[ Moderator Control Panel ]
by mikeh » Sat Sep 10, 2016 10:32 pm
I have just bought a 6904 from a UK reseller and I find the Windows 10 PC will not even POST with it installed.
My 6985 works in that motherboard (ASROCK FM2A88X PRO+) - In the same PCI Express 2.0 x16 slot.
They are telling me that they test the card OK and can only offer me a refund.
Does this mean I can no longer use a TBS card with this motherboard?
mikeh
by DVB » Sun Sep 11, 2016 6:37 am
Have You tried to update BIOS? Looks like current version for Your motherboard is 3.40. Sometimes BIOS updates can improve compability with current hardware (
but of course You have to be very careful when updating BIOS - You are doing this on Your own responsibility). Probably that's BIOS for Your motherboard:
http://www.asrock.com/mb/AMD/FM2A88X%20 ... ad&os=BIOS
DVB
Return to DVB-S2 Quad Tuner PCIe Card TBS6904
