The most important is when I switch between "Ned1" or "BVN" or every channel which is on 19,2E to "Ned1 HD" which is on 23,5E. Here you can see that after dish is moved there is no signal. Only when I move to another channel on 23,5E, example "Ned2 HD" I will get signal and if I go back to "Ned1 HD" I wil also get signal on that channel also.
Please see it and tell me what is going wrong in driver, because this is the same problem as with TVSource.
- Code: Select all
[1-5-2011 12:27:18 : 453] Captains Log: Star Date 1-5-2011 12:27:18
[1-5-2011 12:27:18 : 453] --------------------------------------------------------
[1-5-2011 12:27:18 : 453] Program started. DvbDream v1.5.5.0
[1-5-2011 12:27:18 : 453] [USER ] ""
[1-5-2011 12:27:18 : 453] [LANG ] DUTCH.ini
[1-5-2011 12:27:18 : 453] [DEV ] BDA
[1-5-2011 12:27:18 : 453] [STATS] CHANNELS : Chs:359 FavChs:0 RmtChs:359
[1-5-2011 12:27:18 : 453] [STATS] USAGE : Launchs:16 Usage: 9:43
[1-5-2011 12:27:18 : 453] [STATS] SATS : Sats:5 (0130 0160 0192 0235 0285)
[1-5-2011 12:27:18 : 453] [SINCE] 1.5.5.0
[1-5-2011 12:27:31 : 13625] [TimeProfiler] Initializing DVB Device: 0 ms
[1-5-2011 12:27:31 : 13828] Loading device:bda.dev
[1-5-2011 12:27:32 : 15078] DeviceTag: "TBS 6921 BDA DVBS/S2 Tuner/Demod"
[1-5-2011 12:27:32 : 15094] [TimeProfiler] Initializing DVB Device: 1469 ms
[1-5-2011 12:27:32 : 15094] [TimeProfiler] Setting display: 0 ms
[1-5-2011 12:27:32 : 15156] [TimeProfiler] Setting display: 62 ms
[1-5-2011 12:27:32 : 15156] [TimeProfiler] Filling channel tree: 0 ms
[1-5-2011 12:27:32 : 15156] --LoadChannelsTree()---
[1-5-2011 12:27:32 : 15172] [TimeProfiler] LoadChannelsTree_GenFav(): 0 ms
[1-5-2011 12:27:32 : 15172] SelectLastCh:1
[1-5-2011 12:27:32 : 15172] SelectLastCh:2
[1-5-2011 12:27:32 : 15172] [TimeProfiler] Filling channel tree: 16 ms
[1-5-2011 12:27:32 : 15172] [TimeProfiler] Init DirectShow: 0 ms
[1-5-2011 12:27:33 : 15344] >>>>: ShowPip(chid:135)
[1-5-2011 12:27:33 : 16062] DS:OK
[1-5-2011 12:27:33 : 16078] pips[0].ds.StartGraph;
[1-5-2011 12:27:33 : 16078] DSWindow:Refresh "Filters" menu...
[1-5-2011 12:27:33 : 16078] <<<<: ShowPip(chid:135)
[1-5-2011 12:27:33 : 16078] InitDirectShow:1
[1-5-2011 12:27:33 : 16078] InitDirectShow:2
[1-5-2011 12:27:33 : 16078] InitDirectShow:3
[1-5-2011 12:27:33 : 16078] [TimeProfiler] Init DirectShow: 906 ms
[1-5-2011 12:27:33 : 16125] [TimeProfiler] Goto Last Channel: 0 ms
[1-5-2011 12:27:33 : 16125] EPG Parser
[1-5-2011 12:27:33 : 16125] Loading addons
[1-5-2011 12:27:33 : 16125] [TimeProfiler] Loading Add-ons: 0 ms
[1-5-2011 12:27:33 : 16125] [ModuleAPI] Disabled module, "AutoCHLBackup.mod" will not be loaded.
[1-5-2011 12:27:33 : 16125] [ModuleAPI] Disabled module, "BitrateView.mod" will not be loaded.
[1-5-2011 12:27:33 : 16125] [ModuleAPI] Disabled module, "chltools.mod" will not be loaded.
[1-5-2011 12:27:33 : 16125] [ModuleAPI] Disabled module, "ddosd.mod" will not be loaded.
[1-5-2011 12:27:33 : 16125] [ModuleAPI] Disabled module, "levellog.mod" will not be loaded.
[1-5-2011 12:27:33 : 16125] [ModuleAPI] Disabled module, "signaldisplay.mod" will not be loaded.
[1-5-2011 12:27:33 : 16125] [ModuleAPI] Disabled module, "simosd.mod" will not be loaded.
[1-5-2011 12:27:33 : 16125] [ModuleAPI] Disabled module, "streamrecorder.mod" will not be loaded.
[1-5-2011 12:27:33 : 16140] last channel
[1-5-2011 12:27:33 : 16140] GotoLastCh(chid:135)
"deleted piece because of maximum number of allowed characters which is 60000"
[1-5-2011 12:40:37 : 800172] >>>>: ---SetCh(chid:0)--------------------------------
[1-5-2011 12:40:37 : 800172] SetCh(): BeforeChChange:1
[1-5-2011 12:40:37 : 800172] SetCh(): BeforeChChange:2
[1-5-2011 12:40:37 : 800172] SetCh(): Start (chid:0)
[1-5-2011 12:40:38 : 800312] SetCh(): Channel: 12515,H,22000 @ 19.2° E "SBS6"
[1-5-2011 12:40:38 : 800312] SetCh(): Refresh ECM pids and PIP channels...
[1-5-2011 12:40:38 : 800312] SetCh(): Creating new thread...
[1-5-2011 12:40:38 : 800312] SetCh: Setting Diseqc...
[1-5-2011 12:40:38 : 800312] LOF1/LOFSW/LOF2:9750000/11700000/10600000 b22Khz:00
[1-5-2011 12:40:38 : 800344] SetCh: Setting tuner...
[1-5-2011 12:40:38 : 800344] SetCh: Setting tuner, resume thread...
[1-5-2011 12:40:38 : 800344] <<<<: SetCh Finish (12515,H,22000 - "SBS6")
[1-5-2011 12:40:38 : 800344] SetChThread: Start
[1-5-2011 12:40:38 : 800344] Same TP , no need to tune again CurrentTpInfo: 12515000, H, 22000000
[1-5-2011 12:40:38 : 800344] [TimeProfiler] AfterChChange: 0 ms
[1-5-2011 12:40:38 : 800344] Locked in 0 ms
[1-5-2011 12:40:38 : 800344] SetCh(): Tune Ok
[1-5-2011 12:40:38 : 800359] AfterChChange() C1
[1-5-2011 12:40:38 : 800359] AfterChChange() C4
[1-5-2011 12:40:38 : 800359] AfterChChange() C5
[1-5-2011 12:40:38 : 800359] Execute_AfterChannelChange() CHID: 0 "SBS6"
[1-5-2011 12:40:38 : 800359] AfterChChange() D2
[1-5-2011 12:40:38 : 800359] AfterChChange() D3
[1-5-2011 12:40:38 : 800359] AfterChChange() D4
[1-5-2011 12:40:38 : 800359] AfterChChange(): RefreshAudios()
[1-5-2011 12:40:38 : 800359] AfterChChange(): Finished
[1-5-2011 12:40:38 : 800359] [TimeProfiler] AfterChChange: 15 ms
[1-5-2011 12:40:38 : 800359] SetChThread: Finish
[1-5-2011 12:40:38 : 800469] bResetDS1:False 1 = 1 (ds_audio_type, new_audio_type)
[1-5-2011 12:40:38 : 800469] bResetDS2:False (bRadio <> (ds_video_type = VIDEOTYPE_NONE)
[1-5-2011 12:40:38 : 800469] bResetDS3:False 0 <> 0 (chl^.Channels[chid].VideoType <> ds_video_type)
[1-5-2011 12:40:53 : 816281] TVMouseUp() n^.ChId: 7
[1-5-2011 12:40:53 : 816281] TVDblClick()
[1-5-2011 12:40:53 : 816281] TVDblClick() n^.ChId: 7
[1-5-2011 12:40:53 : 816281] >>>>: ---SetCh(chid:7)--------------------------------
[1-5-2011 12:40:53 : 816281] SetCh(): BeforeChChange:1
[1-5-2011 12:40:53 : 816281] SetCh(): BeforeChChange:2
[1-5-2011 12:40:53 : 816281] SetCh(): Start (chid:7)
[1-5-2011 12:40:54 : 816359] SetCh(): Channel: 12515,H,22000 @ 19.2° E "NGC"
[1-5-2011 12:40:54 : 816359] SetCh(): Refresh ECM pids and PIP channels...
[1-5-2011 12:40:54 : 816359] SetCh(): Creating new thread...
