perfect picture, but swoosh noice
TBS6301 HDMI Video Capture Card with HDMI1.4 port, completely support full HD Video and Audio capture and playback. It provides HDMI input of highest quality, and meets the HDMI 1.4 standard, satisfies the 1080i resolutions and can capture the LPCM audio signals in HDMI, you can easily capture signals from different kinds of devices by TBS6301 HDMI Capture Card without limitation. For TBS6301 windows driver is BDA architecture compatible with DVBDream,DVBView,... ,Linux driver is V4l architecture compatible with dvblast,tvheadend,astra..
Postby janty » Thu Sep 14, 2017 3:14 pm
we are using a 6301 cature card for a couple of weeks now, and it worked perfect. Yesterday we received a new ("l*bara box" for S*nTV) with version 3.0 on it. wen connected directly to the TV both video and audio are running perfect. Wen connecting to the capture card, video is running very smooth, but the audio gives a swoosh noice. behind that swoosh noice you van hear a little from the original sound.
We used several option with HDMIOPTIONS: , but all have the same result. Is this a trick from L*bara, or?
used option:./hdmioptions -a 0 -n 0 -K S*nTV -A
also after - r (reset) and/or -R (mcu reset) we have the same result.
we use Mumudvb as software to stream to VLC and/or iptv-panel
Setup:
i5-3550 quad core CPU
8 Gig Mem
Ubuntu server edition 14.04.5 LTS (up to date)
TBS-drivers: latest open source
only 1 card is the server
Mumudvb:
card=0
port_http=12XXX
multicast_ipv4=0
multicast_ipv6=0
unicast=1
freq=12515
srate=22000
autoconfiguration=full
with this hardware and software setting the old box and other inputs worked just fine, only the new box gives us the strange noice.
Please advice wat other options we can try,
greetings,
janty
janty
Return to TBS6301 HDMI Capture Card
