LOCK Problems
Re: LOCK Problems
Postby winger » Sat Mar 10, 2012 2:40 pm
[email protected]:~# dvbsnoop -s feinfo -adapter 4
dvbsnoop V1.4.50 -- http://dvbsnoop.sourceforge.net/
FrontEnd Info...
Device: /dev/dvb/adapter4/frontend0
Basic capabilities:
Name: "TurboSight TBS 6984 DVBS/S2 frontend"
Frontend-type: QPSK (DVB-S)
Frequency (min): 950.000 MHz
Frequency (max): 2150.000 MHz
Frequency stepsiz: 1.011 MHz
Frequency tolerance: 5.000 MHz
Symbol rate (min): 1.000000 MSym/s
Symbol rate (max): 45.000000 MSym/s
Symbol rate tolerance: 0 ppm
Notifier delay: 0 ms
Frontend capabilities:
auto inversion
FEC 1/2
FEC 2/3
FEC 3/4
FEC 4/5
FEC 5/6
FEC 6/7
FEC 7/8
FEC AUTO
QPSK
Current parameters:
Frequency: 1702.992 MHz
Inversion: OFF
Symbol rate: 26.400000 MSym/s
FEC: FEC AUTO
I have bind my skystar2 adapters in udev. So they have number from 0 to 2, and tbs have number 3-6. adapter 4 is a second tuner on tbs 6984!
winger
Re: LOCK Problems
Postby SergioDanielG » Sat Mar 10, 2012 9:29 pm
winger wrote:I have bind my skystar2 adapters in udev. So they have number from 0 to 2, and tbs have number 3-6. adapter 4 is a second tuner on tbs 6984!
Well, if you are sure that the second adapter it's failing, and it fail with all transponder, maybe something wrong with the card and, Maybe you can email to TBS support.
Best regards.
SergioDanielG
Re: LOCK Problems
Postby winger » Sun Mar 11, 2012 5:28 pm
TBS 6984 working on PCI-Ex16? Or in PCI-Ex1 only? I bay second card and install it to PCI-Ex16 and work only one tuner from that card! I do something wrong or all TBS product work like that????!!???
winger
Re: LOCK Problems
Postby SergioDanielG » Mon Mar 12, 2012 11:13 am
winger wrote:TBS 6984 working on PCI-Ex16? Or in PCI-Ex1 only? I bay second card and install it to PCI-Ex16 and work only one tuner from that card! I do something wrong or all TBS product work like that????!!???
A pci-e 1x card (any card) work in pci-e 1x slot, 4x slot, 8xslot and 16x slot. But in same motherboards, the pci-e is shared. For example form user manual of my motherboard GIGABYTE GA-890FXA-UD5
Code: Select all
    The PCIEX8 slot shares bandwidth with the PCIEX16_1 slot. When PCIEX8 is populated with a PCI
Express graphics card, the PCIEX16_1 slot will operate at up to x8 mode.
    Whether the CPU/system fan speed control function is supported will depend on the CPU/system
I'm actually using tbs cards un pci-e 1x slot and 16x slot without problems.
Best regards.
SergioDanielG
Re: LOCK Problems
Postby winger » Sat Mar 17, 2012 5:02 pm
I have another problem with card.... Now I have two TBS 6984 in my server. One of them is working fine.... (but one adapter from four still not work). The second card working some hours from the reboot, after that time she has NO LOCK. I need to reboot PC and all is fine some next hours.... adn again and again.....
scan-s2 says in that moment :
>>> tune to: 11881:hC34M2O35S0:S0.0W:27500:
DVB-S IF freq is 1131000
WARNING: filter timeout pid 0x0010
dumping lists (0 services)
Done.
szap-s2 :
status 01 | signal 74% | snr 0% | ber 0 | unc 0 |
NO LOCK.....
Help....
winger
Previous
