Totaly a NewBie
Totaly a NewBie
Postby hazz » Mon Jan 06, 2014 8:46 pm
Happy new year to all of you.As mansioned on the subject,i'd like to know how can i use scan-s2 and all software that are available with the driver, are there any Tutorial around?.
The driver include the Astra.conf does anyone got the Hotbird.conf,if yes could you post it?.
I tried to installed Mythtv but i' encountered on some problem so i quited, i'm more confident with vlc i presume.
Does anyone of you tried the card with tcpdump if yes could you post your command line?Does anyone tried to view the TCP/IP protocol that comes from the Sattelite if yes how did you do that?
I know i'm to much newbaa
hazz
Re: Totaly a NewBie
Postby updatelee » Mon Jan 06, 2014 10:14 pm
I can only say I don't recommend vlc for tuning.
Not many satellites have a TCP/UDP network on them, more of an advanced topic.
