No services found with DVB-C - Driver correct? (tbs6205)
Postby Meindert » Sat Sep 17, 2016 3:11 pm
Configuration:
- MoBo: Gigabyte ga-h110m-s2h
- OS: Debian testing
- Kernel: 4.7.0-1-amd64
- DVB: 2x TBS6981, 1x TBS6281SE (DVB-C mode)
- Driver: TBS v160630
Problem:
- No services found even what I do with the properties in TVheadend
In the Dmesg log a reference to tbs6205 driver is shown, is that correct? Also the text "TurboSight TBS 6205 Frontend" seems odd!
Dmesg:
[ 7.032677] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 7.039638] v4l2_compat_ioctl32: module verification failed: signature and/or required key missing - tainting kernel
[ 7.063218] Linux video capture interface: v2.00
[ 7.075288] i915 0000:00:02.0: firmware: direct-loading firmware i915/skl_dmc_ver1.bin
[ 7.075622] [drm] Finished loading i915/skl_dmc_ver1.bin (v1.23)
[ 7.087911] TBS version 160405
[ 7.094653] IR NEC protocol handler initialized
[ 7.122182] IR RC5(x) protocol handler initialized
[ 7.216926] IR RC6 protocol handler initialized
[ 7.217504] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 7.217534] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 7.217553] sr 2:0:0:0: Attached scsi generic sg2 type 5
[ 7.252584] Bluetooth: Core ver 2.21
[ 7.252593] NET: Registered protocol family 31
[ 7.262148] IR JVC protocol handler initialized
[ 7.294364] input: PC Speaker as /devices/platform/pcspkr/input/input5
[ 7.303009] [drm] failed to retrieve link info, disabling eDP
[ 7.308074] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 7.308458] acpi device:0f: registered as cooling_device9
[ 7.308516] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input6
[ 7.308547] [drm] Initialized i915 1.6.0 20160425 for 0000:00:02.0 on minor 0
[ 7.308704] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[ 7.354079] IR Sony protocol handler initialized
[ 7.372913] IR MCE Keyboard/mouse protocol handler initialized
[ 7.455105] TBS PCIE Detected TBS6281 Board Rev 3
[ 7.456450] DVB: registering new adapter (TBS PCIE DVB Adapter)
[ 7.472519] lirc_dev: IR Remote Control driver registered, major 246
[ 7.473295] IR LIRC bridge handler initialized
[ 7.590011] fbcon: inteldrmfb (fb0) is primary device
[ 7.685386] cx23885 driver version 0.0.3 loaded
[ 7.685468] CORE cx23885[0]: subsystem: 6981:8888, board: TurboSight TBS 6981 [card=33,autodetected]
[ 7.702160] cdc_acm 1-5:1.0: ttyACM0: USB ACM device
[ 7.702613] usbcore: registered new interface driver cdc_acm
[ 7.702613] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 7.856122] tbs6205fe: module license 'TurboSight Proprietary' taints kernel.
[ 7.856123] Disabling lock debugging due to kernel taint
[ 7.928834] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 7.928840] Console: switching to colour frame buffer device 240x67
[ 7.933774] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[ 8.420784] cx25840 9-0044: cx23885 A/V decoder found @ 0x88 (cx23885[0])
[ 8.458433] Adding 2047996k swap on /dev/sda2. Priority:-1 extents:1 across:2047996k FS
[ 8.462481] cx25840 9-0044: firmware: direct-loading firmware v4l-cx23885-avcore-01.fw
[ 8.488002] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input12
[ 8.488048] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input13
[ 8.488096] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input14
[ 8.584392] iTCO_vendor_support: vendor-support=0
[ 8.593943] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 8.594047] iTCO_wdt: Found a Intel PCH TCO device (Version=4, TCOBASE=0x0400)
[ 8.594142] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 8.681843] Adding 2496508k swap on /dev/sdb1. Priority:-2 extents:1 across:2496508k FS
[ 8.808987] [drm] RC6 on
[ 8.935517] TurboSight TBS 6205 Frontend:
tbs6205fe - software version is 2.0.0.0
[ 9.063788] cx25840 9-0044: loaded v4l-cx23885-avcore-01.fw firmware (16382 bytes)
[ 9.071127] cx23885_dvb_register() allocating 1 frontend(s)
[ 9.071129] cx23885[0]: cx23885 based dvb card
[ 9.072334] TurboSight TBS 6205 Frontend:
tbs6205fe - Successfully Initialized
[ 9.072337] DVB: registering adapter 0 frontend 0 (TurboSight TBS 6281 DVBC frontend)...
