Should the RF output on the tuner be terminated?
Postby AndersG » Thu Jan 12, 2023 3:47 pm
Just curious. Should I terminate the RF output on the tuner card with a 75 ohm terminator if it is not connected further to another tuner or should I leave it unconnected?
AndersG
Re: Should the RF output on the tuner be terminated?
Postby steven » Fri Jan 13, 2023 10:34 am
you can let it unconnected
thanks
Postby AndersG » Fri Jan 13, 2023 4:37 pm
Will do. Thanks!
AndersG
Return to PCIe DVB-T2/T/C Dual Tuner Card TBS6281SE
