Drivers for 2.6.38 / Ubuntu 11.04
Postby grandmastermarclar » Sun Apr 10, 2011 11:52 pm
Any news of when these are likely to be available, for use with Ubuntu 11.04?
What about posting betas here? I'm happy to (electronically) sign any NDAs if needed, and provide any bug reports...
These drivers are the only thing holding me back from upgrading from 10.10.
grandmastermarclar
Re: Drivers for 2.6.38 / Ubuntu 11.04
Postby smv1210 » Tue Apr 19, 2011 2:39 pm
Check this topic trend, my Mythbuntu 11.04 B2 i386 (with many thanks to Andy Burns) does work as a charm now :D
https://shop.tbsdtv.com/forum/viewtopic.php?f=22&t=110&start=20#p1911
https://shop.tbsdtv.com/forum/viewtopic.php?f=22&t=110&start=20#p1913
https://shop.tbsdtv.com/forum/viewtopic.php?f=22&t=110&start=30#p1917
smv1210
Postby grandmastermarclar » Fri Apr 22, 2011 3:35 pm
I'd much prefer to be testing code heading towards the version that will eventually be released, not some clever patch that'll never be supported.
I've been involved in testing before, on an off for twenty years. It's easy enough to report defects, with all the supporting information the developers need. Depending on who you're dealing with they're usually prompt to respond with fixes and/or feedback.
TurboSight, how can I formally apply to be one of your external testers? Have you thought about running some kind of open beta testing programme...?
grandmastermarclar
Postby grandmastermarclar » Fri Apr 29, 2011 4:51 pm
Wakey wakey, TBS...
Ubuntu 11.04 is out. Officially. That means kernel 2.6.38. Now.
Where are your drivers? 32 and 64 bit?
From what I can tell, https://shop.tbsdtv.com/forum/viewtopic.php?f=22&t=110 has descended into unfathomable hackery.
I recall mention a couple of months back that TBS were about to release a DVB-T2 solution with linux support, and that they were to be updating all of their linux drivers to support 2.6.38.
ALL has gone quiet... Not even a progress report. Perhaps we should all go elsewhere, too?
grandmastermarclar
Postby eejit1 » Sat Apr 30, 2011 6:53 am
I found this thread while doing a web search for Ubuntu 11.04 drivers. When can we expect kernel 2.6.38 support? I only bought my TBS6920 six weeks ago. I sure hope there is on-going support.
- Tom
eejit1
Postby sema4 » Wed May 11, 2011 4:17 am
Successfully built and installed a TBS6980 using the patch presented by AndyBurns in the 6981 Linux forum on natty.
Much happier now.
sema4
Postby softnhard » Sun May 22, 2011 11:21 am
Take a look to http://blog.mohammadzadeh.info/index.php/step-by-step-guide-to for a complete guide on how to install.
softnhard
Postby stevellion » Tue May 24, 2011 4:53 am
The link posted above doesn't work on kernels past 2.6.35.
stevellion
Postby diglam » Tue May 24, 2011 12:38 pm
check this : http://www.tbsdtv.com/english/Download.html
new linux drivers have been released.
diglam
Postby veehexx » Wed May 25, 2011 12:24 am
awww that's awesome! the day my mythbuntu install dies, along come 11.04 (or rather the release 11.04 kernel) drivers! :D
thanks TBS, although it's a shame it's taken (imo) a considerable time to get them published with little info on even a rough ETA.
that said, i hope the delay has been down to a well polished release; I'd rather one stable release than a load of releases that are buggy.
veehexx
