Installing Driver in CentOS 6.3
Postby wannabe » Sun Jan 20, 2013 3:46 pm
Hello
Anyone can help me please, i want to install driver for tbs 6984 quad tuner but i can't.
i have been following the install manual but dont work for me:
I.1 extract linux-tbs-drivers.tar.bz2 archive:
# tar xjvf linux-tbs-drivers.tar.bz2
I.2 go to driver package directory:
# cd linux-tbs-drivers
I.3 depending on your kernel version and if the kernel is x86 or
x86_64 (check output of 'uname -a') do:
- for x86 kernel 3.x (x86 32 bit installations of kernel 3.x):
# ./v4l/tbs-x86_r3.sh
- for x86 kernel 2.6.x (x86 32 bit installations of kernel 2.6.x):
# ./v4l/tbs-x86.sh
- for any x86_64 kernel (x86 64 bit installations of Linux):
# ./v4l/tbs-x86_64.sh
I.3 build and install the driver:
# make && make install
I.4 reboot in order to load the newly installed driver:
# shutdown -r now
I use kernel 2.6.32-279, and my Os is x86_64
when type make & make install then show me the next error:
[[email protected] linux-tbs-drivers]# ./v4l/tbs-x86_64.sh
[[email protected] linux-tbs-drivers]# make && make install
make -C /linux-tbs-drivers/v4l
make[1]: se ingresa al directorio `/linux-tbs-drivers/v4l'
Updating/Creating .config
Preparing to compile for kernel version 2.6.32
File not found: /lib/modules/2.6.32-279.el6.x86_64/build/.config at ./scripts/make_kconfig.pl line 33, <IN> line 4.
make[1]: *** No hay ninguna regla para construir el objetivo `.myconfig', necesario para `config-compat.h'. Alto.
make[1]: se sale del directorio `/linux-tbs-drivers/v4l'
make: *** [all] Error 2
wannabe
Re: Installing Driver in CentOS 6.3
Postby SergioDanielG » Sun Jan 20, 2013 10:28 pm
Hi wannabe
Can you try running "make clean" and "make distclean" (or "make dist-clean") before any installation step?
Best regards.
SergioDanielG
Postby updatelee » Mon Jan 21, 2013 12:54 am
I believe the problem is if I understand correctly there are only three possible setups with TBS
2.6 32bit
3.x 32bit
3.x 64bit
your attempting todo 2.6 64bit there is no precompiled lib for that
[email protected]:~/src/stv090x-scan$ file ../tbs/tbs-drivers-v121119/linux-tbs-drivers/v4l/tbs6925ctrl_driver.o.x86
../tbs/tbs-drivers-v121119/linux-tbs-drivers/v4l/tbs6925ctrl_driver.o.x86: ELF 32-bit LSB relocatable, Intel 80386, version 1 (SYSV), not stripped
[email protected]:~/src/stv090x-scan$ file ../tbs/tbs-drivers-v121119/linux-tbs-drivers/v4l/tbs6925ctrl_driver.o.x86_64
../tbs/tbs-drivers-v121119/linux-tbs-drivers/v4l/tbs6925ctrl_driver.o.x86_64: ELF 64-bit LSB relocatable, x86-64, version 1 (SYSV), not stripped
[email protected]:~/src/stv090x-scan$ file ../tbs/tbs-drivers-v121119/linux-tbs-drivers/v4l/tbs6925ctrl_driver.o.x86_r3
../tbs/tbs-drivers-v121119/linux-tbs-drivers/v4l/tbs6925ctrl_driver.o.x86_r3: ELF 32-bit LSB relocatable, Intel 80386, version 1 (SYSV), not stripped
the 6984 is the same, just look in the TBS folder /v4l
Postby wannabe » Mon Jan 21, 2013 2:35 am
Hello
using the command make dist-clean show me the next error:
[[email protected] linux-tbs-drivers]# make dist-clean
make -C /linux-tbs-drivers/v4l dist-clean
make[1]: *** No hay ninguna regla para construir el objetivo `dist-clean'. Alto.
make: *** [dist-clean] Error 2
wannabe
Postby SergioDanielG » Mon Jan 21, 2013 8:13 am
wannabe wrote:Hello
Hi wannabe
Don't worry for that. I doesn't remember if the command was distclean or dist-clean.
Now I confirm, the command is "distclean"
Well, did you try running "make clean" and "make distclean" before all TBS installation steps?
Best regards
SergioDanielG
Postby wannabe » Mon Jan 21, 2013 8:26 am
SergioDanielG wrote:
wannabe wrote:Hello
Hi wannabe
Best regards
:( use the commad but still the same error :(
No version yet, using 2.6.32-279.el6.x86_64
scripts/make_makefile.pl
wannabe
Postby updatelee » Mon Jan 21, 2013 12:55 pm
well you havent done a make menuconfig thats why there is no .config
still dont think it'll work though, upgrade your kernel and it should work fine
Postby wannabe » Mon Jan 21, 2013 12:59 pm
updatelee wrote:well you havent done a make menuconfig thats why there is no .config
Hello updatelee
can you tell me how upgrade the kernel?
wannabe
Postby updatelee » Tue Jan 22, 2013 3:17 am
in Ubuntu its as simple as opening software manager and clicking 'check for updates'. I have no idea in CentOS Im sure they have a forum or something though.
Postby SergioDanielG » Tue Jan 22, 2013 8:44 am
Hi wannabe
In CentOS, update kernel it's not so easy as in Ubuntu, but there are a lot of documentation.
Refer to chapter 39 of "
Red Hat Enterprise Linux Deployment Guide" http://www.centos.org/docs/5/html/Deplo ... ation.html
But, if is not a problem for you, update your kernel and centos distribution with "yum update"
Best regards
SergioDanielG
