TBS 6902 on Windows 7 x64
Postby redman » Tue May 22, 2018 2:46 am
hi there,
i registered here to look for a help for the case.
I have got 6922 se but in 5 years seems not working anymore.
then i looked for another card and bought 6902.
so i installed it on windows 7 but i could not get it working at all. googled a bit and then found some opinion that card doenst worked well on w7 x 64 ( working but with errors - channel list, diseq)
i installed a fresh copy of windows 7 x 86 and its working. but its not the solution i want ( limitation of ram, etc. )
so could you help me to install tbs 6902 on x64?
i tried reinstalling, manual installing of drivers - not working: windows detect it but with error ( with exclanation mark under device manager)
blind scan cant use the card etc.
thanks in advance
forgot to mention: using latest drivers from the download section here
redman
Re: TBS 6902 on Windows 7 x64
Postby redman » Wed May 23, 2018 2:10 am
hi again
can somebody share links for older versions of the drivers please
is there any archive site ?
redman
Postby redman » Thu Jul 05, 2018 11:23 am
thanks a lot BrianG61UK
i had not luck to run the card on x64 Windows 7, so i gave up
i recently installed a windows 10 and the card is working ( tbs blindscan is working ) fine. seems like w7 is not the best solution for this model
there is another issue with the scan results and the ini that i try to find a solution out
redman
