OS: Windows 10 Pro
Processor: Xeon CPU E5-26700 @ 2.60 GHz (2 Processors)
Driver Version: 1.0.0.7 (TBS Official)
DBA: StreamReaderEx BDA Ver:1.2.4.52-commited (Feb 3 2018, 19:08:52)
CrazyScan Version: 1.0.2.142
StreamReader Log:
02:46:10 - 07/09/2018 StreamReaderEx BDA Ver:1.2.4.52-commited (Feb 3 2018, 19:08:52)
02:46:10 - 07/09/2018 Log level = 1
02:46:10 - 07/09/2018 DLL_PROCESS_ATTACH hModule = 680A0000
02:46:10 - 07/09/2018 CheckForDVBEx(0x00839150)
02:46:10 - 07/09/2018 PID filtering disabled !
02:46:10 - 07/09/2018 Power-off LNB on exit: ENABLED
02:46:10 - 07/09/2018 SendDiSEqC use 2 repeats
02:46:10 - 07/09/2018 Default modulation: AUTO
02:46:10 - 07/09/2018 Default spectral inversion: AUTO
02:46:10 - 07/09/2018 Default pilot: AUTO
02:46:10 - 07/09/2018 Default rolloff: AUTO
02:46:10 - 07/09/2018 Preffered BDA device type: AUTO
02:46:10 - 07/09/2018 Allowed IF Freq 950-2150 Mhz
02:46:10 - 07/09/2018 Inverted LOF<6000 and >21000 Mhz
02:46:10 - 07/09/2018 Available BDA-devices:
02:46:10 - 07/09/2018 Device 0
02:46:10 - 07/09/2018 Name: TBS 6908 DVBS/S2 Tuner 2
02:46:10 - 07/09/2018 Type: DVB-S/S2
02:46:10 - 07/09/2018 Index: 0
02:46:10 - 07/09/2018 Device 1
02:46:10 - 07/09/2018 Name: TBS 6908 DVBS/S2 Tuner 3
02:46:10 - 07/09/2018 Device 2
02:46:10 - 07/09/2018 Name: TBS 6908 DVBS/S2 Tuner 1
02:46:10 - 07/09/2018 Device 3
02:46:10 - 07/09/2018 Name: TBS 6908 DVBS/S2 Tuner 0
02:46:10 - 07/09/2018 StartDVBEx(0)
02:46:10 - 07/09/2018 Device_ID: 0
02:46:10 - 07/09/2018 Use Device 0
02:46:10 - 07/09/2018 Tuner filter: TBS 6908 DVBS/S2 Tuner 2
02:46:10 - 07/09/2018 Capture filter: TBS 6908 DVBS/S2 Capture 2
02:46:10 - 07/09/2018 Input num 2
02:46:11 - 07/09/2018 Tuner IC: STV6120
02:46:11 - 07/09/2018 Frontend/demod IC: STV0910ADB (rev 5.1)
02:46:11 - 07/09/2018 TBS STV6120/STV0910 direct control used !
02:46:11 - 07/09/2018 BBGain = 6 dB
02:46:11 - 07/09/2018 ACM/VCM optimized mode !
02:46:11 - 07/09/2018 Turbosight (Lattice FPGA based) BDA extension used !
02:46:11 - 07/09/2018 + Turbosight BlindScan support with STV09XX
02:46:11 - 07/09/2018 + Turbosight I2C access support
02:46:11 - 07/09/2018 + Turbosight SignalEx support
02:46:11 - 07/09/2018 + Turbosight SignalInfo support
02:46:11 - 07/09/2018 + Turbosight MIS filtering support
02:46:11 - 07/09/2018 + Turbosight PLS control support
02:46:11 - 07/09/2018 + Turbosight MODCODE filtering support
02:46:11 - 07/09/2018 + Turbosight BBFrame streaming support
02:46:11 - 07/09/2018 + Turbosight fast LNB control support
02:47:46 - 07/09/2018 MISSel(0,0x00,0x00)
02:47:46 - 07/09/2018 PLSSel(0,0x01)
02:59:54 - 07/09/2018 MISSel(0,0x00,0x00)
02:59:54 - 07/09/2018 ModSel(0x6FA058, 0)
02:59:55 - 07/09/2018 PLSSel(0,0x01)
02:59:59 - 07/09/2018 MISSel(0,0xFF,0xFF)
02:59:59 - 07/09/2018 ModSel(0x6FA0B0, 0)
02:59:59 - 07/09/2018 SetFilter(8192, 0x0085DE70, 2, 1, 0x006FCDF8)
02:59:59 - 07/09/2018 filter_num=0
03:00:05 - 07/09/2018 DelFilter(0)
03:00:08 - 07/09/2018 StopDVB()
03:00:08 - 07/09/2018 LNB power-off ok !
03:00:08 - 07/09/2018 DLL_PROCESS_DETACH hModule = 680A0000
phkarmur
Re: TBS 6908 working weirdly!
Postby phkarmur » Wed Sep 12, 2018 12:40 pm
guys, i am still waiting for solution from you side!
at least you are supposed to give some reply here.
you wrote
TBS6908 Professional DVB-S2 Quad Tuner PCIe Card, built with the highest industry standard, with its rock reliability is the device that any personal enthusiasts or engineers in digital satellite TV industry dream to have.
in card description and we bought many cards and now we are facing issue and you are not giving any kind of support!
Even we have mailed you but no reply from support too.
if you are not able to find problem then write
device is not build for professional usage and will not work after months
because this is what you engineer said!
phkarmur