[1-5-2011 12:40:54 : 816359] SetCh: Setting Diseqc...
[1-5-2011 12:40:54 : 816359] LOF1/LOFSW/LOF2:9750000/11700000/10600000 b22Khz:00
[1-5-2011 12:40:54 : 816406] SetCh: Setting tuner...
[1-5-2011 12:40:54 : 816406] SetCh: Setting tuner, resume thread...
[1-5-2011 12:40:54 : 816406] <<<<: SetCh Finish (12515,H,22000 - "NGC")
[1-5-2011 12:40:54 : 816406] SetChThread: Start
[1-5-2011 12:40:54 : 816406] Same TP , no need to tune again CurrentTpInfo: 12515000, H, 22000000
[1-5-2011 12:40:54 : 816406] [TimeProfiler] AfterChChange: 0 ms
[1-5-2011 12:40:54 : 816406] Locked in 0 ms
[1-5-2011 12:40:54 : 816406] SetCh(): Tune Ok
[1-5-2011 12:40:54 : 816422] AfterChChange() C1
[1-5-2011 12:40:54 : 816422] AfterChChange() C4
[1-5-2011 12:40:54 : 816422] AfterChChange() C5
[1-5-2011 12:40:54 : 816422] Execute_AfterChannelChange() CHID: 7 "NGC"
[1-5-2011 12:40:54 : 816422] AfterChChange() D2
[1-5-2011 12:40:54 : 816422] AfterChChange() D3
[1-5-2011 12:40:54 : 816422] AfterChChange() D4
[1-5-2011 12:40:54 : 816422] AfterChChange(): RefreshAudios()
[1-5-2011 12:40:54 : 816422] AfterChChange(): Finished
[1-5-2011 12:40:54 : 816422] [TimeProfiler] AfterChChange: 16 ms
[1-5-2011 12:40:54 : 816422] SetChThread: Finish
[1-5-2011 12:40:54 : 816531] bResetDS1:False 1 = 1 (ds_audio_type, new_audio_type)
[1-5-2011 12:40:54 : 816531] bResetDS2:False (bRadio <> (ds_video_type = VIDEOTYPE_NONE)
[1-5-2011 12:40:54 : 816531] bResetDS3:False 0 <> 0 (chl^.Channels[chid].VideoType <> ds_video_type)
[1-5-2011 12:41:52 : 874328] scan_front:s1
[1-5-2011 12:41:52 : 874344] TChScanThread.Execute;
[1-5-2011 12:41:52 : 874344] TChScanThread: bFirstScanForSat=False
[1-5-2011 12:41:52 : 874344] LOF1/LOFSW/LOF2:9750000/11700000/10600000 b22Khz:00
[1-5-2011 12:41:52 : 874344] SetDiseqc() Sw-Port:1 SwUncommitted:-1 DiseqcType:0
[1-5-2011 12:41:52 : 874344] [TimeProfiler] SetDiseqc: 0 ms
[1-5-2011 12:41:52 : 874344] Tuning 12343, H, 27500...
[1-5-2011 12:41:52 : 874547] Result of Tune() = 0 (LOCKED) in 203 ms
[1-5-2011 12:41:52 : 874562] Locked in 203 ms. Strength:65% Quality:91%
[1-5-2011 12:41:52 : 874672] PSI:---START--------------------------------------------
[1-5-2011 12:41:52 : 874672] PSI:StartParser...
[1-5-2011 12:41:57 : 880187] PSI:Parsing completed in 5515 ms. Found 38 channels:
[1-5-2011 12:41:57 : 880187] - 0) "RTL4" Video:512
[1-5-2011 12:41:57 : 880187] - 1) "RTL5" Video:513
[1-5-2011 12:41:57 : 880187] - 2) "RTL7" Video:518
[1-5-2011 12:41:57 : 880187] - 3) "RTL8" Video:519
[1-5-2011 12:41:57 : 880187] - 4) "Discovery" Video:515
[1-5-2011 12:41:57 : 880187] - 5) "Animal Planet" Video:514
[1-5-2011 12:41:57 : 880187] - 6) "EUROSPORT" Video:517
[1-5-2011 12:41:57 : 880187] - 7) "EUROSPORT CZ" Video:517
[1-5-2011 12:41:57 : 880187] - 8) "Veronica/DisneyXD" Video:521
[1-5-2011 12:41:57 : 880187] - 9) "Comedy Central/Kindernet" Video:520
[1-5-2011 12:41:57 : 880187] - 10) "Hustler TV" Video:526
[1-5-2011 12:41:57 : 880187] - 11) "Animax" Video:524
[1-5-2011 12:41:57 : 880187] - 12) "RTL RADIO" Video:0
[1-5-2011 12:41:57 : 880187] - 13) "RTL 1440" Video:0
[1-5-2011 12:41:57 : 880187] - 14) "RV info" Video:0
[1-5-2011 12:41:57 : 880187] - 15) "Radio Vlaanderen" Video:0
[1-5-2011 12:41:57 : 880187] - 16) "Mint" Video:0
[1-5-2011 12:41:57 : 880187] - 17) "Bel RTL" Video:0
[1-5-2011 12:41:57 : 880187] - 18) "Radio Contact" Video:0
[1-5-2011 12:41:57 : 880187] - 19) "Pure FM" Video:0
[1-5-2011 12:41:57 : 880187] - 20) "Classic21" Video:0
[1-5-2011 12:41:57 : 880187] - 21) "VivaCite" Video:0
[1-5-2011 12:41:57 : 880187] - 22) "Musiq 3" Video:0
[1-5-2011 12:41:57 : 880187] - 23) "La Premiere" Video:0
[1-5-2011 12:41:57 : 880187] - 24) "NL-Radio 1" Video:0
[1-5-2011 12:41:57 : 880187] - 25) "NL-Radio 2" Video:0
[1-5-2011 12:41:57 : 880187] - 26) "NL-3FM" Video:0
[1-5-2011 12:41:57 : 880187] - 27) "NL-Radio 4" Video:0
[1-5-2011 12:41:57 : 880187] - 28) "NL-Radio 5" Video:0
[1-5-2011 12:41:57 : 880187] - 29) "NL-Radio 6" Video:0
[1-5-2011 12:41:57 : 880187] - 30) "Arrow Classic Rock" Video:0
[1-5-2011 12:41:57 : 880187] - 31) "Arrow Jazz" Video:0
[1-5-2011 12:41:57 : 880187] - 32) "Kink FM" Video:0
[1-5-2011 12:41:57 : 880187] - 33) "Sky Radio" Video:0
[1-5-2011 12:41:57 : 880187] - 34) "538 Juize" Video:0
[1-5-2011 12:41:57 : 880187] - 35) "Radio538" Video:0
[1-5-2011 12:41:57 : 880187] - 36) "Radio10Gold" Video:0
[1-5-2011 12:41:57 : 880187] - 37) "Radio Veronica" Video:0
[1-5-2011 12:41:57 : 880187] PSI:---END--------------------------------------------
[1-5-2011 12:41:57 : 880187] UpdateChannels():Start
[1-5-2011 12:41:57 : 880187] UpdateChannels():2
[1-5-2011 12:41:57 : 880219] UpdateChannels():6
[1-5-2011 12:41:57 : 880234] bFirstScanForSat=False
[1-5-2011 12:41:59 : 881719] Tfscan.FormClose:1
[1-5-2011 12:41:59 : 881719] Tfscan.FormClose:2
[1-5-2011 12:42:01 : 883687] --LoadChannelsTree()---
[1-5-2011 12:42:01 : 883687] [TimeProfiler] LoadChannelsTree_GenFav(): 0 ms
[1-5-2011 12:42:01 : 883687] SelectLastCh:1
[1-5-2011 12:42:01 : 883687] SelectLastCh:2
[1-5-2011 12:42:01 : 883687] GotoLastCh(chid:7)
[1-5-2011 12:42:01 : 883687] >>>>: ---SetCh(chid:7)--------------------------------
[1-5-2011 12:42:01 : 883687] SetCh(): BeforeChChange:1
[1-5-2011 12:42:01 : 883687] SetCh(): BeforeChChange:2
[1-5-2011 12:42:01 : 883687] SetCh(): Start (chid:7)
[1-5-2011 12:42:01 : 883703] SetCh(): Channel: 12515,H,22000 @ 19.2° E "NGC"
[1-5-2011 12:42:01 : 883703] SetCh(): Refresh ECM pids and PIP channels...
[1-5-2011 12:42:01 : 883703] SetCh(): Creating new thread...
[1-5-2011 12:42:01 : 883703] SetCh: Setting Diseqc...
[1-5-2011 12:42:01 : 883703] LOF1/LOFSW/LOF2:9750000/11700000/10600000 b22Khz:00
[1-5-2011 12:42:01 : 883703] SetDiseqc() Sw-Port:1 SwUncommitted:-1 DiseqcType:0
[1-5-2011 12:42:01 : 883703] [TimeProfiler] SetDiseqc: 0 ms
[1-5-2011 12:42:01 : 883703] SetCh: Setting tuner...
