TBS 2604 4k Encoder Resolution 3840x2160 Failure
Postby victormika » Thu Jul 04, 2019 7:25 am
Hello team,
i've received my new TBS 2604 and connect it to the UHD receiver by HDMI...so when i try to output on UHD resolution ( 3840x2160 ) :arrow: i've issue ( the resolution on OUTPUT stay always on Full HD (1920x1080 ).
My question is :
How to get the real resoltion UHD ( 3840x2160 ) on this device ? it's incredible that the encoder doesn't output the needed format.
Is there anyway to make it working fine ( correcting some arguments on Main ? )
I've done the new firmware update : 1.0.17 but doesn't affect anything the resolution Full HD still on Output.
Please fix to me this issue and hope you good luck for future projects.
Best Regards.
victormika
Re: TBS 2604 4k Encoder Resolution 3840x2160 Failure
Postby echomay » Thu Jul 04, 2019 10:13 am
Can you please be sure again that the input signal to the encoder is 4K(3840*2160)?Iis your reciver need a config of the playmode, and set it to 4k?
echomay
Postby victormika » Fri Jul 05, 2019 1:57 am
I've receiver UHD with OUTPUT 3840x2160 50FPS and 60FPS ( Standard mode on the World )
Thanks to give a Help.
Best Regards.
victormika
Postby echomay » Fri Jul 05, 2019 4:01 pm
Please mail to me, and i will send you a new version to try again.
echo@tbsdtv.com
echomay
Postby victormika » Sat Jul 06, 2019 1:03 am
Thank you Sir,
Mail sent to you.
Best Regards.
victormika
Return to TBS2604 / TBS2640 4K UHD HD H.265 & H.264 HDMI Video Encoder
