Frequent error / driver not detected
Postby dogman » Fri Sep 05, 2014 12:51 am
I am absolutely fed up with this card.
I frequently get the following when trying to use the card.
'Cannot initialize DVB hardware! ErrorCode:1
Application will work in offline mode.
Usually I can get it working again by uninstalling the card and the driver then reinstalling. Sometimes it would take a few attempts.
Today, I have done this many, many, many times and always the above error.
It doesn't seem to matter what driver I use but seems to be worst with the very latest driver, 1.0.23 or whatever it is.
Any advice please?
I am running windows 8.1 64 bit. When the card works, it is excellent but it is so temperamental and I have lost all my patience!
dogman
Re: Frequent error / driver not detected
Postby PetoBB » Wed Sep 10, 2014 12:54 pm
I have same problems with this cards, when use win 7 ultimate 64 bit. This problem showing on my first and second cards, where second card have as bonus artefacts on HD programs. Big trouble with professional TBS cards...
PetoBB
Postby dogman » Wed Sep 10, 2014 1:16 pm
It took me 3 days this time to get the card working again!
I powered down the computer totally, removing the plug.
Then rebooted after a few minutes and the card was detected again.
I am sick and tired of the problems I have had with this card so will not be buying another TBS card when this one finally dies!
dogman
Postby PetoBB » Wed Sep 10, 2014 10:02 pm
dogman, please visit this topic: viewtopic.php?f=25&t=7799&start=10
and test this channel 10E 11419 H 11815 JEEM HD. Do you have this artefacts? https://www.youtube.com/watch?v=hG2heFZzr6o
PetoBB
Postby dogman » Wed Sep 10, 2014 11:11 pm
Tested for a couple of minutes and I did NOT have that problem you mention.
Should I try a longer test?
I think I have seen something similar before with my card. It looks very familiar, but I cannot remember when or what channels were affected.
dogman
Postby PetoBB » Wed Sep 10, 2014 11:59 pm
No need a long test, artefacts show with my card anytime, and on any other commercial channels 13E 12478 H 29900 KBS WORLD HD, 13E 12476 H 29900 RT HD. My priority with this card is watch sports feed located od 7E, 10E, 16E etc., where this feeds have high bitrate and maybe 60% have artefacts, but few days ago card no showing this artefacts.... In this time card on second rma... i am waiting conclusion from buyer...
PetoBB
Postby dogman » Thu Sep 11, 2014 12:06 am
Is it not a codec problem?
I wish I could remember when and what channels I have seen this problem on.
I seem to recall that I fixed it by using a different codec, but I am fairly sure that there were a few occasions when I could not solve the problem no matter what codec I used.
If I encounter this again, I will make notes.
dogman
Postby PetoBB » Thu Sep 11, 2014 12:21 am
I am tested full week many codecs, TBS drivers, video rendering, dvb software (altDVD, DVBDream, dvbViewer and replaced card on second computer. Always same problems with artefacts, where azbox connect on same dish+lnb show problems channels without artefacts! I am say, few days ago with same configuration TBS run without artefacts.... my result is defect card :(
PetoBB
Postby dogman » Thu Sep 11, 2014 12:25 am
If you tried it on another computer then it does sound like the card is faulty.
dogman
Postby PetoBB » Thu Sep 11, 2014 12:26 am
Look on this video, same problems with artefacts:
https://www.youtube.com/watch?v=z54waQEBTKw
PetoBB
