With CrazyScan, your Blindscan works crazily…GOOD!
Re: With CrazyScan, your Blindscan works crazily…GOOD!
Postby baber » Mon Aug 01, 2011 3:51 am
i install crazyscan but don't know how work wit it first j have to set my dish in a position?
then in crazyscan only press scan button?
i see a graph but don't understand from that
what do i have to do?
baber
Postby baber » Sun Aug 07, 2011 1:57 pm
hey. why don't anybody help me? about crazyscan
baber
Postby sotos65 » Sun Aug 07, 2011 4:49 pm
What is exactly the problem you have with CrazyScan? After you set the basic setup for the satellite you want to scan, you press the "Scan" button. Some seconds later CrazyScan presents you a spectrum graph with some peaks that represent the signal of the transponders of the satellite. If you click on the top of one such peak a new window starts that lets you blind scan this peak and find its characteristics (rf level, snr, ber, frequency, fec, modulation, bitrate, frequency width of the carrier, etc) when you press the little icon with the lens and the satellite. With the latest versions of crazyscan you may also perform streaming to VLC via a stream analyzer (e.g. TSReader) from this window, or dump (save) the transport stream in a file.
sotos65
Postby baber » Sun Aug 07, 2011 7:33 pm
what are basic setup for the satellite? i hace to only click on top of graph? can you put a pic step to step? i am very confused
thanks
baber
Postby sotos65 » Sun Aug 07, 2011 7:56 pm
Set your earth position (not really necessary, unless you use a motor with USAL commands), select your device (TBS 6925), type of LNB (Ku Linear for a typical Ku band setup), your diseqc 1.0/1.1 switch setup (if any) and/or your diseqc motor 1.2/ USALS setup. On satellite info you choose the satellite geostationary position you want to scan, name of satellite (in the screenshot 13E and Hotbird), frequency range you want to scan (10700 - 12750 for the whole Ku band) save your setup and press Scan.
sotos65
Postby sotos65 » Sun Aug 07, 2011 8:03 pm
I believe the following video will also help you,
http://www.youtube.com/watch?v=we6y-aTebxQ
sotos65
hosting
Postby Orenceacerbap » Sun Aug 07, 2011 8:52 pm
Orenceacerbap
Postby starman345 » Sun Aug 07, 2011 10:39 pm
http://rickcaylor.websitetoolbox.com/po ... ostcount=1
At the bottom of the post, download CrazyScanHelp.txt
10' dish- Bullseye II c/ku
55.5W to 139W
Windows 8.1 64 bit
TBS 8922 Prof 7301 TBS 6925
starman345
Postby baber » Mon Aug 08, 2011 10:08 pm
How can i select my sattelite? i have to write sattelite name? is it important select sattelite? how do i have to work with graph that finally get? in each place of grapgh that i click show a pic what do i have to do? i am very confused
baber
Postby SergioDanielG » Mon Aug 08, 2011 10:30 pm
baber wrote:How can i select my sattelite? i have to write sattelite name? is it important select sattelite? how do i have to work with graph that finally get? in each place of grapgh that i click show a pic what do i have to do? i am very confused
It's importan if you use a motorized antenna. If don't, It's doesn't necesary. But it's important select the correct diseqc port (if you use it)
SergioDanielG
PreviousNext