[ 9.072376] DVB: registering new adapter (TBS PCIE DVB Adapter)
[ 9.242391] EXT4-fs (sda8): mounted filesystem with ordered data mode. Opts: (null)
[ 9.328451] TurboSight TBS 6981 Frontend 0 Attaching...
[ 9.445742] EXT4-fs (sda10): mounted filesystem with ordered data mode. Opts: (null)
[ 9.483464] EXT4-fs (sdb5): mounted filesystem with ordered data mode. Opts: (null)
[ 10.287622] TurboSight TBS 6205 Frontend:
[ 10.428463] TurboSight TBS 6205 Frontend:
[ 10.429775] TurboSight TBS6281SE MAC Addresses: 00:22:ab:b1:19:92 - 00:22:ab:b1:19:93
[ 10.429777] DVB: registering adapter 1 frontend 0 (TurboSight TBS 6281 DVBC frontend)...
[ 11.389242] EXT4-fs (sdb6): mounted filesystem with ordered data mode. Opts: (null)
[ 11.408419] TurboSight TBS 6981 Frontend:
tbs6981fe - software version is 1.95.2.21
[ 11.408427] TurboSight TBS 6981 Frontend:
tbs6981fe - Successfully Initialized
[ 11.417697] EXT4-fs (sda6): mounted filesystem with ordered data mode. Opts: (null)
[ 11.452201] systemd-journald[1163]: Received request to flush runtime journal from PID 1
[ 11.461999] DVB: registering new adapter (cx23885[0])
[ 11.462011] DVB: registering adapter 2 frontend 0 (TurboSight TBS 6981 DVBS/S2 frontend)...
[ 11.489657] TurboSight TBS698x Dual DVB-S2 card port0 MAC=00:22:ab:f0:5b:54
[ 11.489664] cx23885_dvb_register() allocating 1 frontend(s)
[ 11.489668] cx23885[0]: cx23885 based dvb card
[ 11.489678] TurboSight TBS 6981 Frontend 1 Attaching...
[ 11.555657] EXT4-fs (sda9): mounted filesystem with ordered data mode. Opts: (null)
[ 11.572642] DVB: registering new adapter (cx23885[0])
[ 11.572652] DVB: registering adapter 3 frontend 0 (TurboSight TBS 6981 DVBS/S2 frontend)...
[ 11.600386] TurboSight TBS698x Dual DVB-S2 card port1 MAC=00:22:ab:f0:5b:55
[ 11.600392] cx23885_dev_checkrevision() Hardware revision = 0xa5
[ 11.600398] cx23885[0]/0: found at 0000:01:00.0, rev: 4, irq: 16, latency: 0, mmio: 0xdf200000
[ 11.636486] Registered IR keymap rc-tbs-nec
[ 11.636730] input: cx23885 IR (TurboSight TBS 6981) as /devices/pci0000:00/0000:00:01.0/0000:01:00.0/rc/rc0/input15
[ 11.640258] rc0: cx23885 IR (TurboSight TBS 6981) as /devices/pci0000:00/0000:00:01.0/0000:01:00.0/rc/rc0
[ 11.640466] input: MCE IR Keyboard/Mouse (cx23885) as /devices/virtual/input/input16
[ 11.640754] rc rc0: lirc_dev: driver ir-lirc-codec (cx23885) registered at minor = 0
[ 11.641048] CORE cx23885[1]: subsystem: 6981:8888, board: TurboSight TBS 6981 [card=33,autodetected]
[ 12.364474] cx25840 12-0044: cx23885 A/V decoder found @ 0x88 (cx23885[1])
[ 12.374378] cx25840 12-0044: firmware: direct-loading firmware v4l-cx23885-avcore-01.fw
[ 12.984419] cx25840 12-0044: loaded v4l-cx23885-avcore-01.fw firmware (16382 bytes)
[ 12.991958] cx23885_dvb_register() allocating 1 frontend(s)
[ 12.991960] cx23885[1]: cx23885 based dvb card
[ 12.991964] TurboSight TBS 6981 Frontend 0 Attaching...