[1-5-2011 12:42:01 : 883703] SetCh: Setting tuner, resume thread...
[1-5-2011 12:42:01 : 883703] <<<<: SetCh Finish (12515,H,22000 - "NGC")
[1-5-2011 12:42:01 : 883703] SetChThread: Start
[1-5-2011 12:42:01 : 883703] Tuning 12515, H, 22000...
[1-5-2011 12:42:01 : 883719] Tfscan.FormClose:3
[1-5-2011 12:42:01 : 883719] scan_front:s2
[1-5-2011 12:42:01 : 883734] scan_front:s3
[1-5-2011 12:42:01 : 883734] scan_front:s4
[1-5-2011 12:42:01 : 883906] Result of Tune() = 0 (LOCKED) in 203 ms
[1-5-2011 12:42:01 : 883906] [TimeProfiler] AfterChChange: 0 ms
[1-5-2011 12:42:01 : 883906] Locked in 203 ms
[1-5-2011 12:42:01 : 883906] SetCh(): Tune Ok
[1-5-2011 12:42:01 : 883922] AfterChChange() C1
[1-5-2011 12:42:01 : 883922] AfterChChange() C4
[1-5-2011 12:42:01 : 883922] AfterChChange() C5
[1-5-2011 12:42:01 : 883922] Execute_AfterChannelChange() CHID: 7 "NGC"
[1-5-2011 12:42:01 : 883922] AfterChChange() D2
[1-5-2011 12:42:01 : 883922] AfterChChange() D3
[1-5-2011 12:42:01 : 883922] AfterChChange() D4
[1-5-2011 12:42:01 : 883922] AfterChChange(): RefreshAudios()
[1-5-2011 12:42:01 : 883922] AfterChChange(): Finished
[1-5-2011 12:42:01 : 883922] [TimeProfiler] AfterChChange: 16 ms
[1-5-2011 12:42:01 : 883922] SetChThread: Finish
[1-5-2011 12:42:01 : 884031] bResetDS1:False 1 = 1 (ds_audio_type, new_audio_type)
[1-5-2011 12:42:01 : 884031] bResetDS2:False (bRadio <> (ds_video_type = VIDEOTYPE_NONE)
[1-5-2011 12:42:01 : 884031] bResetDS3:False 0 <> 0 (chl^.Channels[chid].VideoType <> ds_video_type)
[1-5-2011 12:42:02 : 885078] Tfscan_front.FormClose:1
[1-5-2011 12:42:02 : 885078] Tfscan_front.FormClose:2
[1-5-2011 12:42:02 : 885078] Tfscan_front.FormClose:3
[1-5-2011 12:42:02 : 885078] Tfscan_front.FormClose:4
[1-5-2011 12:42:12 : 894797] TVMouseUp() n^.ChId: 364
[1-5-2011 12:42:12 : 894797] TVDblClick()
[1-5-2011 12:42:12 : 894797] TVDblClick() n^.ChId: 364
[1-5-2011 12:42:12 : 894797] >>>>: ---SetCh(chid:364)--------------------------------
[1-5-2011 12:42:12 : 894828] SetCh(): BeforeChChange:1
[1-5-2011 12:42:12 : 894828] SetCh(): BeforeChChange:2
[1-5-2011 12:42:12 : 894828] SetCh(): Start (chid:364)
[1-5-2011 12:42:12 : 894953] SetCh(): Channel: 12343,H,27500 @ 19.2° E "Animal Planet"
[1-5-2011 12:42:12 : 894953] SetCh(): Refresh ECM pids and PIP channels...
[1-5-2011 12:42:12 : 894969] SetCh(): Creating new thread...
[1-5-2011 12:42:12 : 894969] SetCh: Setting Diseqc...
[1-5-2011 12:42:12 : 894969] LOF1/LOFSW/LOF2:9750000/11700000/10600000 b22Khz:00
[1-5-2011 12:42:12 : 894969] SetDiseqc() Sw-Port:1 SwUncommitted:-1 DiseqcType:0
[1-5-2011 12:42:12 : 894969] [TimeProfiler] SetDiseqc: 0 ms
[1-5-2011 12:42:12 : 895000] SetCh: Setting tuner...
[1-5-2011 12:42:12 : 895000] SetCh: Setting tuner, resume thread...
[1-5-2011 12:42:12 : 895000] <<<<: SetCh Finish (12343,H,27500 - "Animal Planet")
[1-5-2011 12:42:12 : 895000] SetChThread: Start
[1-5-2011 12:42:12 : 895000] Tuning 12343, H, 27500...
[1-5-2011 12:42:12 : 895203] Result of Tune() = 0 (LOCKED) in 203 ms
[1-5-2011 12:42:12 : 895203] [TimeProfiler] AfterChChange: 0 ms
[1-5-2011 12:42:12 : 895203] Locked in 203 ms
[1-5-2011 12:42:12 : 895203] SetCh(): Tune Ok
[1-5-2011 12:42:12 : 895219] AfterChChange() C1
[1-5-2011 12:42:12 : 895219] AfterChChange() C4
[1-5-2011 12:42:12 : 895219] AfterChChange() C5
[1-5-2011 12:42:12 : 895219] Execute_AfterChannelChange() CHID: 364 "Animal Planet"
[1-5-2011 12:42:12 : 895219] AfterChChange() D2
[1-5-2011 12:42:12 : 895219] AfterChChange() D3
[1-5-2011 12:42:12 : 895219] AfterChChange() D4
[1-5-2011 12:42:12 : 895219] AfterChChange(): RefreshAudios()
[1-5-2011 12:42:12 : 895219] AfterChChange(): Finished
[1-5-2011 12:42:12 : 895219] [TimeProfiler] AfterChChange: 16 ms
[1-5-2011 12:42:12 : 895219] SetChThread: Finish
[1-5-2011 12:42:13 : 895328] bResetDS1:False 1 = 1 (ds_audio_type, new_audio_type)
[1-5-2011 12:42:13 : 895328] bResetDS2:False (bRadio <> (ds_video_type = VIDEOTYPE_NONE)
[1-5-2011 12:42:13 : 895328] bResetDS3:False 0 <> 0 (chl^.Channels[chid].VideoType <> ds_video_type)
[1-5-2011 12:42:58 : 941078] TVMouseUp() n^.ChId: 8
[1-5-2011 12:42:58 : 941078] TVDblClick()
[1-5-2011 12:42:58 : 941078] TVDblClick() n^.ChId: 8
[1-5-2011 12:42:58 : 941078] >>>>: ---SetCh(chid:8)--------------------------------
[1-5-2011 12:42:58 : 941078] SetCh(): BeforeChChange:1
[1-5-2011 12:42:58 : 941078] SetCh(): BeforeChChange:2
[1-5-2011 12:42:58 : 941078] SetCh(): Start (chid:8)
[1-5-2011 12:42:58 : 941172] SetCh(): Channel: 12515,H,22000 @ 19.2° E "BVN"
[1-5-2011 12:42:58 : 941172] SetCh(): Refresh ECM pids and PIP channels...
[1-5-2011 12:42:58 : 941172] SetCh(): Creating new thread...
[1-5-2011 12:42:58 : 941172] SetCh: Setting Diseqc...
[1-5-2011 12:42:58 : 941172] LOF1/LOFSW/LOF2:9750000/11700000/10600000 b22Khz:00
[1-5-2011 12:42:58 : 941172] SetDiseqc() Sw-Port:1 SwUncommitted:-1 DiseqcType:0
[1-5-2011 12:42:58 : 941172] [TimeProfiler] SetDiseqc: 0 ms
[1-5-2011 12:42:58 : 941219] SetCh: Setting tuner...
[1-5-2011 12:42:58 : 941219] SetCh: Setting tuner, resume thread...
[1-5-2011 12:42:58 : 941219] <<<<: SetCh Finish (12515,H,22000 - "BVN")
[1-5-2011 12:42:58 : 941219] SetChThread: Start
[1-5-2011 12:42:58 : 941219] Tuning 12515, H, 22000...
