Multiple Inputs H.264/H.265 IPTV Transcoder TBS8520
TBS8520 and TBS8510
Postby Jenny » Thu Apr 12, 2018 6:27 pm
Dear All,
Good day. Here I'd like to share New Arrival Multiple inputs H.264/H.265 IPTV Transcoder TBS8520 with you. It's an all-in-one IPTV / OTT /CATV headend server for streaming, encoding and transcoding.
With Two Giga Ethernet Ports, TBS8520 IPTV transcoder supports to transcode up to 80 SD or 30 Full HD streams simultaneously.
Multiple Inputs Available: DVB-S2/S/T2/T/C2/C/ISDB-T, HDMI, ASI or IP
GbE IP output: UDP, RTMP, HTTP, Pull / Push HTTP, Live smooth (HLS), FTP M3u8 playlist files outputs.
Lower video's bit rate for live streaming,
Upload channels to RTMP Server
Import HTTP streams and transcode it
Check more details here: https://www.tbsiptv.com/multiple-inputs-h.264-h.265--iptv-transcoder-tbs8520
TBS8520 datasheet: https://www.tbsiptv.com/download/tbs8520/tbs8520_data_sheet.pdf
TBS8520 user guide: https://www.tbsiptv.com/download/tbs8520/tbs8520_user_guide.pdf
Any further question, pls feel free to e-mail us sales@tbsdtv.com. :)
Best Regards,
TBS Team
E-mail sales@tbsdtv.com
TBS Technology
DVB Broadcast |IPTV System Solution | IPTV Head-end | Video IP Encoder | OEM & ODM Solution
Jenny
Re: Multiple Inputs H.264/H.265 IPTV Transcoder TBS8520
Postby TheTroll » Thu Sep 27, 2018 10:50 pm
could you please tell us what CPU/GPU it is using to achieve 30 transcodes in // ?
TheTroll
Postby diabloss » Mon Oct 08, 2018 1:27 pm
TheTroll Wrote:Hi,
Special customized GPU with regular e3 server class cpu.
diabloss
Postby Jenny » Tue Oct 09, 2018 11:22 am
Sorry for late reply. We use GPU transcoding in TBS8520 real-time IPTV transcoder. It supports to transcode up to 30 full HD or 80 SD streams simultaneously. May I know how many channels / IP streams you need to transcode?
Links for your reference:
How to use TBS8520 to low down the video bit rate ? https://youtu.be/g4tRNptA2FY
Any further question, please don't hesitate to contact me.
Best Regards,
Jenny Feng
Jenny
Postby firozkhan » Tue Oct 08, 2019 12:07 pm
Great Post :)
firozkhan
Return to TBS Transcoding solution
