2020 New Arrival TBS6304SE Quad HD HDMI Capture Card
TBS6304SE supports 4 x HDMI inputs ( max. input resolution 1080P 60fps) and H.264 hardware compression. You can use it inside MOI Pro AMD / MOI-V IPTV streaming server, TBS8510 IPTV transcoder, PC etc. for convering your HDMI sources to your IPTV/ broadcasting system etc.
Postby Jenny » Fri Sep 11, 2020 5:59 pm
Dear All,
Good day. Good news for you! :)
Now we release new arrival TBS6304SE Quad HD HDMI Capture Card for you. It supports 4 x HDMI inputs (max. input resolution 1920 x 1080 60fps) and H.264 hardware compression …
You can install TBS6304SE inside the MOI PRO AMD professional IPTV streaming server, MOI-V server or TBS8510 IPTV transcoder to covert the HDMI video into your IPTV/ broadcasting system etc.
(1) IPTV Servers
(2) Datacasting and monitoring
(3) Live TV capturing and streaming
(4) Broadcast TV
Benefits:
H.264 Hardware Compression with low CPU Consumption Solution
Equipped with an advanced built-in H.264 hardware encoder that enables the system not to utilise CPU's computing ability while maintaining high quality video encoding. This feature balances the load, thereby imporving the reliability of the system.
TBS6304SE Quad HD HDMI Capture Card is used as a DVB tuner system device, built-in a H.264 encoder with HDCP supported and provides adjustable resolution and bitrate options. You can easily apply it to IPTV streaming servers of headend systems.
4 x Real HDMI Digital Interface
TBS6304SE Quad HD HDMI Capture Card provides 4 HDMI inputs of the highest quality video. It meets the HDMI 1.4 standard and can be able to capture the LPCM audio signals.
TBS6304SE quad HD HDMI capture card with 4 x real HDMI digital inferface.jpg
Intuitive User Interface for Effective Management of TS Stream Outputs
TBS Pro Quad HD HDMI Capture Card supports automatically detecting the signal source. With TBS encoded setting tool, it can easily switch between channels and adjust configurations, offering better TV viewing experience.
Find more details here: https://www.tbsiptv.com/tbs6304se_quad_hd_hdmi_capture_card
Any interested in HDMI inputs to TS streams outputs solution, kindly e-mail us directly on sales@tbsdtv.com Our customer representative will revert to you shortly.
Best Regards,
TBS Team
E-mail: sales@tbsiptv.com
Tel+ : +86-755-26501345
TBS Technology
DVB Broadcast |Live TV Streaming |IPTV Head-end | OEM & ODM Solution
Jenny
Return to 2020 New Arrival TBS6304SE Quad HD HDMI Capture Card