[1-5-2011 12:42:59 : 941422] Result of Tune() = 0 (LOCKED) in 203 ms
[1-5-2011 12:42:59 : 941422] [TimeProfiler] AfterChChange: 0 ms
[1-5-2011 12:42:59 : 941422] Locked in 203 ms
[1-5-2011 12:42:59 : 941422] SetCh(): Tune Ok
[1-5-2011 12:42:59 : 941422] AfterChChange() C1
[1-5-2011 12:42:59 : 941422] AfterChChange() C4
[1-5-2011 12:42:59 : 941422] AfterChChange() C5
[1-5-2011 12:42:59 : 941422] Execute_AfterChannelChange() CHID: 8 "BVN"
[1-5-2011 12:42:59 : 941422] AfterChChange() D2
[1-5-2011 12:42:59 : 941422] AfterChChange() D3
[1-5-2011 12:42:59 : 941422] AfterChChange() D4
[1-5-2011 12:42:59 : 941422] AfterChChange(): RefreshAudios()
[1-5-2011 12:42:59 : 941422] AfterChChange(): Finished
[1-5-2011 12:42:59 : 941422] SetChThread: Finish
[1-5-2011 12:42:59 : 941531] bResetDS1:False 1 = 1 (ds_audio_type, new_audio_type)
[1-5-2011 12:42:59 : 941531] bResetDS2:False (bRadio <> (ds_video_type = VIDEOTYPE_NONE)
[1-5-2011 12:42:59 : 941531] bResetDS3:False 0 <> 0 (chl^.Channels[chid].VideoType <> ds_video_type)
[1-5-2011 12:43:25 : 967687] --LoadChannelsTree()---
[1-5-2011 12:43:25 : 967750] [TimeProfiler] LoadChannelsTree_GenFav(): 63 ms
[1-5-2011 12:43:25 : 967750] SelectLastCh:1
[1-5-2011 12:43:25 : 967750] SelectLastCh:2
[1-5-2011 12:43:25 : 967750] [TimeProfiler] ApplyChListSettings: 63 ms
[1-5-2011 12:43:31 : 974062] --LoadChannelsTree()---
[1-5-2011 12:43:31 : 974062] [TimeProfiler] LoadChannelsTree_GenFav(): 0 ms
[1-5-2011 12:43:31 : 974062] SelectLastCh:1
[1-5-2011 12:43:31 : 974062] SelectLastCh:2
[1-5-2011 12:43:31 : 974062] [TimeProfiler] ApplyChListSettings: 0 ms
[1-5-2011 12:43:33 : 976109] --LoadChannelsTree()---
[1-5-2011 12:43:33 : 976109] [TimeProfiler] LoadChannelsTree_GenFav(): 0 ms
[1-5-2011 12:43:33 : 976109] SelectLastCh:1
[1-5-2011 12:43:33 : 976109] SelectLastCh:2
[1-5-2011 12:43:33 : 976109] [TimeProfiler] ApplyChListSettings: 0 ms
[1-5-2011 12:43:33 : 976265] --LoadChannelsTree()---
[1-5-2011 12:43:33 : 976281] [TimeProfiler] LoadChannelsTree_GenFav(): 16 ms
[1-5-2011 12:43:33 : 976281] SelectLastCh:1
[1-5-2011 12:43:33 : 976281] SelectLastCh:2
[1-5-2011 12:43:33 : 976281] [TimeProfiler] ApplyChListSettings: 16 ms
[1-5-2011 12:43:35 : 978156] TVMouseUp() n^.ChId: 135
[1-5-2011 12:43:35 : 978156] TVDblClick()
[1-5-2011 12:43:35 : 978156] TVDblClick() n^.ChId: 135
[1-5-2011 12:43:35 : 978156] >>>>: ---SetCh(chid:135)--------------------------------
[1-5-2011 12:43:35 : 978156] SetCh(): BeforeChChange:1
[1-5-2011 12:43:35 : 978156] SetCh(): BeforeChChange:2
[1-5-2011 12:43:35 : 978156] SetCh(): Start (chid:135)
[1-5-2011 12:43:35 : 978156] SetCh(): Channel: 11856,V,27500 @ 23.5° E "NED1 HD"
[1-5-2011 12:43:35 : 978156] SetCh(): Refresh ECM pids and PIP channels...
[1-5-2011 12:43:35 : 978156] SetCh(): Creating new thread...
[1-5-2011 12:43:35 : 978156] SetCh: Setting Diseqc...
[1-5-2011 12:43:35 : 978156] LOF1/LOFSW/LOF2:9750000/11700000/10600000 b22Khz:00
[1-5-2011 12:43:37 : 979640] SetDiseqc() Sw-Port:1 SwUncommitted:-1 DiseqcType:0
[1-5-2011 12:43:37 : 979640] [TimeProfiler] SetDiseqc: 1484 ms
[1-5-2011 12:43:37 : 979640] SetCh: Setting tuner...
[1-5-2011 12:43:37 : 979640] SetCh: Setting tuner, resume thread...
[1-5-2011 12:43:37 : 979640] <<<<: SetCh Finish (11856,V,27500 - "NED1 HD")
[1-5-2011 12:43:37 : 979640] SetChThread: Start
[1-5-2011 12:43:37 : 979640] Tuning 11856, V, 27500...
[1-5-2011 12:43:38 : 980375] Result of Tune() = 0 (LOCKED) in 735 ms
[1-5-2011 12:43:38 : 980390] [TimeProfiler] AfterChChange: 0 ms
[1-5-2011 12:43:38 : 980390] Locked in 750 ms
[1-5-2011 12:43:38 : 980390] SetCh(): Tune Ok
[1-5-2011 12:43:38 : 980390] AfterChChange() C1
[1-5-2011 12:43:38 : 980390] AfterChChange() C4
[1-5-2011 12:43:38 : 980390] AfterChChange() C5
[1-5-2011 12:43:38 : 980390] Execute_AfterChannelChange() CHID: 135 "NED1 HD"
[1-5-2011 12:43:38 : 980390] AfterChChange() D2
[1-5-2011 12:43:38 : 980390] AfterChChange() D3
[1-5-2011 12:43:38 : 980390] AfterChChange() D4
[1-5-2011 12:43:38 : 980390] AfterChChange(): RefreshAudios()
[1-5-2011 12:43:38 : 980390] AfterChChange(): Finished
[1-5-2011 12:43:38 : 980390] SetChThread: Finish
[1-5-2011 12:43:38 : 980500] bResetDS1:True 1 = 2 (ds_audio_type, new_audio_type)
[1-5-2011 12:43:38 : 980500] bResetDS2:True (bRadio <> (ds_video_type = VIDEOTYPE_NONE)
[1-5-2011 12:43:38 : 980500] bResetDS3:True 2 <> 0 (chl^.Channels[chid].VideoType <> ds_video_type)
[1-5-2011 12:43:38 : 980500] RebuildDSafterChChange:False
[1-5-2011 12:43:38 : 980500] RDSC StartGraphAfterChChange
[1-5-2011 12:43:38 : 980500] >>>>: Reset_DirectShow ResetDirectShowPIP0
[1-5-2011 12:43:38 : 980500] >>>>: HidePip(chid:135)
[1-5-2011 12:43:38 : 980500] HidePip(hPIP:0) - ClearDSFilters
[1-5-2011 12:43:38 : 980500] HidePip(hPIP:0) - ds.free
[1-5-2011 12:43:38 : 980500] freemem(pips[0].VBuf)
[1-5-2011 12:43:38 : 980500] freemem(pips[0].ABuf)
[1-5-2011 12:43:38 : 980500] HidePip(hPIP:0) - DelFilters
[1-5-2011 12:43:38 : 980500] <<<<: HidePip(chid:135)
[1-5-2011 12:43:38 : 980500] >>>>: ShowPip(chid:135)
[1-5-2011 12:43:38 : 980531] DS:OK
[1-5-2011 12:43:38 : 980531] pips[0].ds.StartGraph;
[1-5-2011 12:43:38 : 980531] DSWindow:Refresh "Filters" menu...
