Hi, Is there possible support for the higher kernels numbers?
Just received my QBox CI and during compilation (kernel 3.0rc6) I have objects error:
make -C /home/piotr/bin/TBS/linux-tbs-sources_110531/linux-tbs-sources/v4l
make[1]: Wejście do katalogu `/home/piotr/bin/TBS/linux-tbs-sources_110531/linux-tbs-sources/v4l'
creating symbolic links...
make -C firmware prep
make[2]: Entering directory `/home/piotr/bin/TBS/linux-tbs-sources_110531/linux-tbs-sources/v4l/firmware'
make[2]: Leaving directory `/home/piotr/bin/TBS/linux-tbs-sources_110531/linux-tbs-sources/v4l/firmware'
make -C firmware
make[2]: Nothing to be done for `default'.
Kernel build directory is /lib/modules/3.0.0-rc6-full/build
make -C /lib/modules/3.0.0-rc6-full/build SUBDIRS=/home/piotr/bin/TBS/linux-tbs-sources_110531/linux-tbs-sources/v4l CFLAGS="-I../linux/include -D__KERNEL__ -I/include -DEXPORT_SYMTAB" modules
make[2]: Entering directory `/usr/src/linux-3.0-rc6'
CC [M] /home/piotr/bin/TBS/linux-tbs-sources_110531/linux-tbs-sources/v4l/tuner-xc2028.o
/home/piotr/bin/TBS/linux-tbs-sources_110531/linux-tbs-sources/v4l/tuner-xc2028.c: In function 'xc2028_set_params':
/home/piotr/bin/TBS/linux-tbs-sources_110531/linux-tbs-sources/v4l/tuner-xc2028.c:1178: error: 'T_DIGITAL_TV' undeclared (first use in this function)
/home/piotr/bin/TBS/linux-tbs-sources_110531/linux-tbs-sources/v4l/tuner-xc2028.c:1178: error: (Each undeclared identifier is reported only once
/home/piotr/bin/TBS/linux-tbs-sources_110531/linux-tbs-sources/v4l/tuner-xc2028.c:1178: error: for each function it appears in.)
make[3]: *** [/home/piotr/bin/TBS/linux-tbs-sources_110531/linux-tbs-sources/v4l/tuner-xc2028.o] Błąd 1
make[2]: *** [_module_/home/piotr/bin/TBS/linux-tbs-sources_110531/linux-tbs-sources/v4l] Error 2
make[2]: Leaving directory `/usr/src/linux-3.0-rc6'
make[1]: *** [default] Błąd 2
make[1]: Opuszczenie katalogu `/home/piotr/bin/TBS/linux-tbs-sources_110531/linux-tbs-sources/v4l'
make: *** [all] Błąd 2
In a midtime I'm making egg 2.38.8 :-)
