TbsCIapi and the paid channels
Postby pensas08 » Mon Sep 19, 2016 3:37 pm
i had tbs 6618 and it worked very well with the digilog cam +card but it got broken....I bought this tbs 6290se because this card is dual tuner.The problem is now that tbs6290 doesnt open any paid channels .I have tried with the tbs clabi version TbsCIapi v.1.0.1.8 and TbsClabi.dll v.1.0.1.9 and no succeed.Where can I download another version of tbsclabi and try if they work with the card.I watch tv with dvbviewer pro 5.06 and windows 10
pensas08
Re: TbsCIapi and the paid channels
Postby INGBEAN » Mon Sep 19, 2016 6:15 pm
Hello pensas08!
Please try following, it works since DVBViewer Pro V5.2.7:
Copy your TbsCIapi.dll (V 1.0.1.8) AGAIN into DVBViewer program directory and rename it to TbsCIapi1.dll - as result you have 2 DLL-files in this directory (TbsCIapi and TbsCIapi1).
Remark: both files must be the same version.
If no success, you can try with V1.0.1.9.
Or you can download V1.0.1.2 -> http://www.tbsdtv.com/download/document ... .0.1.2.zip
But I am not sure, if this old version supports TBS 6290SE.
Your feedback is appreciated.
Best regards!
INGBEAN
INGBEAN
Postby pensas08 » Tue Sep 20, 2016 12:39 am
I tried every way,no success...my version of DVBViewer is 5.6 .04.Any other alternatives...? My other card old terratec cinergy pci-hd opens those channels fine.
pensas08
Postby INGBEAN » Mon Oct 31, 2016 7:25 am
Hello pensas08!
Let's try 2 different ways.
way 1 - new DLL for DVBViewer:
TBS has released TBSCIAPI.DLL V1.0.2.0 at the end of september 2016.
You find it here -> http://www.tbsiptv.com/download/common/ ... .0.2.0.zip
Don't forget to follow the "copy and rename instructions" I gave in my upper post.
way 2 - test of TBSViewer:
Download latest TBSViewer V20160919 -> http://www.tbsiptv.com/download/common/ ... 160919.zip
Install it on your PC and test this software - maybe it works (because it's newer than original DVBViewer)?
Remark: TBSViewer is an "OEM version of DVBViewer".
Please send your feedback of both ways.
INGBEAN
INGBEAN
Return to DVB-T2/T/C Dual Tuner Dual CI PCIe Card TBS6290SE