[1-5-2011 12:43:38 : 980531] <<<<: ShowPip(chid:135)
[1-5-2011 12:43:38 : 980531] Restore volume
[1-5-2011 12:43:38 : 980531] <<<<: Reset_DirectShow
[1-5-2011 12:43:40 : 982797] WARNING: No Signal
[1-5-2011 12:43:41 : 983890] WARNING: No Signal
[1-5-2011 12:43:41 : 983890] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:43:42 : 984984] WARNING: No Signal
[1-5-2011 12:43:42 : 984984] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:43:43 : 986078] WARNING: No Signal
[1-5-2011 12:43:43 : 986078] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:43:44 : 987172] WARNING: No Signal
[1-5-2011 12:43:44 : 987172] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:43:45 : 988265] WARNING: No Signal
[1-5-2011 12:43:45 : 988265] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:43:47 : 989359] WARNING: No Signal
[1-5-2011 12:43:47 : 989359] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:43:48 : 990453] WARNING: No Signal
[1-5-2011 12:43:48 : 990453] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:43:49 : 991547] WARNING: No Signal
[1-5-2011 12:43:49 : 991547] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:43:50 : 992640] WARNING: No Signal
[1-5-2011 12:43:50 : 992640] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:43:51 : 993734] WARNING: No Signal
[1-5-2011 12:43:51 : 993734] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:43:52 : 994828] WARNING: No Signal
[1-5-2011 12:43:52 : 994828] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:43:53 : 995922] WARNING: No Signal
[1-5-2011 12:43:53 : 995922] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:43:54 : 997015] WARNING: No Signal
[1-5-2011 12:43:54 : 997015] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:43:55 : 998109] WARNING: No Signal
[1-5-2011 12:43:55 : 998109] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:43:56 : 999203] WARNING: No Signal
[1-5-2011 12:43:56 : 999203] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:43:58 : 1000297] WARNING: No Signal
[1-5-2011 12:43:58 : 1000297] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:43:59 : 1001390] WARNING: No Signal
[1-5-2011 12:43:59 : 1001390] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:44:00 : 1002484] WARNING: No Signal
[1-5-2011 12:44:00 : 1002484] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:44:01 : 1003578] WARNING: No Signal
[1-5-2011 12:44:01 : 1003578] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:44:02 : 1004672] WARNING: No Signal
[1-5-2011 12:44:02 : 1004672] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:44:03 : 1005765] WARNING: No Signal
[1-5-2011 12:44:03 : 1005765] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:44:04 : 1006859] WARNING: No Signal
[1-5-2011 12:44:04 : 1006859] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:44:05 : 1007953] WARNING: No Signal
[1-5-2011 12:44:05 : 1007953] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:44:06 : 1009047] WARNING: No Signal
[1-5-2011 12:44:06 : 1009047] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:44:07 : 1010140] WARNING: No Signal
[1-5-2011 12:44:07 : 1010140] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:44:08 : 1011234] WARNING: No Signal
[1-5-2011 12:44:08 : 1011234] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:44:10 : 1012328] WARNING: No Signal
[1-5-2011 12:44:10 : 1012328] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:44:11 : 1013422] WARNING: No Signal
[1-5-2011 12:44:11 : 1013422] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:44:12 : 1014515] WARNING: No Signal
[1-5-2011 12:44:12 : 1014515] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:44:13 : 1015609] WARNING: No Signal
[1-5-2011 12:44:13 : 1015609] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:44:14 : 1016703] WARNING: No Signal
[1-5-2011 12:44:14 : 1016703] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:44:15 : 1017797] WARNING: No Signal
[1-5-2011 12:44:15 : 1017797] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:44:16 : 1018890] WARNING: No Signal
[1-5-2011 12:44:16 : 1018890] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:44:17 : 1019984] WARNING: No Signal
[1-5-2011 12:44:17 : 1019984] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:44:18 : 1021078] WARNING: No Signal
[1-5-2011 12:44:18 : 1021078] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:44:19 : 1022172] WARNING: No Signal
[1-5-2011 12:44:19 : 1022172] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:44:20 : 1023265] WARNING: No Signal
[1-5-2011 12:44:20 : 1023265] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:44:22 : 1024359] WARNING: No Signal
[1-5-2011 12:44:22 : 1024359] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:44:23 : 1025453] WARNING: No Signal
[1-5-2011 12:44:23 : 1025453] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:44:24 : 1026547] WARNING: No Signal
[1-5-2011 12:44:24 : 1026547] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:44:25 : 1027640] WARNING: No Signal
[1-5-2011 12:44:25 : 1027640] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:44:26 : 1028734] WARNING: No Signal
[1-5-2011 12:44:26 : 1028734] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:44:27 : 1029828] WARNING: No Signal
[1-5-2011 12:44:27 : 1029828] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:44:28 : 1030922] WARNING: No Signal
[1-5-2011 12:44:28 : 1030922] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:44:29 : 1032015] WARNING: No Signal
[1-5-2011 12:44:29 : 1032015] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:44:30 : 1033062] TVMouseUp() n^.ChId: 88
[1-5-2011 12:44:30 : 1033062] TVDblClick()
[1-5-2011 12:44:30 : 1033062] TVDblClick() n^.ChId: 88
[1-5-2011 12:44:30 : 1033062] >>>>: ---SetCh(chid:88)--------------------------------
[1-5-2011 12:44:30 : 1033062] SetCh(): BeforeChChange:1
[1-5-2011 12:44:30 : 1033062] SetCh(): BeforeChChange:2
[1-5-2011 12:44:30 : 1033062] SetCh(): Start (chid:88)
[1-5-2011 12:44:30 : 1033062] SetCh(): Channel: 11739,V,27500 @ 23.5° E "NED2 HD"
[1-5-2011 12:44:30 : 1033062] SetCh(): Refresh ECM pids and PIP channels...
[1-5-2011 12:44:30 : 1033078] SetCh(): Creating new thread...
[1-5-2011 12:44:30 : 1033078] SetCh: Setting Diseqc...
[1-5-2011 12:44:30 : 1033078] LOF1/LOFSW/LOF2:9750000/11700000/10600000 b22Khz:00
[1-5-2011 12:44:30 : 1033078] SetDiseqc() Sw-Port:1 SwUncommitted:-1 DiseqcType:0
[1-5-2011 12:44:30 : 1033078] [TimeProfiler] SetDiseqc: 0 ms
[1-5-2011 12:44:30 : 1033078] SetCh: Setting tuner...
[1-5-2011 12:44:30 : 1033078] SetCh: Setting tuner, resume thread...
[1-5-2011 12:44:30 : 1033078] <<<<: SetCh Finish (11739,V,27500 - "NED2 HD")
[1-5-2011 12:44:30 : 1033078] SetChThread: Start
[1-5-2011 12:44:30 : 1033078] Tuning 11739, V, 27500...
[1-5-2011 12:44:35 : 1037484] Result of Tune() = 0 (LOCKED) in 4406 ms
[1-5-2011 12:44:35 : 1037484] [TimeProfiler] AfterChChange: 0 ms
[1-5-2011 12:44:35 : 1037484] Locked in 4406 ms
[1-5-2011 12:44:35 : 1037484] SetCh(): Tune Ok
[1-5-2011 12:44:35 : 1037500] AfterChChange() C1
[1-5-2011 12:44:35 : 1037500] AfterChChange() C4
[1-5-2011 12:44:35 : 1037500] AfterChChange() C5
[1-5-2011 12:44:35 : 1037500] Execute_AfterChannelChange() CHID: 88 "NED2 HD"
[1-5-2011 12:44:35 : 1037500] AfterChChange() D2
[1-5-2011 12:44:35 : 1037500] AfterChChange() D3
[1-5-2011 12:44:35 : 1037500] AfterChChange() D4
[1-5-2011 12:44:35 : 1037500] AfterChChange(): RefreshAudios()
[1-5-2011 12:44:35 : 1037500] AfterChChange(): Finished
[1-5-2011 12:44:35 : 1037500] [TimeProfiler] AfterChChange: 16 ms
[1-5-2011 12:44:35 : 1037500] SetChThread: Finish
[1-5-2011 12:44:35 : 1037609] bResetDS1:False 2 = 2 (ds_audio_type, new_audio_type)
[1-5-2011 12:44:35 : 1037609] bResetDS2:False (bRadio <> (ds_video_type = VIDEOTYPE_NONE)
[1-5-2011 12:44:35 : 1037609] bResetDS3:False 2 <> 2 (chl^.Channels[chid].VideoType <> ds_video_type)
[1-5-2011 12:45:18 : 1080890] TVMouseUp() n^.ChId: 226
[1-5-2011 12:45:18 : 1080890] TVDblClick()
[1-5-2011 12:45:18 : 1080890] TVDblClick() n^.ChId: 226
[1-5-2011 12:45:18 : 1080890] >>>>: ---SetCh(chid:226)--------------------------------
[1-5-2011 12:45:18 : 1080890] SetCh(): BeforeChChange:1
[1-5-2011 12:45:18 : 1080890] SetCh(): BeforeChChange:2
[1-5-2011 12:45:18 : 1080890] SetCh(): Start (chid:226)
[1-5-2011 12:45:18 : 1080890] SetCh(): Channel: 12129,V,27500 @ 23.5° E "NED3 HD"
[1-5-2011 12:45:18 : 1080890] SetCh(): Refresh ECM pids and PIP channels...
[1-5-2011 12:45:18 : 1080906] SetCh(): Creating new thread...
[1-5-2011 12:45:18 : 1080906] SetCh: Setting Diseqc...
[1-5-2011 12:45:18 : 1080906] LOF1/LOFSW/LOF2:9750000/11700000/10600000 b22Khz:00
[1-5-2011 12:45:18 : 1080906] SetDiseqc() Sw-Port:1 SwUncommitted:-1 DiseqcType:0
[1-5-2011 12:45:18 : 1080906] [TimeProfiler] SetDiseqc: 0 ms
[1-5-2011 12:45:18 : 1080906] SetCh: Setting tuner...
[1-5-2011 12:45:18 : 1080906] SetCh: Setting tuner, resume thread...
[1-5-2011 12:45:18 : 1080906] <<<<: SetCh Finish (12129,V,27500 - "NED3 HD")
[1-5-2011 12:45:18 : 1080906] SetChThread: Start
[1-5-2011 12:45:18 : 1080906] Tuning 12129, V, 27500...
