added 2 6902 cards and 6981 card died
Postby JeroenM » Fri Jul 21, 2017 3:31 am
Hi.
I bought two 6902 cards to expand the tunercount in the tvserver.
I had a 6981 working prior to installing the new cards.
After installing the opensourcedrivers the 6981 tuners dissapeared but the 6902 do work fine.
I followed the installationguide here: viewtopic.php?f=86&t=9960
Is there a way for these guys to all play together? I assume the compilation of all the drivers when installing the new cards overwrite working drivers for the 6981 card with broken ones(?)
my Linux knowledge is limited and i have been plowing these forums and the rest of the internet for 2 Days without success.
I´m Running Ubuntu Server 16.04.02 x64
Here is some output:
Code: Select all
[email protected]:~# lspci -vv
18:00.0 Multimedia controller: TBS Technologies DVB-S2 4 Tuner PCIe Card
        Subsystem: Device 6902:0002
        Physical Slot: 1-1
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
        Interrupt: pin A routed to IRQ 31
        Region 0: Memory at f0500000 (32-bit, non-prefetchable) [size=256K]
        Capabilities: [70] MSI: Enable+ Count=1/1 Maskable- 64bit+
                Address: 00000000fee0200c  Data: 4182
        Capabilities: [90] Express (v1) Endpoint, MSI 00
                        ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
                DevCtl: Report errors: Correctable- Non-Fatal- Fatal+ Unsupported-
                LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s, Exit Latency L0s unlimited, L1 <1us
                        ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
                LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
        Capabilities: [100 v1] Device Serial Number 00-00-00-00-00-00-00-00
        Kernel driver in use: TBSECP3 driver
        Kernel modules: tbsecp3
24:00.0 Multimedia video controller: Conexant Systems, Inc. CX23885 PCI Video and Audio Decoder (rev 04)
        Subsystem: Device 6981:8888
        Physical Slot: 1-2
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Region 0: Memory at f0600000 (64-bit, non-prefetchable) [size=2M]
        Capabilities: [40] Express (v1) Endpoint, MSI 00
                        RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
                LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <2us, L1 <4us
                Flags: PMEClk- DSI+ D1+ D2+ AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold-)
        Capabilities: [90] Vital Product Data
                Product Name: "
                End
        Capabilities: [a0] MSI: Enable- Count=1/1 Maskable- 64bit+
        Capabilities: [100 v1] Advanced Error Reporting
                UESta:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UEMsk:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
                CESta:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
                CEMsk:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
                AERCap: First Error Pointer: 00, GenCap- CGenEn- ChkCap- ChkEn-
        Capabilities: [200 v1] Virtual Channel
                Caps:   LPEVC=0 RefClk=100ns PATEntryBits=1
                Arb:    Fixed+ WRR32+ WRR64+ WRR128-
                Ctrl:   ArbSelect=WRR64
                Status: InProgress-
                Port Arbitration Table [240] <?>
                VC0:    Caps:   PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
                        Arb:    Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
