Help now web interface
Postby Tictalk » Mon Sep 05, 2016 2:16 am
hi i purchased the tbs2603 and worked fine for 1 night
now i can access web interface
i have tried to reset device ,, try ip 192.168.1.168 and search my router but not see tbs2603
do u have a solution please or i need to send device back as faulty ?
thanks
Tictalk
Re: Help now web interface
Postby freddy12 » Mon Sep 05, 2016 6:01 am
Does it register in your router as connected?
freddy12
Postby Tictalk » Tue Sep 06, 2016 1:23 am
freddy12 Wrote:Does it register in your router as connected?
hi freddy
thanks for the reply ,, i can't see it in router
ive tried all the usual stuff like new cables reboot router etc .... still nothing
ive also tried to reset the device with the pin button and reboot
the box was working fine with latest software and streamed great for one night ,, but now nothing
I'm thinking maybe a hardware problem ?
Tictalk
Postby freddy12 » Tue Sep 06, 2016 3:11 am
hi freddy
its either that or wrong gateway, check what gateway your router uses and what encoder is set at which is usually 192.168.1.168
freddy12
Postby Tictalk » Tue Sep 06, 2016 5:58 am
gateway is 192.168.0.1
ive tried 192.168.1.168 and 192.168.1.168
Tictalk
Postby freddy12 » Tue Sep 06, 2016 5:17 pm
Tictalk Wrote:gateway is 192.168.0.1
try plugging the encoder directly into your computer and changing your pc gateway to same gateway and then connecting, had to do this to a mates different brand encoder recently
freddy12
Postby Tictalk » Wed Sep 07, 2016 1:26 am
thanks freddy ,, problem solved
set the computer to 192.16.8.1.1
and bingo we have web if
great help m8 ,, its appreciated
Tictalk
Postby Tictalk » Wed Sep 07, 2016 1:30 am
maybe an admin can mark this as solved thanks
Tictalk
Postby freddy12 » Wed Sep 07, 2016 1:50 am
then change gateway on device to match router gateway and plug it all back in and your all set :)
freddy12
