Linux Driver for Kernel 3.x Released
Re: Linux Driver for Kernel 3.x Released
Postby wesser » Wed Oct 26, 2011 12:05 am
Thanks smv1210
I shall give your method a try.
Does this overcome the problems people seem to be having with the file permissions posted above?
wesser
Postby smv1210 » Wed Oct 26, 2011 1:05 am
wesser wrote:...Does this overcome the problems people seem to be having with the file permissions posted above?
At least, I have not had reported issues, while compiling the driver as a "root" (sudo -s)
smv1210
Postby micksulley » Fri Oct 28, 2011 6:45 am
I have a new install of Ubuntu 11.10 64bit, just installed the TBS6981 driver from your site, all seemed to install OK but after the reboot I get
Code: Select all
[email protected]:~$ dmesg | grep cx23885
[   24.090788] cx23885 driver version 0.0.2 loaded
[   24.090847] cx23885 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[   24.090857] cx23885[0]: Your board isn't known (yet) to the driver.
[   24.090859] cx23885[0]: Try to pick one of the existing card configs via
[   24.090862] cx23885[0]: card=<n> insmod option.  Updating to the latest
[   24.090865] cx23885[0]: version might help as well.
[   24.090870] cx23885[0]: Here is a list of valid choices for the card=<n> insmod option:
[   24.090875] cx23885[0]:    card=0 -> UNKNOWN/GENERIC
[   24.090880] cx23885[0]:    card=1 -> Hauppauge WinTV-HVR1800lp
[   24.090884] cx23885[0]:    card=2 -> Hauppauge WinTV-HVR1800
[   24.090889] cx23885[0]:    card=3 -> Hauppauge WinTV-HVR1250
[   24.090893] cx23885[0]:    card=4 -> DViCO FusionHDTV5 Express
[   24.090898] cx23885[0]:    card=5 -> Hauppauge WinTV-HVR1500Q
[   24.090903] cx23885[0]:    card=6 -> Hauppauge WinTV-HVR1500
[   24.090907] cx23885[0]:    card=7 -> Hauppauge WinTV-HVR1200
[   24.090912] cx23885[0]:    card=8 -> Hauppauge WinTV-HVR1700
[   24.090917] cx23885[0]:    card=9 -> Hauppauge WinTV-HVR1400
[   24.090922] cx23885[0]:    card=10 -> DViCO FusionHDTV7 Dual Express
[   24.090926] cx23885[0]:    card=11 -> DViCO FusionHDTV DVB-T Dual Express
[   24.090932] cx23885[0]:    card=12 -> Leadtek Winfast PxDVR3200 H
[   24.090937] cx23885[0]:    card=13 -> Compro VideoMate E650F
[   24.090942] cx23885[0]:    card=14 -> TurboSight TBS 6920
[   24.090946] cx23885[0]:    card=15 -> TeVii S470
[   24.090950] cx23885[0]:    card=16 -> DVBWorld DVB-S2 2005
[   24.090955] cx23885[0]:    card=17 -> NetUP Dual DVB-S2 CI
[   24.090960] cx23885[0]:    card=18 -> Hauppauge WinTV-HVR1270
[   24.090964] cx23885[0]:    card=19 -> Hauppauge WinTV-HVR1275
[   24.090969] cx23885[0]:    card=20 -> Hauppauge WinTV-HVR1255
[   24.090973] cx23885[0]:    card=21 -> Hauppauge WinTV-HVR1210
[   24.090977] cx23885[0]:    card=22 -> Mygica X8506 DMB-TH
[   24.090981] cx23885[0]:    card=23 -> Magic-Pro ProHDTV Extreme 2
[   24.090985] cx23885[0]:    card=24 -> Hauppauge WinTV-HVR1850
[   24.090989] cx23885[0]:    card=25 -> Compro VideoMate E800
[   24.090993] cx23885[0]:    card=26 -> Hauppauge WinTV-HVR1290
[   24.090997] cx23885[0]:    card=27 -> Mygica X8558 PRO DMB-TH
[   24.091002] cx23885[0]:    card=28 -> LEADTEK WinFast PxTV1200
[   24.091007] cx23885[0]:    card=29 -> GoTView X5 3D Hybrid
[   24.091011] cx23885[0]:    card=30 -> NetUP Dual DVB-T/C-CI RF
[   24.094076] CORE cx23885[0]: subsystem: 6981:8888, board: UNKNOWN/GENERIC [card=0,autodetected]
[   24.222164] cx23885_dev_checkrevision() Hardware revision = 0xa5
[   24.222175] cx23885[0]/0: found at 0000:01:00.0, rev: 4, irq: 16, latency: 0, mmio: 0xfba00000
[   24.222188] cx23885 0000:01:00.0: setting latency timer to 64
Any idea what I have done wrong?
Mick
micksulley
Postby micksulley » Sun Oct 30, 2011 8:03 am
OK I have fixed that. I had run everything with sudo, started again and used sudo su to get to root and it has worked in that it can now see the card.