                        Ctrl:   Enable+ ID=0 ArbSelect=Fixed TC/VC=01
                        Status: NegoPending- InProgress-
        Kernel driver in use: cx23885
        Kernel modules: cx23885
Code: Select all
[email protected]:~# lsdvb
                Version: 0.0.4
                Copyright (C) Manu Abraham
TBSECP3 driver (544:6178 6902:2) on PCI Domain:0 Bus:1 Device:0 Function:0
        DEVICE:0 ADAPTER:0 FRONTEND:0 (TurboSight TBS 6902 DVB-S/S2 )
                 FE_QPSK Fmin=950MHz Fmax=2150MHz
        DEVICE:0 ADAPTER:3 FRONTEND:0 (TurboSight TBS 6902 DVB-S/S2 )
        DEVICE:0 ADAPTER:2 FRONTEND:0 (TurboSight TBS 6902 DVB-S/S2 )
        DEVICE:0 ADAPTER:1 FRONTEND:0 (TurboSight TBS 6902 DVB-S/S2 )
JeroenM
Re: added 2 6902 cards and 6981 card died
Postby JeroenM » Fri Jul 21, 2017 3:33 am
And dmesg:
Code: Select all
[email protected]:~# dmesg
[    5.095766] cx25840 23-0044: cx23885 A/V decoder found @ 0x88 (cx23885[0])
[    5.095782] general protection fault: 0000 [#1] SMP
[    5.096793] Modules linked in: cx25840(OE) gpio_ich ppdev hp_wmi sparse_keymap av201x(OE) cx23885(OE+) altera_ci(OE) tda18271(OE) altera_stapl(OE) intel_powerclamp coretemp m88ds3103(OE) tveeprom(OE) cx2341x(OE) videobuf2_dvb(OE) snd_hda_codec_hdmi kvm snd_hda_codec_realtek snd_hda_codec_generic rc_core(OE) videobuf2_dma_sg(OE) videobuf2_memops(OE) v4l2_common(OE) irqbypass videobuf2_v4l2(OE) videobuf2_core(OE) snd_hda_intel snd_hda_codec snd_hda_core serio_raw snd_hwdep videodev(OE) snd_pcm input_leds tbsecp3(OE) ftdi_sio snd_timer usbserial snd lpc_ich soundcore mei_me mei tas2101(OE) parport_pc dvb_core(OE) i2c_mux media(OE) parport 8250_fintek shpchp mac_hid ib_iser rdma_cm iw_cm ib_cm ib_sa ib_mad ib_core ib_addr iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi autofs4 btrfs raid10 raid456
[    5.102561]  async_raid6_recov async_memcpy async_pq async_xor async_tx xor hid_generic usbhid hid raid6_pq libcrc32c raid1 raid0 multipath linear crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel aes_x86_64 lrw gf128mul glue_helper ablk_helper cryptd i915 e1000e psmouse i2c_algo_bit drm_kms_helper ahci syscopyarea sysfillrect libahci sysimgblt fb_sys_fops ptp drm pps_core wmi fjes video
[    5.106362] CPU: 0 PID: 473 Comm: systemd-udevd Tainted: G           OE   4.4.0-83-generic #106-Ubuntu
[    5.107612] Hardware name: Hewlett-Packard HP Compaq 8100 Elite Small Form Factor/304Ah, BIOS 786H1 v01.07 10/19/2010
[    5.108883] task: ffff8800d3896600 ti: ffff8800d73dc000 task.ti: ffff8800d73dc000
[    5.110165] RIP: 0010:[<ffffffffc0cc53a5>]  [<ffffffffc0cc53a5>] find_ref+0x55/0xc0 [videodev]
[    5.111464] RSP: 0018:ffff8800d73df5c0  EFLAGS: 00010202
[    5.112761] RAX: 69762f7365636976 RBX: ffff8800344a3d58 RCX: ffffc90000754000
[    5.114072] RDX: 0000000000000001 RSI: 0000000000980001 RDI: ffff8800344a3d58
[    5.115387] RBP: ffff8800d73df5c0 R08: 0000000000000002 R09: 0000000000000001
[    5.116703] R10: ffffffffc0cd20c9 R11: ffffffffc0ccff20 R12: 0000000000980001
[    5.118018] R13: 0000000000980001 R14: ffffc9000097a000 R15: ffffc9000097a000
[    5.119341] FS:  00007efcbe0f18c0(0000) GS:ffff880117c00000(0000) knlGS:0000000000000000
[    5.120677] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[    5.122024] CR2: 00007fb744dd0420 CR3: 0000000034bd0000 CR4: 00000000000006f0
[    5.123385] Stack:
[    5.124742]  ffff8800d73df5e0 ffffffffc0cc56bb ffff8800344a3d58 0000000000980900
[    5.126140]  ffff8800d73df628 ffffffffc0cc78ec 0000000000980900 0002000000000000
