Professional Test Report of TBS6590 card
Postby Jenny » Tue Aug 15, 2017 6:48 pm
Hi All,
Good day! Here comes professional test report on TBS6590 Multi Standard Dual Tuner Dual CI PCI-e Card from Satelescu. :)
Check it on RDI forum: http://www.rdi-board.com/threads/158080-TBS6590-Multi-Standard-Dual-Tuner-Dual-CI-PCI-e-Card?p=1424484#post1424484
TBS6590 multi standard dual tuner dual CI card is a twin tuner card for watching or recording two different channels from two different frequencies simultaneously. TBS6590 supports multiple digital TV standards, including DVB-S2/S, DVB-T2/T,DVB-C2/C, DVB-S2X and ISDB-T.
It is built with 2 Common Interface which allows insertion of CAM and smartcard for pay TV, so it is a good choice for watching/recording digital HD TV on PC. What's more, with this multi-standard TV tuner card, a switchover between different digital TV signals is much easier, you just need to plug another signal cable instead of taking out the card from your server.
Support DVB-S/S2/S2X 、 DVB-T/T2/C(ITU-T J.83 Annex A/B/C)/C2 、 ISDB-T
Watch & record TV/ radio programs on PC
Common Interface (Dual CI) Support
SD or HD TV receiving
Data receiving
IPTV streaming
Media monitoring
Digital content distribution
For more details, you can check here: https://www.tbsiptv.com/tbs-tv-tuner-pcie/tbs-tv-tuner-pcie-multi-standard/tbs6590-multi-standard-dual-tuner-dual-ci-pci-e-card
TBS6590 User Guide: https://www.tbsiptv.com/download/tbs6590/tbs6590_user_guide.pdf
Any further question, pls feel free to contact us support@tbsdtv.com Thanks! :)
Best Regards,
Jenny Feng
TBS Technology
Professional Test Report of TBS6590 Multi Standard Dual Tuner Dual CI PCI-e Card_01.jpg
Professional Test Report of TBS6590 Multi Standard Dual Tuner Dual CI PCI-e Card_02.jpg
Professional Test Report of TBS6590 Multi Standard Dual Tuner Dual CI PCI-e Card_03.jpg
Professional Test Report of TBS6590 Multi Standard Dual Tuner Dual CI PCI-e Card_04.jpg
Jenny
