questions about TBS6902
Postby two4two » Wed Dec 21, 2016 11:38 pm
It says it has two tuners. The card appears to have two connectors. Are they BOTH for LNB in? So one could be a KU LNB and the other a C LNB? Does this card provide power to the LNB? And if I have two LNBs input, one to each connector, does it power BOTH LNBs? Is there a LINUX driver? I would use my DSR-922 to position the dish and power the polarizer, but I would not connect any LNB to the DSR-922. Is this OK to do this? I'm thinking that the DSR-922 would select the correct polarizer setting based on TP selected on the DSR-922 even though it would not actually be connected to the TP. I will use the TBS-6902 display on my PC to visualize signal strength while using the dish positioner and polarizer control on the DSR-922 to fine-tune. Thanks all. :D
two4two
Re: questions about TBS6902
Postby crazycat » Thu Dec 22, 2016 5:18 am
Two separate inputs for each tuner. Linux driver available, 100% open-source
Postby two4two » Tue Dec 27, 2016 10:47 pm
Thank you crazycat. So is that a "yes" to all of my questions? Also, since computers have 12V power supplies, how can a computer send 13V/18V to the LNB? (It is 13V/18V, right?)
two4two
Postby crazycat » Wed Dec 28, 2016 4:08 am
some voltage DC-DC converter :)
Postby two4two » Wed Dec 28, 2016 4:25 am
8-)
two4two