[    5.127547]  0000000000000001 0000000000000001 ffff8800344a3d58 ffffc9000097a000
[    5.128969] Call Trace:
[    5.130379]  [<ffffffffc0cc56bb>] find_ref_lock+0x2b/0x50 [videodev]
[    5.131796]  [<ffffffffc0cc78ec>] handler_new_ref+0x4c/0x1b0 [videodev]
[    5.133222]  [<ffffffffc0cc7e4e>] v4l2_ctrl_new+0x3fe/0x5b0 [videodev]
[    5.134649]  [<ffffffffc0cc834c>] v4l2_ctrl_new_std+0x11c/0x130 [videodev]
[    5.136067]  [<ffffffffc0652b0a>] cx25840_probe+0x28a/0x8f0 [cx25840]
[    5.137492]  [<ffffffffc0652880>] ? common_s_io_pin_config+0x2e0/0x2e0 [cx25840]
[    5.138928]  [<ffffffff81691560>] i2c_device_probe+0x100/0x1b0
[    5.140374]  [<ffffffff81562dc2>] driver_probe_device+0x222/0x4a0
[    5.141812]  [<ffffffff81563141>] __device_attach_driver+0x71/0xa0
[    5.143254]  [<ffffffff815630d0>] ? __driver_attach+0x90/0x90
[    5.144689]  [<ffffffff81560ac7>] bus_for_each_drv+0x67/0xb0
[    5.146130]  [<ffffffff81562a9c>] __device_attach+0xdc/0x170
[    5.147575]  [<ffffffff815631b3>] device_initial_probe+0x13/0x20
[    5.149019]  [<ffffffff81561d52>] bus_probe_device+0x92/0xa0
[    5.150479]  [<ffffffff8155f919>] device_add+0x449/0x650
[    5.151934]  [<ffffffff8155fb3a>] device_register+0x1a/0x20
[    5.153394]  [<ffffffff8169509e>] i2c_new_device+0x18e/0x230
[    5.154869]  [<ffffffffc0d0852d>] v4l2_i2c_new_subdev_board+0xdd/0xf0 [v4l2_common]
[    5.156340]  [<ffffffffc0d085aa>] v4l2_i2c_new_subdev+0x6a/0x90 [v4l2_common]
[    5.157824]  [<ffffffffc0e266d6>] cx23885_card_setup+0x306/0x7f0 [cx23885]
[    5.159306]  [<ffffffffc0e2d1b4>] cx23885_initdev+0x814/0x1280 [cx23885]
[    5.160782]  [<ffffffff8144b565>] local_pci_probe+0x45/0xa0
[    5.162261]  [<ffffffff8144c9a3>] pci_device_probe+0x103/0x150
[    5.163740]  [<ffffffff81562dc2>] driver_probe_device+0x222/0x4a0
[    5.165224]  [<ffffffff815630c4>] __driver_attach+0x84/0x90
[    5.166707]  [<ffffffff81563040>] ? driver_probe_device+0x4a0/0x4a0
[    5.168188]  [<ffffffff815609ec>] bus_for_each_dev+0x6c/0xc0
[    5.169663]  [<ffffffff8156257e>] driver_attach+0x1e/0x20
[    5.171137]  [<ffffffff815620bb>] bus_add_driver+0x1eb/0x280
[    5.172615]  [<ffffffffc0dfa000>] ? 0xffffffffc0dfa000
[    5.174087]  [<ffffffff815639d0>] driver_register+0x60/0xe0
[    5.175548]  [<ffffffff8144ae8c>] __pci_register_driver+0x4c/0x50
[    5.177006]  [<ffffffffc0dfa031>] cx23885_init+0x31/0x1000 [cx23885]
[    5.178470]  [<ffffffff81002123>] do_one_initcall+0xb3/0x200
[    5.179925]  [<ffffffff811d12b1>] ? __vunmap+0x91/0xe0
[    5.181381]  [<ffffffff811ed4c3>] ? kmem_cache_alloc_trace+0x183/0x1f0
[    5.182851]  [<ffffffff811ee2ba>] ? kfree+0x13a/0x150
[    5.184317]  [<ffffffff8118dd83>] do_init_module+0x5f/0x1cf
[    5.185740]  [<ffffffff8110aaaf>] load_module+0x166f/0x1c10
[    5.187135]  [<ffffffff81107050>] ? __symbol_put+0x60/0x60
[    5.188504]  [<ffffffff81215140>] ? kernel_read+0x50/0x80
[    5.189834]  [<ffffffff8110b294>] SYSC_finit_module+0xb4/0xe0
[    5.191128]  [<ffffffff8110b2de>] SyS_finit_module+0xe/0x10
[    5.192399]  [<ffffffff81840b72>] entry_SYSCALL_64_fastpath+0x16/0x71
[    5.193640] Code: 8b 4f 58 48 85 c9 74 45 44 0f b7 47 70 31 d2 89 f0 41 f7 f0 48 63 d2 48 8b 04 d1 48 85 c0 75 0b eb 2b 48 8b 40 10 48 85 c0 74 22 <48> 8b 50 18 3b 72 48 75 ee 48 89 47 50 5d c3 48 8b 47 40 48 83
[    5.196575] RIP  [<ffffffffc0cc53a5>] find_ref+0x55/0xc0 [videodev]
[    5.197905]  RSP <ffff8800d73df5c0>
[    5.199229] ---[ end trace 3f62cf7ef35d7ef6 ]---
JeroenM
