Mini PCIe TBS7220 with Matrix ARM mini PC
Postby maspeter » Thu Feb 04, 2016 9:47 pm
Hello TBS
I have Mini PCIe card TBS7220 (T2/T/C) and I want to use it with Matrix ARM mini PC.
Do you have any instruction how to configure it? In the download section is only "How to use MatrixTV with TBS USB tuner".
I will use DVB-C tuner.
Thank you
maspeter
Re: Mini PCIe TBS7220 with Matrix ARM mini PC
Postby SergioDanielG » Thu Feb 04, 2016 11:34 pm
Hi maspeter.
I haven't got experience with mini pci-e devices (and TBS are on National Public Hollidays) but It's not so different. If you want try, power down matrix, conext mini pci-e and TBS7220 and follow instruction on same howto. If it's detected continue and use it. If not, please wait for TBS support answert.
Kind regards.
SergioDanielG
Return to DVB-T2/T/C TV Tuner mini PCIe Card TBS7220
