TBS 6902 Diseqc not working
Postby duane01098 » Mon Jul 04, 2016 5:38 pm
Hi , I am a newbie so I hope this isn't a dumb post. Last week I purchased a new TBS 6902 with hopes of adding a second satellite dish for PIP capibilities with DVBviewer 5.1. The existing setup was a Hauppauge WinTV HVR 2255 and a Prof 7500 which gave me any combination of PIP I desired operating in Windows Vista, (the Hauppauge card wouldn't work with DVBViewer in Windows 7 or Windows 10). I installed the new TBS 6902 using driver version 1.0.0.1 but none of the diseqc commands worked. I removed the diseqc switch and made a direct connection to the Cband LNB and it worked fine but the diseqc 1.2 motor command still didn't work. I downloaded the latest DVBviewer Trial ware , same result. I downloaded SichboPVR and the diseqc switch worked but the motor command didn't work.
I down loaded TBSviewer and had the same results as DVBviewer. I down loaded TBS-IPdata and got an error message OnOK m_pksCtrl Failed. I down loaded DVBdream 2.81 trialware. The diseqc functions all work but PIP using different cards didn't work. I tried all of the above in Windows 7 & 10 with the same result. My question is ,is there a work around to make this card work with my favorite player DVBviewer or is there a player where everything works? Thank in advance for any help you can offer.......Duane :D
duane01098
Re: TBS 6902 Diseqc not working
Postby luchy » Tue Jul 05, 2016 6:25 pm
please download our oem version dvbdream the following link and test it
http://www.tbsdtv.com/download/document ... p_v277.zip
I update a new version driver the following link and you can have a compared to the following drivers to see if it has some improved.
https://my.pcloud.com/publink/show?code ... fObmPfO0Fy
luchy
Postby duane01098 » Wed Jul 06, 2016 8:16 am
Thank you Luchy for the quick reply. The new driver 1.0.0.2 is an improvement. SichboPVR now works properly with multituner PIP. Dvbviewer and Tbsviewer still have no diseqc function. The Dvbdream v277 diseqc functions but doesn't work with the Hauppauge 2255 atsc card. DVBdream 2.81 functions with both cards but only does PIP on one transponder at a time.....Duane
duane01098
Postby luchy » Wed Jul 06, 2016 10:33 am
now that dvbdreamv277 and sichboPVR can work,so it seems that our driver is no problem on diseqc functions. still some tbsviewer and dvbdream support are not enough.
Indeed, it is not easy for you to choose.
luchy
Postby duane01098 » Wed Jul 13, 2016 7:33 pm
I downloaded the newly posted TBS Data 3.0.4.9 and the error message "OnOK m_pksCtrl Failed" has disappered and software now functions properly although it did crash once.
duane01098
Postby luchy » Thu Jul 14, 2016 10:22 am
Thanks for your feedback:)
luchy
