How to use TBS6900 DVB dual CI PCI-e Card?
TBS6900 is a DVB network PCI-E card with two common interface slots, where you can insert 2 CAM inside to decrypt the pay channels.
TBS6900 DVB dual CI PCI-e card is a stand alone CI/CI+ a pcie card to use as a network resource.
Postby Jenny » Wed Dec 18, 2019 11:48 am
Dear All,
As we know, TBS6900 is a DVB network PCI-E card with two common interface slots, where you can insert 2 CAM inside to decrypt the pay channels. How does it work??
Here I'd like to share a live video of TBS6900 DVB dual CI PCI-e card for you.
"TBS6900 stand alone CI/CI+ a pcie card to use as a network resource" https://youtu.be/AN39j4KLKDM
How to use TBS6900 with other TBS products ?
TBS6900 compatible with all TBS tuner cards and server products , supports to install in MOI pro AMD or MOI-V , this is especially good in systems with a limited number of free slots and have lots of channels need to decrypted. For example, you can use 2 TBS6909 (means you can receive from 16 transponders) for receiving the signals in MOI Pro AMD, and then use 2 TBS6900 for decryption.
Buy now: https://www.tbsiptv.com/tbs6900-dvb-dual-pci-e-card
Any furthter question or feedback, feel free to e-mail us support@tbsdtv.com or leave your comments below. Thank you.
Best Regards,
Jenny Feng
Jenny
Return to TBS6900 DVB Dual CI PCI-E Card
Users browsing this forum: No registered users and 11 guests