[ 15.106077] TurboSight TBS 6981 Frontend:
[ 15.106083] TurboSight TBS 6981 Frontend:
[ 15.106098] DVB: registering new adapter (cx23885[1])
[ 15.106102] DVB: registering adapter 4 frontend 0 (TurboSight TBS 6981 DVBS/S2 frontend)...
[ 15.133865] TurboSight TBS698x Dual DVB-S2 card port0 MAC=00:22:ab:f0:1b:9e
[ 15.133868] cx23885_dvb_register() allocating 1 frontend(s)
[ 15.133869] cx23885[1]: cx23885 based dvb card
[ 15.133874] TurboSight TBS 6981 Frontend 1 Attaching...
[ 15.216174] DVB: registering new adapter (cx23885[1])
[ 15.216182] DVB: registering adapter 5 frontend 0 (TurboSight TBS 6981 DVBS/S2 frontend)...
[ 15.244310] TurboSight TBS698x Dual DVB-S2 card port1 MAC=00:22:ab:f0:1b:9f
[ 15.244317] cx23885_dev_checkrevision() Hardware revision = 0xa5
[ 15.244323] cx23885[1]/0: found at 0000:04:00.0, rev: 4, irq: 19, latency: 0, mmio: 0xdf000000
[ 15.244353] Registered IR keymap rc-tbs-nec
[ 15.244462] input: cx23885 IR (TurboSight TBS 6981) as /devices/pci0000:00/0000:00:1c.7/0000:04:00.0/rc/rc1/input17
[ 15.248022] rc1: cx23885 IR (TurboSight TBS 6981) as /devices/pci0000:00/0000:00:1c.7/0000:04:00.0/rc/rc1
[ 15.248177] input: MCE IR Keyboard/Mouse (cx23885) as /devices/virtual/input/input18
[ 15.249080] rc rc1: lirc_dev: driver ir-lirc-codec (cx23885) registered at minor = 1
[ 31.014498] NET: Registered protocol family 4
[ 31.763429] NET: Registered protocol family 3
[ 31.778432] NET: Registered protocol family 5
Meindert
Re: No services found with DVB-C - Driver correct? (tbs6205)
Postby Meindert » Sat Sep 17, 2016 3:33 pm
lspci show this ( DVB-S2 4 Tuner PCIe Card ?):
00:00.0 Host bridge: Intel Corporation Sky Lake Host Bridge/DRAM Registers (rev 07)
00:01.0 PCI bridge: Intel Corporation Sky Lake PCIe Controller (x16) (rev 07)
00:02.0 VGA compatible controller: Intel Corporation Sky Lake Integrated Graphics (rev 06)
00:14.0 USB controller: Intel Corporation Sunrise Point-H USB 3.0 xHCI Controller (rev 31)
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-H Thermal subsystem (rev 31)
00:16.0 Communication controller: Intel Corporation Sunrise Point-H CSME HECI #1 (rev 31)
00:17.0 SATA controller: Intel Corporation Sunrise Point-H SATA controller [AHCI mode] (rev 31)
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-H PCI Express Root Port #5 (rev f1)
00:1c.6 PCI bridge: Intel Corporation Sunrise Point-H PCI Express Root Port #7 (rev f1)
00:1c.7 PCI bridge: Intel Corporation Sunrise Point-H PCI Express Root Port #8 (rev f1)
00:1d.0 PCI bridge: Intel Corporation Sunrise Point-H PCI Express Root Port #9 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Sunrise Point-H LPC Controller (rev 31)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-H PMC (rev 31)
00:1f.3 Audio device: Intel Corporation Sunrise Point-H HD Audio (rev 31)
00:1f.4 SMBus: Intel Corporation Sunrise Point-H SMBus (rev 31)
01:00.0 Multimedia video controller: Conexant Systems, Inc. CX23885 PCI Video and Audio Decoder (rev 04)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 0c)
03:00.0 Multimedia controller: TBS Technologies DVB-S2 4 Tuner PCIe Card
04:00.0 Multimedia video controller: Conexant Systems, Inc. CX23885 PCI Video and Audio Decoder (rev 04)
Meindert
Postby Meindert » Sun Sep 18, 2016 3:13 pm
The initial problem is solved, I put totally wrong parameters in the configuration of TVheadend.
Still I like to know if the driver selected is meant to be
Meindert
Return to PCIe DVB-T2/T/C Dual Tuner Card TBS6281SE