[1-5-2011 12:45:22 : 1085219] Result of Tune() = 0 (LOCKED) in 4313 ms
[1-5-2011 12:45:22 : 1085219] [TimeProfiler] AfterChChange: 0 ms
[1-5-2011 12:45:22 : 1085219] Locked in 4313 ms
[1-5-2011 12:45:22 : 1085219] SetCh(): Tune Ok
[1-5-2011 12:45:22 : 1085234] AfterChChange() C1
[1-5-2011 12:45:22 : 1085234] AfterChChange() C4
[1-5-2011 12:45:22 : 1085234] AfterChChange() C5
[1-5-2011 12:45:22 : 1085234] Execute_AfterChannelChange() CHID: 226 "NED3 HD"
[1-5-2011 12:45:22 : 1085234] AfterChChange() D2
[1-5-2011 12:45:22 : 1085234] AfterChChange() D3
[1-5-2011 12:45:22 : 1085234] AfterChChange() D4
[1-5-2011 12:45:22 : 1085234] AfterChChange(): RefreshAudios()
[1-5-2011 12:45:22 : 1085234] AfterChChange(): Finished
[1-5-2011 12:45:22 : 1085234] [TimeProfiler] AfterChChange: 15 ms
[1-5-2011 12:45:22 : 1085234] SetChThread: Finish
[1-5-2011 12:45:23 : 1085344] bResetDS1:False 2 = 2 (ds_audio_type, new_audio_type)
[1-5-2011 12:45:23 : 1085344] bResetDS2:False (bRadio <> (ds_video_type = VIDEOTYPE_NONE)
[1-5-2011 12:45:23 : 1085344] bResetDS3:False 2 <> 2 (chl^.Channels[chid].VideoType <> ds_video_type)
[1-5-2011 12:45:32 : 1094969] TVMouseUp() n^.ChId: 135
[1-5-2011 12:45:32 : 1094969] TVDblClick()
[1-5-2011 12:45:32 : 1094969] TVDblClick() n^.ChId: 135
[1-5-2011 12:45:32 : 1094969] >>>>: ---SetCh(chid:135)--------------------------------
[1-5-2011 12:45:32 : 1094969] SetCh(): BeforeChChange:1
[1-5-2011 12:45:32 : 1094969] SetCh(): BeforeChChange:2
[1-5-2011 12:45:32 : 1094969] SetCh(): Start (chid:135)
[1-5-2011 12:45:32 : 1094969] SetCh(): Channel: 11856,V,27500 @ 23.5° E "NED1 HD"
[1-5-2011 12:45:32 : 1094969] SetCh(): Refresh ECM pids and PIP channels...
[1-5-2011 12:45:32 : 1094969] SetCh(): Creating new thread...
[1-5-2011 12:45:32 : 1094969] SetCh: Setting Diseqc...
[1-5-2011 12:45:32 : 1094969] LOF1/LOFSW/LOF2:9750000/11700000/10600000 b22Khz:00
[1-5-2011 12:45:32 : 1094969] SetDiseqc() Sw-Port:1 SwUncommitted:-1 DiseqcType:0
[1-5-2011 12:45:32 : 1094969] [TimeProfiler] SetDiseqc: 0 ms
[1-5-2011 12:45:32 : 1094969] SetCh: Setting tuner...
[1-5-2011 12:45:32 : 1094969] SetCh: Setting tuner, resume thread...
[1-5-2011 12:45:32 : 1094969] <<<<: SetCh Finish (11856,V,27500 - "NED1 HD")
[1-5-2011 12:45:32 : 1094969] SetChThread: Start
[1-5-2011 12:45:32 : 1094984] Tuning 11856, V, 27500...
[1-5-2011 12:45:36 : 1099281] Result of Tune() = 0 (LOCKED) in 4297 ms
[1-5-2011 12:45:36 : 1099281] [TimeProfiler] AfterChChange: 0 ms
[1-5-2011 12:45:36 : 1099281] Locked in 4312 ms
[1-5-2011 12:45:36 : 1099281] SetCh(): Tune Ok
[1-5-2011 12:45:37 : 1099297] AfterChChange() C1
[1-5-2011 12:45:37 : 1099297] AfterChChange() C4
[1-5-2011 12:45:37 : 1099297] AfterChChange() C5
[1-5-2011 12:45:37 : 1099297] Execute_AfterChannelChange() CHID: 135 "NED1 HD"
[1-5-2011 12:45:37 : 1099297] AfterChChange() D2
[1-5-2011 12:45:37 : 1099297] AfterChChange() D3
[1-5-2011 12:45:37 : 1099297] AfterChChange() D4
[1-5-2011 12:45:37 : 1099297] AfterChChange(): RefreshAudios()
[1-5-2011 12:45:37 : 1099297] AfterChChange(): Finished
[1-5-2011 12:45:37 : 1099297] [TimeProfiler] AfterChChange: 16 ms
[1-5-2011 12:45:37 : 1099297] SetChThread: Finish
[1-5-2011 12:45:37 : 1099406] bResetDS1:False 2 = 2 (ds_audio_type, new_audio_type)
[1-5-2011 12:45:37 : 1099406] bResetDS2:False (bRadio <> (ds_video_type = VIDEOTYPE_NONE)
[1-5-2011 12:45:37 : 1099406] bResetDS3:False 2 <> 2 (chl^.Channels[chid].VideoType <> ds_video_type)
[1-5-2011 12:45:44 : 1106797] --LoadChannelsTree()---
[1-5-2011 12:45:44 : 1106797] [TimeProfiler] LoadChannelsTree_GenFav(): 0 ms
[1-5-2011 12:45:44 : 1106797] SelectLastCh:1
[1-5-2011 12:45:44 : 1106797] SelectLastCh:2
[1-5-2011 12:45:44 : 1106797] [TimeProfiler] ApplyChListSettings: 0 ms
[1-5-2011 12:45:47 : 1109906] TVMouseUp() n^.ChId: 3
[1-5-2011 12:45:47 : 1109906] TVDblClick()
[1-5-2011 12:45:47 : 1109906] TVDblClick() n^.ChId: 3
[1-5-2011 12:45:47 : 1109906] >>>>: ---SetCh(chid:3)--------------------------------
[1-5-2011 12:45:47 : 1109906] SetCh(): BeforeChChange:1
[1-5-2011 12:45:47 : 1109906] SetCh(): BeforeChChange:2
[1-5-2011 12:45:47 : 1109906] SetCh(): Start (chid:3)
[1-5-2011 12:45:47 : 1109906] SetCh(): Channel: 12515,H,22000 @ 19.2° E "NED1"
[1-5-2011 12:45:47 : 1109906] SetCh(): Refresh ECM pids and PIP channels...
[1-5-2011 12:45:47 : 1109922] SetCh(): Creating new thread...
[1-5-2011 12:45:47 : 1109922] SetCh: Setting Diseqc...
[1-5-2011 12:45:47 : 1109922] LOF1/LOFSW/LOF2:9750000/11700000/10600000 b22Khz:00
[1-5-2011 12:45:49 : 1111390] SetDiseqc() Sw-Port:1 SwUncommitted:-1 DiseqcType:0
[1-5-2011 12:45:49 : 1111390] [TimeProfiler] SetDiseqc: 1468 ms
[1-5-2011 12:45:49 : 1111390] SetCh: Setting tuner...
[1-5-2011 12:45:49 : 1111390] SetCh: Setting tuner, resume thread...
[1-5-2011 12:45:49 : 1111390] <<<<: SetCh Finish (12515,H,22000 - "NED1")
[1-5-2011 12:45:49 : 1111390] SetChThread: Start
[1-5-2011 12:45:49 : 1111390] Tuning 12515, H, 22000...
