Kaffeine and TBS 6922SE
Postby eelstrebor » Thu Jan 12, 2017 1:42 am
I'm using a TBS 6922SE with Kaffeine and ran into an interesting problem. I'm not sure if it's a problem with the TBS driver or with Kaffeine. What happens is that when I scan SES1 at 101.0 W, I get a "hit" on Decades (3957 V 2734) and on MeTV (3725 V 10000) but I can't add both of them to the channel list. When I select both of them to be added, only one will end up in the channel list. When I select them one at a time such as MeTV and then Decades, MeTV disappears. If I select Decades first and then MeTV, Decades disappears. Is this a bug in Kaffeine or the TBS driver?
[email protected]:~$ uname -a
Linux server2 4.8.15-040815-generic #201612151231 SMP Thu Dec 15 17:33:37 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
[email protected]:~$ dmesg | grep tbs
[ 17.686360] tbs6290fe: module license 'TurboSight Proprietary' taints kernel.
[ 18.012653] Registered IR keymap rc-tbs-nec
[email protected]:~$ dmesg | grep dvb
[ 18.012924] DVB: registering new adapter (SAA716x dvb adapter)
[email protected]:~$ dmesg | grep Turbo
[ 18.012713] input: saa716x IR (TurboSight TBS 6923) as /devices/pci0000:00/0000:00:1c.6/0000:05:00.0/rc/rc0/input10
[ 18.012777] rc0: saa716x IR (TurboSight TBS 6923) as /devices/pci0000:00/0000:00:1c.6/0000:05:00.0/rc/rc0
[ 18.504673] TurboSight TBS 6923 Frontend Attaching...
[ 18.735584] TurboSight TBS6923 DVB-S2 card MAC=00:22:ab:e0:58:04
[ 18.735586] DVB: registering adapter 0 frontend 0 (TurboSight TBS 6923 DVBS/S2 frontend)...
tbs-linux-drivers_v161031.zip
kaffeine 1.2.2-3
Ubuntu 16.04.1
eelstrebor
Re: Kaffeine and TBS 6922SE
Postby Alfredo » Sat Feb 04, 2017 9:23 am
I have the same problem. I thinks is problem of kaffeine.
Regards
Alfredo
