Remote control problem - driver 1.0.0.5
Re: Remote control problem - driver 1.0.0.5
Postby tonewheelkev » Tue Feb 14, 2012 7:41 am
Please tell me if TBS(6922) remote is referenced on this list:
http://lirc.sourceforge.net/remotes/
tonewheelkev
Postby steven » Thu Feb 16, 2012 9:59 am
Hi tonewheelkev
TBS remote is not direct supported,you need to config every shortcut key with MediaPortal.
Later we will make a config for you. :)
Postby tonewheelkev » Fri Feb 17, 2012 2:59 am
steven wrote:Hi tonewheelkev
.............Later we will make a config for you. :)
....Many thanks!!
tonewheelkev
Postby steven » Tue Feb 21, 2012 2:45 pm
Hi tonewheelkev
Sorry for the delay reply,and here is the new version of TBSVHID which have added MediaPortal profile.
And i have contact the remote support with MediaPortal,Maybe later you can direct use remote with MediaPortal.
Here is the linker:
http://hotfile.com/dl/147271866/288254a/Setup_TBSVHID(1.0.0.4)_new.zip.html
Postby tonewheelkev » Tue Feb 21, 2012 5:24 pm
Thank you for this Steven.....will have a go later!!
Kev
tonewheelkev
Postby steven » Mon Mar 12, 2012 9:10 am
Sorry for the dely reply.
We are contacting this with MediaPort now, Before this can you use VHID first if have any progress ,we will
contact you as soon as possible.
Previous
