BlueScreen
BlueScreen
Postby ahmedghazi » Tue Jul 29, 2014 2:01 pm
Dear sir,
I have many technical problems since I bought and installed the software device, and the technical supporter doesn't respond to my questions. For example after installed software and restart the system a blue screen appears to my screen. I'm using windows 8.1 64bit. I installed (TBS5980 Windows Driver V1.0.3.0) from your website, and the box was connecting when I installed the software, and the software driver caused blue screen in my system even with or without connecting the device, and I'm using USB2 port. So I need your help.
Regards
ahmedghazi
Re: BlueScreen
Postby Metinolmetin » Fri Dec 25, 2015 9:27 pm
Bu ürünü 30 Nisan 2015' tarihinde sitenizden satın aldım. İşlerimin yoğunluğundan ötürü ürünü, yeni kullanmaya başladım. DVB Dream2.7.4 & DVBViewer pro 5.3.2 Windows 7 SP1 64 bit desktop sistemim de ve Windows 8.1 64 bit laptop sistemim de TBS5980 kart kullanırken bir süre sonra mavi ekran (Bluescreen) hatası veriyor. Ürün ile ilgili çıkmış olan eski ve en güncel donanım sürücülerini denedim, aynı şikyetim devam ediyor. Ürünü bu şekilde kullanmak mümkün değil malesef. :( Çözüm önerilerinizi bekliyorum teşekkürler.
Google Translate:
This product April 30, 2015 Google bought your site. Due to the intensity of my work product, I began to use the new. DVB Dream2.7.4 & DVBViewer Pro 5.3.2 Windows 7 SP1 64-bit desktop systems and Windows 8.1 64-bit laptop system I'm also using a blue screen after a while TBS5980 card (Bluescreen) gives an error. I tried the old and the latest hardware drivers that came on the product, but I şikyet continues. Product is unfortunately not possible to use in this way. :( Solution Waiting for your suggestions, thank you.
Metinolmetin
Re: BlueScreen
Postby Metinolmetin » Sat Dec 26, 2015 5:55 am
Edirne Türkiye'den selamlar. Mavi ekran sorunu için kimse cevap vermiyormu?
Greetings from Turkey Edirne. No one replied to a blue screen problem?
Metinolmetin
