Future of the Linux-Driver
Re: Future of the Linux-Driver
Postby softnhard » Sun May 22, 2011 11:21 am
Take a look to http://blog.mohammadzadeh.info/index.php/step-by-step-guide-to for a complete guide on how to install.
softnhard
Postby smv1210 » Mon May 23, 2011 7:45 pm
The "official" 2.6.38 kernel's driver has been appeared on the Downloads page,
However... it is not in-line with real 2.6.38 driver's structure; it still uses legacy "linux/drivers/media/IR" instead of "linux/drivers/media/rc", etc, etc.
smv1210
Postby stevellion » Tue May 24, 2011 5:22 am
I don't suppose there are any release notes with it, or available?
It looks like there are few updated files to it, but can't tell what's been done - apart from it actually compiles now without all the hacking we've had to do.
stevellion
Postby stevellion » Tue May 24, 2011 6:36 am
I can confirm it compiles, installs and works fine though!
stevellion
Postby smv1210 » Tue May 24, 2011 6:55 am
Yes it does compile, however, if you are going to use vdr-sasc-ng with it, an additional patch is still needed:
Code: Select all
--- linux/drivers/media/dvb/dvb-core/dvbdev.c   2011-05-17 18:43:04.000000000 +0300
+++ linux/drivers/media/dvb/dvb-core/dvbdev.c   2011-05-23 22:48:40.514641108 +0300
@@ -36,7 +36,7 @@
 #include <linux/smp_lock.h>
 #include "dvbdev.h"
-static DEFINE_MUTEX(dvbdev_mutex);
+//static DEFINE_MUTEX(dvbdev_mutex);
 static int dvbdev_debug;
 module_param(dvbdev_debug, int, 0644);
@@ -70,7 +70,8 @@
    struct dvb_device *dvbdev;
-   mutex_lock(&dvbdev_mutex);
+   lock_kernel();
+   //mutex_lock(&dvbdev_mutex);
    down_read(&minor_rwsem);
    dvbdev = dvb_minors[iminor(inode)];
@@ -101,12 +102,13 @@
       fops_put(old_fops);
       up_read(&minor_rwsem);
-      mutex_unlock(&dvbdev_mutex);
+      //mutex_unlock(&dvbdev_mutex);
+                unlock_kernel();
       return err;
 fail:
    return -ENODEV;
@@ -169,6 +171,7 @@
             unsigned int cmd, unsigned long arg)
    struct dvb_device *dvbdev = file->private_data;
+        int ret;
    if (!dvbdev)
       return -ENODEV;
@@ -176,7 +179,12 @@
    if (!dvbdev->kernel_ioctl)
       return -EINVAL;
-   return dvb_usercopy (file, cmd, arg, dvbdev->kernel_ioctl);
+   //return dvb_usercopy (file, cmd, arg, dvbdev->kernel_ioctl);
+        lock_kernel();
+        ret = dvb_usercopy(file, cmd, arg, dvbdev->kernel_ioctl);
+        unlock_kernel();
+        return ret;
 EXPORT_SYMBOL(dvb_generic_ioctl);
@@ -441,10 +449,10 @@
    /* call driver */
    if ((err = func(file, cmd, parg)) == -ENOIOCTLCMD)
       err = -EINVAL;
    if (err < 0)
       goto out;
smv1210
Postby hda » Thu May 26, 2011 3:18 am
Could someone please point me to this new driver for 2.6.38.
I can still only see the rar file for 2.6.35 on the downloads page.
Cheers.
hda
Postby smv1210 » Thu May 26, 2011 2:48 pm
http://www.tbsdtv.com/download/common/linux-tbs-drivers_110523.rar
smv1210
Postby hda » Thu May 26, 2011 7:30 pm
smv1210 wrote:http://www.tbsdtv.com/download/common/linux-tbs-drivers_110523.rar
Thanks a lot.
hda
Postby hda » Fri May 27, 2011 1:15 am
I'm still getting same errors as when I compiled with Andys patch.
It looks like this new rar is just a re-packaging or Andys work and not a proper solution :(
hda
Postby stevellion » Mon May 30, 2011 5:55 am
What errors are you getting? I just compiled it straight away, with no problems.
Did you follow all the README instructions properly?
With these latest drivers, you shouldn't need any patches.
stevellion
PreviousNext