Then in scan.c I had to comment out the section that looked for DVB_API_VERSION being 5.1
I am now stuck again when I try to scan for channels. This is what I get
Code: Select all
[email protected]:/usr/local/src/tbs6981$ szap-s2/szap-s2 -c astra_szap-s2.conf -a 2 -p -r -S 0 "BBC"
reading channels from file 'astra_szap-s2.conf'
zapping to 3 'BBC':
sat 0, frequency 11597 MHz V, symbolrate 22000000, coderate auto, rolloff 0.35
vpid 0x00a3, apid 0x005c, sid 0x2742
using '/dev/dvb/adapter2/frontend0' and '/dev/dvb/adapter2/demux0'
and it just hangs.
Any ideas?
Mick
micksulley
Postby smv1210 » Mon Jan 30, 2012 1:27 am
The topic's name: "Linux Driver for Kernel 3.x Released" has to be changet to less optimistic one - "Linux Driver for Kernel 3.0.x Released", since it is not compiling on 3.2 kernel :evil:
smv1210
Postby bob » Tue Jan 31, 2012 12:16 pm
I can't find any message relate with TBS 6921 hardware,it seems your main board can't find the TBS 6921.
Please try to clean up the 6921's PCIE connection golden pin with rubber .
Or you can try to update the main board's BIOS,some earlier BIOS don't support PCIE1.0a.
Regards!
bob
Postby hda » Wed Feb 01, 2012 10:53 pm
Any idea when this will be working with the 3.2 kernel?
hda
Postby Simon » Sun Feb 12, 2012 6:15 am
I get the same kernel oops during boot as others have been getting (TBS6984, using the v111118 driver on Ubuntu 11.10, kernel 3.0.0-15, x86_64), but unfortunately the file hosting site you use no longer allows users to share files so I can't try the updated version.
Is there somewhere else you could put it for me to pick up? Or perhaps you could email me the changes if they're small enough?
Are they likely to make it to the main download site soon?
Cheers,
Simon.
Simon
Postby knap » Sun Feb 12, 2012 6:43 pm
The Dvb-s2 card TBS 6981 Work in Kubuntu 11.10 - KDE4.7
Tested with kaffeine 1.2.2
From Driver -> TBS6981 linux driver is updated to V111118
A quick example I make a guide for all
Code: Select all
[email protected]:~$ uname -a
Linux knapx 3.0.0-16-generic #28-Ubuntu SMP Fri Jan 27 17:44:39 UTC 2012 x86_64 x86_64 x86_64 GNU/Linux
Code: Select all
[email protected]:~$ ls -l /dev/dvb
totale 0
drwxr-xr-x 2 root root 120 2012-02-12 10:37 adapter0
drwxr-xr-x 2 root root 120 2012-02-12 10:37 adapter1
Code: Select all
[   15.190138] cx23885 driver version 0.0.3 loaded
[   15.190167] cx23885 0000:03:00.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[   15.190422] CORE cx23885[0]: subsystem: 6981:8888, board: TurboSight TBS 6981 [card=33,autodetected]
[   15.991847] cx25840 2-0044: cx23885 A/V decoder found @ 0x88 (cx23885[0])
[   16.679859] cx25840 2-0044: loaded v4l-cx23885-avcore-01.fw firmware (16382 bytes)
[   16.687284] cx23885_dvb_register() allocating 1 frontend(s)
[   16.687287] cx23885[0]: cx23885 based dvb card
[   16.808403] DVB: registering new adapter (cx23885[0])
[   16.835466] cx23885_dvb_register() allocating 1 frontend(s)
[   16.835471] cx23885[0]: cx23885 based dvb card
[   16.916008] DVB: registering new adapter (cx23885[0])
[   16.943008] cx23885_dev_checkrevision() Hardware revision = 0xa5
[   16.943012] cx23885[0]/0: found at 0000:03:00.0, rev: 4, irq: 19, latency: 0, mmio: 0xfe800000
[   16.943018] cx23885 0000:03:00.0: setting latency timer to 64
[   16.988068] input: cx23885 IR (TurboSight TBS 6981) as /devices/pci0000:00/0000:00:1c.3/0000:03:00.0/rc/rc0/input2
[   16.991501] rc0: cx23885 IR (TurboSight TBS 6981) as /devices/pci0000:00/0000:00:1c.3/0000:03:00.0/rc/rc0
[   16.991549] input: MCE IR Keyboard/Mouse (cx23885) as /devices/virtual/input/input3
[   16.991602] rc rc0: lirc_dev: driver ir-lirc-codec (cx23885) registered at minor = 0
knap
Postby knap » Sun Feb 12, 2012 11:24 pm
-- How to Install the card Dvb-S2 TBS 6981
-- Work in Kubuntu 11.10 Linux Kernel 3.0.0-16-generic x86_64
-- For All
http://knap-home.no-ip.org/forum/viewthread.php?thread_id=57&pid=189#post_189
See you later .... :lol:
knap
PreviousNext