[1-5-2011 12:45:52 : 1114547] Result of Tune() = 0 (LOCKED) in 3157 ms
[1-5-2011 12:45:52 : 1114562] [TimeProfiler] AfterChChange: 0 ms
[1-5-2011 12:45:52 : 1114562] Locked in 3172 ms
[1-5-2011 12:45:52 : 1114562] SetCh(): Tune Ok
[1-5-2011 12:45:52 : 1114562] AfterChChange() C1
[1-5-2011 12:45:52 : 1114562] AfterChChange() C4
[1-5-2011 12:45:52 : 1114562] AfterChChange() C5
[1-5-2011 12:45:52 : 1114562] Execute_AfterChannelChange() CHID: 3 "NED1"
[1-5-2011 12:45:52 : 1114562] AfterChChange() D2
[1-5-2011 12:45:52 : 1114562] AfterChChange() D3
[1-5-2011 12:45:52 : 1114562] AfterChChange() D4
[1-5-2011 12:45:52 : 1114562] AfterChChange(): RefreshAudios()
[1-5-2011 12:45:52 : 1114562] AfterChChange(): Finished
[1-5-2011 12:45:52 : 1114562] SetChThread: Finish
[1-5-2011 12:45:52 : 1114672] bResetDS1:True 2 = 1 (ds_audio_type, new_audio_type)
[1-5-2011 12:45:52 : 1114672] bResetDS2:True (bRadio <> (ds_video_type = VIDEOTYPE_NONE)
[1-5-2011 12:45:52 : 1114672] bResetDS3:True 0 <> 2 (chl^.Channels[chid].VideoType <> ds_video_type)
[1-5-2011 12:45:52 : 1114672] RebuildDSafterChChange:False
[1-5-2011 12:45:52 : 1114672] RDSC StartGraphAfterChChange
[1-5-2011 12:45:52 : 1114672] >>>>: Reset_DirectShow ResetDirectShowPIP0
[1-5-2011 12:45:52 : 1114672] >>>>: HidePip(chid:3)
[1-5-2011 12:45:52 : 1114672] HidePip(hPIP:0) - ClearDSFilters
[1-5-2011 12:45:52 : 1114672] HidePip(hPIP:0) - ds.free
[1-5-2011 12:45:52 : 1114672] freemem(pips[0].VBuf)
[1-5-2011 12:45:52 : 1114672] freemem(pips[0].ABuf)
[1-5-2011 12:45:52 : 1114672] HidePip(hPIP:0) - DelFilters
[1-5-2011 12:45:52 : 1114672] <<<<: HidePip(chid:3)
[1-5-2011 12:45:52 : 1114672] >>>>: ShowPip(chid:3)
[1-5-2011 12:45:52 : 1114687] DS:OK
[1-5-2011 12:45:52 : 1114687] pips[0].ds.StartGraph;
[1-5-2011 12:45:52 : 1114687] DSWindow:Refresh "Filters" menu...
[1-5-2011 12:45:52 : 1114703] <<<<: ShowPip(chid:3)
[1-5-2011 12:45:52 : 1114703] Restore volume
[1-5-2011 12:45:52 : 1114703] <<<<: Reset_DirectShow
[1-5-2011 12:45:58 : 1121031] --LoadChannelsTree()---
[1-5-2011 12:45:58 : 1121109] [TimeProfiler] LoadChannelsTree_GenFav(): 78 ms
[1-5-2011 12:45:58 : 1121109] SelectLastCh:1
[1-5-2011 12:45:58 : 1121109] SelectLastCh:2
[1-5-2011 12:45:58 : 1121109] [TimeProfiler] ApplyChListSettings: 78 ms
[1-5-2011 12:46:03 : 1126109] TVMouseUp() n^.ChId: 135
[1-5-2011 12:46:03 : 1126109] TVDblClick()
[1-5-2011 12:46:03 : 1126109] TVDblClick() n^.ChId: 135
[1-5-2011 12:46:03 : 1126109] >>>>: ---SetCh(chid:135)--------------------------------
[1-5-2011 12:46:03 : 1126109] SetCh(): BeforeChChange:1
[1-5-2011 12:46:03 : 1126109] SetCh(): BeforeChChange:2
[1-5-2011 12:46:03 : 1126109] SetCh(): Start (chid:135)
[1-5-2011 12:46:03 : 1126109] SetCh(): Channel: 11856,V,27500 @ 23.5° E "NED1 HD"
[1-5-2011 12:46:03 : 1126109] SetCh(): Refresh ECM pids and PIP channels...
[1-5-2011 12:46:03 : 1126125] SetCh(): Creating new thread...
[1-5-2011 12:46:03 : 1126125] SetCh: Setting Diseqc...
[1-5-2011 12:46:03 : 1126125] LOF1/LOFSW/LOF2:9750000/11700000/10600000 b22Khz:00
[1-5-2011 12:46:05 : 1127594] SetDiseqc() Sw-Port:1 SwUncommitted:-1 DiseqcType:0
[1-5-2011 12:46:05 : 1127594] [TimeProfiler] SetDiseqc: 1469 ms
[1-5-2011 12:46:05 : 1127594] SetCh: Setting tuner...
[1-5-2011 12:46:05 : 1127594] SetCh: Setting tuner, resume thread...
[1-5-2011 12:46:05 : 1127594] <<<<: SetCh Finish (11856,V,27500 - "NED1 HD")
[1-5-2011 12:46:05 : 1127594] SetChThread: Start
[1-5-2011 12:46:05 : 1127594] Tuning 11856, V, 27500...
[1-5-2011 12:46:06 : 1128328] Result of Tune() = 0 (LOCKED) in 734 ms
[1-5-2011 12:46:06 : 1128328] [TimeProfiler] AfterChChange: 0 ms
[1-5-2011 12:46:06 : 1128328] Locked in 734 ms
[1-5-2011 12:46:06 : 1128328] SetCh(): Tune Ok
[1-5-2011 12:46:06 : 1128344] AfterChChange() C1
[1-5-2011 12:46:06 : 1128344] AfterChChange() C4
[1-5-2011 12:46:06 : 1128344] AfterChChange() C5
[1-5-2011 12:46:06 : 1128344] Execute_AfterChannelChange() CHID: 135 "NED1 HD"
[1-5-2011 12:46:06 : 1128344] AfterChChange() D2
[1-5-2011 12:46:06 : 1128344] AfterChChange() D3
[1-5-2011 12:46:06 : 1128344] AfterChChange() D4
[1-5-2011 12:46:06 : 1128344] AfterChChange(): RefreshAudios()
[1-5-2011 12:46:06 : 1128344] AfterChChange(): Finished
[1-5-2011 12:46:06 : 1128344] [TimeProfiler] AfterChChange: 16 ms
[1-5-2011 12:46:06 : 1128344] SetChThread: Finish
[1-5-2011 12:46:06 : 1128453] bResetDS1:True 1 = 2 (ds_audio_type, new_audio_type)
[1-5-2011 12:46:06 : 1128453] bResetDS2:True (bRadio <> (ds_video_type = VIDEOTYPE_NONE)
[1-5-2011 12:46:06 : 1128453] bResetDS3:True 2 <> 0 (chl^.Channels[chid].VideoType <> ds_video_type)
[1-5-2011 12:46:06 : 1128453] RebuildDSafterChChange:False
[1-5-2011 12:46:06 : 1128453] RDSC StartGraphAfterChChange
[1-5-2011 12:46:06 : 1128453] >>>>: Reset_DirectShow ResetDirectShowPIP0
[1-5-2011 12:46:06 : 1128453] >>>>: HidePip(chid:135)
[1-5-2011 12:46:06 : 1128453] HidePip(hPIP:0) - ClearDSFilters
[1-5-2011 12:46:06 : 1128453] HidePip(hPIP:0) - ds.free
[1-5-2011 12:46:06 : 1128453] freemem(pips[0].VBuf)
[1-5-2011 12:46:06 : 1128453] freemem(pips[0].ABuf)
[1-5-2011 12:46:06 : 1128453] HidePip(hPIP:0) - DelFilters
[1-5-2011 12:46:06 : 1128453] <<<<: HidePip(chid:135)
[1-5-2011 12:46:06 : 1128453] >>>>: ShowPip(chid:135)
[1-5-2011 12:46:06 : 1128484] DS:OK
[1-5-2011 12:46:06 : 1128484] pips[0].ds.StartGraph;
[1-5-2011 12:46:06 : 1128484] DSWindow:Refresh "Filters" menu...
