TBS6925 V1 and V2
TBS6925 V1 and V2
Postby chputney » Fri Jul 29, 2011 3:10 pm
What is the difference between 6925 V1 and V2 ?
How do we tell if the card is V1 or V2 ?
Crazycat has said he has support for V2. Is V1 supported too ?
Charles
chputney
Re: TBS6925 V1 and V2
Postby steven » Fri Jul 29, 2011 3:47 pm
Hi chputney
TBS6925 V1 and V2 the difference is the Bridge, TBS6925 V1 are use CX23885, and TBS6925 V2 are use SAA7160ET,
Postby tempo » Sat Jul 30, 2011 3:09 am
TBS6925 V1 and V2 supported in CrazyCat's software, both versions.
tempo
Postby DVB » Sat Jul 30, 2011 5:13 am
TBS6925 V1 also using older cut (2.0) of STV0900 (STV0900AAB). In TBS6925 V2 there is updated STV0900AAC (cut 3.0) demod.
It is very easy to check actual card version. It is written on it's top side in corner. There should be V20, V21 or higher, which generally means that this is V2.
As far as I know TBS 6925 V1 were never in official sale, there are probably only few of these cards in betatesters/DX-ers hands ;) All cards that are now in stock (from beginning of sale in june) are TBS 6925 V2. :D
DVB
Postby crazycat » Tue Aug 09, 2011 5:39 am
but main diffrence - SAA7160ET PCI-E bridge in V2, instead CX23885 in V1.
