Auto-adjust stream settings based on HDMI input
Postby KermitT » Fri Nov 22, 2019 3:03 am
Is there a way to make the stream automatically adapt its settings to the encoding size/resolution and frame rate of the HDMI source signal?
Attached to my encoder is device that broadcasts in different formats (1080i30, 720p60 etc.). I'd like to output the stream in its original format but avoid changing settings manually through WebUI every time a format switch occurs.
Device: TBS-2604, Firmware version: 1.0.11 (factory default)
KermitT
Re: Auto-adjust stream settings based on HDMI input
Postby echomay » Fri Nov 22, 2019 2:41 pm
This "auto" option of the encode size is means encoding the video as it's orignal resolution.
echomay
Postby KermitT » Tue Nov 26, 2019 1:24 am
Yes, I noticed that option. But this only relates to the resolution, right?
How can the encoder be configured to adapt to the encoding frame rate of the input device? (It looks like the field requires a fixed rate to be entered with no "auto" option available.)
KermitT
Postby echomay » Tue Nov 26, 2019 4:08 pm
Yes, there are no "auto " in framrate, you need set it manully, see status->video parameters, to find thei nput fps and set it into encode framrate.
echomay
Return to TBS2604 / TBS2640 4K UHD HD H.265 & H.264 HDMI Video Encoder