[1-5-2011 12:46:06 : 1128484] <<<<: ShowPip(chid:135)
[1-5-2011 12:46:06 : 1128484] Restore volume
[1-5-2011 12:46:06 : 1128484] <<<<: Reset_DirectShow
[1-5-2011 12:46:08 : 1130640] WARNING: No Signal
[1-5-2011 12:46:09 : 1131734] WARNING: No Signal
[1-5-2011 12:46:09 : 1131734] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:46:10 : 1132828] WARNING: No Signal
[1-5-2011 12:46:10 : 1132828] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:46:11 : 1133922] WARNING: No Signal
[1-5-2011 12:46:11 : 1133922] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:46:12 : 1135015] WARNING: No Signal
[1-5-2011 12:46:12 : 1135015] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:46:13 : 1136109] WARNING: No Signal
[1-5-2011 12:46:13 : 1136109] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:46:14 : 1137203] WARNING: No Signal
[1-5-2011 12:46:14 : 1137203] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:46:16 : 1138297] WARNING: No Signal
[1-5-2011 12:46:16 : 1138297] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:46:17 : 1139390] WARNING: No Signal
[1-5-2011 12:46:17 : 1139390] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:46:18 : 1140484] WARNING: No Signal
[1-5-2011 12:46:18 : 1140484] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:46:19 : 1141578] WARNING: No Signal
[1-5-2011 12:46:19 : 1141578] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:46:20 : 1142672] WARNING: No Signal
[1-5-2011 12:46:20 : 1142672] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:46:21 : 1143765] WARNING: No Signal
[1-5-2011 12:46:21 : 1143765] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:46:22 : 1144859] WARNING: No Signal
[1-5-2011 12:46:22 : 1144859] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:46:23 : 1145953] WARNING: No Signal
[1-5-2011 12:46:23 : 1145953] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:46:24 : 1147047] WARNING: No Signal
[1-5-2011 12:46:24 : 1147047] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:46:25 : 1148140] WARNING: No Signal
[1-5-2011 12:46:25 : 1148140] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:46:26 : 1149234] WARNING: No Signal
[1-5-2011 12:46:26 : 1149234] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:46:28 : 1150328] WARNING: No Signal
[1-5-2011 12:46:28 : 1150328] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:46:29 : 1151422] WARNING: No Signal
[1-5-2011 12:46:29 : 1151422] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:46:30 : 1152515] WARNING: No Signal
[1-5-2011 12:46:30 : 1152515] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:46:31 : 1153609] WARNING: No Signal
[1-5-2011 12:46:31 : 1153609] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:46:32 : 1154703] WARNING: No Signal
[1-5-2011 12:46:32 : 1154703] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:46:33 : 1155797] WARNING: No Signal
[1-5-2011 12:46:33 : 1155797] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:46:34 : 1156890] WARNING: No Signal
[1-5-2011 12:46:34 : 1156890] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:46:35 : 1157984] WARNING: No Signal
[1-5-2011 12:46:35 : 1157984] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:46:36 : 1159078] WARNING: No Signal
[1-5-2011 12:46:36 : 1159078] WARNING: No TS packets in the queue in last 1000 ms !
[1-5-2011 12:46:37 : 1159609] TVMouseUp() n^.ChId: 88
[1-5-2011 12:46:37 : 1159609] TVDblClick()
[1-5-2011 12:46:37 : 1159609] TVDblClick() n^.ChId: 88
[1-5-2011 12:46:37 : 1159609] >>>>: ---SetCh(chid:88)--------------------------------
[1-5-2011 12:46:37 : 1159609] SetCh(): BeforeChChange:1
[1-5-2011 12:46:37 : 1159609] SetCh(): BeforeChChange:2
[1-5-2011 12:46:37 : 1159609] SetCh(): Start (chid:88)
[1-5-2011 12:46:37 : 1159609] SetCh(): Channel: 11739,V,27500 @ 23.5° E "NED2 HD"
[1-5-2011 12:46:37 : 1159609] SetCh(): Refresh ECM pids and PIP channels...
[1-5-2011 12:46:37 : 1159609] SetCh(): Creating new thread...
[1-5-2011 12:46:37 : 1159609] SetCh: Setting Diseqc...
[1-5-2011 12:46:37 : 1159609] LOF1/LOFSW/LOF2:9750000/11700000/10600000 b22Khz:00
[1-5-2011 12:46:37 : 1159609] SetDiseqc() Sw-Port:1 SwUncommitted:-1 DiseqcType:0
[1-5-2011 12:46:37 : 1159609] [TimeProfiler] SetDiseqc: 0 ms
[1-5-2011 12:46:37 : 1159609] SetCh: Setting tuner...
[1-5-2011 12:46:37 : 1159609] SetCh: Setting tuner, resume thread...
[1-5-2011 12:46:37 : 1159609] <<<<: SetCh Finish (11739,V,27500 - "NED2 HD")
[1-5-2011 12:46:37 : 1159625] SetChThread: Start
[1-5-2011 12:46:37 : 1159625] Tuning 11739, V, 27500...
[1-5-2011 12:46:41 : 1163922] Result of Tune() = 0 (LOCKED) in 4297 ms
[1-5-2011 12:46:41 : 1163922] [TimeProfiler] AfterChChange: 0 ms
[1-5-2011 12:46:41 : 1163922] Locked in 4313 ms
[1-5-2011 12:46:41 : 1163922] SetCh(): Tune Ok
[1-5-2011 12:46:41 : 1163937] AfterChChange() C1
[1-5-2011 12:46:41 : 1163937] AfterChChange() C4
[1-5-2011 12:46:41 : 1163937] AfterChChange() C5
[1-5-2011 12:46:41 : 1163937] Execute_AfterChannelChange() CHID: 88 "NED2 HD"
[1-5-2011 12:46:41 : 1163937] AfterChChange() D2
[1-5-2011 12:46:41 : 1163937] AfterChChange() D3
[1-5-2011 12:46:41 : 1163937] AfterChChange() D4
[1-5-2011 12:46:41 : 1163937] AfterChChange(): RefreshAudios()
[1-5-2011 12:46:41 : 1163937] AfterChChange(): Finished
[1-5-2011 12:46:41 : 1163937] [TimeProfiler] AfterChChange: 15 ms
[1-5-2011 12:46:41 : 1163937] SetChThread: Finish
[1-5-2011 12:46:41 : 1164047] bResetDS1:False 2 = 2 (ds_audio_type, new_audio_type)
[1-5-2011 12:46:41 : 1164047] bResetDS2:False (bRadio <> (ds_video_type = VIDEOTYPE_NONE)
[1-5-2011 12:46:41 : 1164047] bResetDS3:False 2 <> 2 (chl^.Channels[chid].VideoType <> ds_video_type)
[1-5-2011 12:47:23 : 1205984] TVMouseUp() n^.ChId: 135
[1-5-2011 12:47:23 : 1205984] TVDblClick()
[1-5-2011 12:47:23 : 1205984] TVDblClick() n^.ChId: 135
[1-5-2011 12:47:23 : 1205984] >>>>: ---SetCh(chid:135)--------------------------------
[1-5-2011 12:47:23 : 1205984] SetCh(): BeforeChChange:1
[1-5-2011 12:47:23 : 1205984] SetCh(): BeforeChChange:2
[1-5-2011 12:47:23 : 1205984] SetCh(): Start (chid:135)
[1-5-2011 12:47:23 : 1205984] SetCh(): Channel: 11856,V,27500 @ 23.5° E "NED1 HD"
[1-5-2011 12:47:23 : 1205984] SetCh(): Refresh ECM pids and PIP channels...
[1-5-2011 12:47:23 : 1206000] SetCh(): Creating new thread...
[1-5-2011 12:47:23 : 1206000] SetCh: Setting Diseqc...
[1-5-2011 12:47:23 : 1206000] LOF1/LOFSW/LOF2:9750000/11700000/10600000 b22Khz:00
[1-5-2011 12:47:23 : 1206000] SetDiseqc() Sw-Port:1 SwUncommitted:-1 DiseqcType:0
[1-5-2011 12:47:23 : 1206000] [TimeProfiler] SetDiseqc: 0 ms
[1-5-2011 12:47:23 : 1206000] SetCh: Setting tuner...
[1-5-2011 12:47:23 : 1206000] SetCh: Setting tuner, resume thread...
[1-5-2011 12:47:23 : 1206000] <<<<: SetCh Finish (11856,V,27500 - "NED1 HD")
[1-5-2011 12:47:23 : 1206000] SetChThread: Start
[1-5-2011 12:47:23 : 1206000] Tuning 11856, V, 27500...
[1-5-2011 12:47:28 : 1210312] Result of Tune() = 0 (LOCKED) in 4312 ms
[1-5-2011 12:47:28 : 1210312] [TimeProfiler] AfterChChange: 0 ms
[1-5-2011 12:47:28 : 1210312] Locked in 4312 ms
[1-5-2011 12:47:28 : 1210312] SetCh(): Tune Ok
[1-5-2011 12:47:28 : 1210312] AfterChChange() C1
[1-5-2011 12:47:28 : 1210312] AfterChChange() C4
[1-5-2011 12:47:28 : 1210312] AfterChChange() C5
[1-5-2011 12:47:28 : 1210312] Execute_AfterChannelChange() CHID: 135 "NED1 HD"
[1-5-2011 12:47:28 : 1210312] AfterChChange() D2
[1-5-2011 12:47:28 : 1210312] AfterChChange() D3
[1-5-2011 12:47:28 : 1210312] AfterChChange() D4
[1-5-2011 12:47:28 : 1210312] AfterChChange(): RefreshAudios()
[1-5-2011 12:47:28 : 1210312] AfterChChange(): Finished
[1-5-2011 12:47:28 : 1210312] SetChThread: Finish
[1-5-2011 12:47:28 : 1210422] bResetDS1:False 2 = 2 (ds_audio_type, new_audio_type)
[1-5-2011 12:47:28 : 1210422] bResetDS2:False (bRadio <> (ds_video_type = VIDEOTYPE_NONE)
[1-5-2011 12:47:28 : 1210422] bResetDS3:False 2 <> 2 (chl^.Channels[chid].VideoType <> ds_video_type)
[edit] This is with driver 2.0.0.7 [/edit]
