TBS 6921 release date
Re: TBS 6921 release date
Postby cody » Wed Feb 16, 2011 7:38 am
Derrick Wrote:If the tool is working, you'll only find what you already know
still, it should produce some output - added to my list of issues about the new DVB-S2 demodulator inside 6921/8921/5921 (Q-box III) that i need to check, investigate, etc.
BTW, a little off-the-topic, but still related, because that work should lead to improvement of all 6921/8921/5921 drivers, Derrick i'm going to post debug driver for the "frequency problem" you reported with your 8921 card in the thread here:
https://shop.tbsdtv.com/forum/viewtopic.php?f=27&t=211&start=10
i'm guessing some of the more 6921/5921 users that are interested in more advanced things than just watching DTH in their Windows Media Center could also be interested to follow the thread.
Postby paulus » Wed Feb 16, 2011 11:04 am
Derrick Wrote:What do you expect to find? If the tool is working, you'll only find what you already know: wideband transponder on DBS satellites ;)
For transponders and channels that are hot 24/7, it's not a problem as most programs have up to date TP lists.
However, the blind scan is pretty much a requirement when searching for back hauls and wild feeds on the NA sats.
paulus
Postby starman345 » Sun Mar 27, 2011 9:54 pm
I loaded up the new driver 1.0.0.4 for my 8921 and now I get about 3/4 through the progress bar during a BS and the program crashes :o Rolling back to the previous 1.0.0.3 driver results in the BS tool no longer recognizing the 8921 card ....so, remove everything and start from scratch...sigh :x
10' dish- Bullseye II c/ku
55.5W to 139W
Windows 8.1 64 bit
TBS 8922 Prof 7301 TBS 6925
starman345
Postby pjm » Fri Apr 22, 2011 10:42 am
cody Wrote:
pjm Wrote:TBS TSReader_BDA source is not reading command line inputs
at least in my opinion it has to be something else, but anyway there is no problem to add command line inputs to the module. i'm close to finishing my on-going project and thus have more time to improve 6921/8921 software bugs, but in any case i will try to find some time and build such module for you in the next several days.
Is anyone looking at this problem - its now 2 & 1/2 months and I haven't heard a word from anyone at TBS? - despite Cody's statement above to build a module within a few days!
pjm
Previous
