Card can't be accessed
Postby Neula » Sun Mar 09, 2014 9:01 pm
Driver installation for this card went just fine and the device show up too, but somehow it can't be detected by tvheadend nor any other programms. I'm running fedora20 see relevant dmesg snippet below.
Code: Select all
 [ 4.033333] TurboSight TBS 6922 Frontend Attaching... [ 4.083348] TurboSight TBS6922 DVB-S2 card MAC=00:22:ab:e0:3b:5f [ 4.083355] SAA716x TBS 0000:02:00.0: DVB: registering adapter 0 frontend 947400765 (TurboSight TBS 6922 DVBS/S2 frontend)... [ 4.690231] systemd-journald[310]: Received request to flush runtime journal from PID 1 [ 4.693285] systemd-journald[310]: File /var/log/journal/5ab163d87efd4414bde7230b83ccd480/system.journal corrupted or uncleanly shut down, renaming and replacing. [ 4.704443] type=1305 audit(1394368655.349:4): audit_pid=493 old=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:auditd_t:s0 res=1 [ 5.308604] nf_conntrack version 0.5.0 (16384 buckets, 65536 max) [ 5.328950] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 5.390780] Ebtables v2.0 registered [ 5.439858] Bridge firewalling registered [ 5.785687] r8169 0000:03:00.0 p19p1: link down [ 5.785707] r8169 0000:03:00.0 p19p1: link down [ 5.785746] IPv6: ADDRCONF(NETDEV_UP): p19p1: link is not ready [ 6.128931] [drm:dce6_afmt_write_speaker_allocation] *ERROR* Couldn't read Speaker Allocation Data Block: 0 [ 6.573765] systemd-journald[310]: File /var/log/journal/5ab163d87efd4414bde7230b83ccd480/user-42.journal corrupted or uncleanly shut down, renaming and replacing. [ 7.314584] r8169 0000:03:00.0 p19p1: link up [ 7.314600] IPv6: ADDRCONF(NETDEV_CHANGE): p19p1: link becomes ready [ 8.498385] kernel tried to execute NX-protected page - exploit attempt? (uid: 1001) [ 8.498422] BUG: unable to handle kernel paging request at ffff8802321ab000 [ 8.498452] IP: [<ffff8802321ab000>] 0xffff8802321ab000 [ 8.498478] PGD 200f067 PUD 2012067 PMD 2320b2063 PTE 80000002321ab163 [ 8.498509] Oops: 0011 [#1] SMP [ 8.498525] Modules linked in: ip6t_rpfilter ip6t_REJECT xt_conntrack ebtable_nat ebtable_broute bridge stp llc ebtable_filter ebtables ip6table_nat nf_conntrack_ipv6 nf_defrag_ipv6 nf_nat_ipv6 ip6table_mangle ip6table_security ip6table_raw ip6table_filter ip6_tables iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack iptable_mangle iptable_security iptable_raw tbsfe(OF) snd_usb_audio snd_usbmidi_lib snd_hwdep snd_rawmidi kvm snd_seq crct10dif_pclmul crc32_pclmul crc32c_intel snd_seq_device ir_lirc_codec(OF) lirc_dev(OF) ghash_clmulni_intel ir_mce_kbd_decoder(OF) rc_tbs_nec(OF) microcode ir_sony_decoder(OF) snd_pcm ir_jvc_decoder(OF) saa716x_tbs_dvb(OF) tbs6982fe(POF) tbs6680fe(POF) tbs6923fe(POF) tbs6985se(POF) tbs6928se(POF) serio_raw tbs6982se(POF) ir_rc6_decoder(OF) tbs6991fe(POF) [ 8.498861] tbs6618fe(POF) saa716x_core(OF) tbs6922fe(POF) tbs6928fe(POF) ir_rc5_decoder(OF) tbs6991se(POF) stv090x ir_nec_decoder(OF) dvb_core k10temp r8169 mii rc_core(OF) snd_page_alloc shpchp snd_timer snd soundcore joydev i2c_piix4 acpi_cpufreq ata_generic pata_acpi btrfs libcrc32c xor raid6_pq radeon pata_atiixp i2c_algo_bit drm_kms_helper ttm drm i2c_core hid_logitech_dj [ 8.499031] CPU: 0 PID: 1239 Comm: tvheadend Tainted: PF O 3.13.5-202.fc20.x86_64 #1 [ 8.499064] Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./FM2A75 Pro4-M, BIOS P2.00 11/30/2012 [ 8.499100] task: ffff880094ede780 ti: ffff880224232000 task.ti: ffff880224232000 [ 8.499127] RIP: 0010:[<ffff8802321ab000>] [<ffff8802321ab000>] 0xffff8802321ab000 [ 8.499163] RSP: 0018:ffff880224233d98 EFLAGS: 00010286 [ 8.499184] RAX: ffff8802321ab000 RBX: ffff8802321ab010 RCX: 0000000000000000 [ 8.499210] RDX: 0000000000000000 RSI: ffff8802236d9480 RDI: ffff8802321ab010 [ 8.499236] RBP: ffff880224233de0 R08: 0000000000017340 R09: ffff880236801800 [ 8.499260] R10: ffff8802236d9480 R11: 0000000000000000 R12: ffff8802236d9480 [ 8.499283] R13: 0000000000000000 R14: ffff8802236d9480 R15: ffff880224233e08 [ 8.499306] FS: 00007fc395839880(0000) GS:ffff88023ec00000(0000) knlGS:0000000000000000 [ 8.499332] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 8.499351] CR2: ffff8802321ab000 CR3: 0000000231eec000 CR4: 00000000000407f0 [ 8.499374] Stack: [ 8.499382] ffffffffa035213f ffff880224233e08 ffff880231984b00 ffff8802313b05c0 [ 8.499410] 00000000fffffff2 0000000000000001 0000000000000000 ffff880224233e08 [ 8.499437] 0000000040106f52 ffff880224233eb8 ffffffffa0347a15 ffffffffa0351f40 [ 8.499465] Call Trace: [ 8.499483] [<ffffffffa035213f>] ? dvb_frontend_ioctl+0x1ff/0x1270 [dvb_core] [ 8.499511] [<ffffffffa0347a15>] dvb_usercopy+0x115/0x190 [dvb_core] [ 8.499538] [<ffffffffa0351f40>] ? dvb_register_frontend+0x1b0/0x1b0 [dvb_core] [ 8.499565] [<ffffffff811c931a>] ? do_filp_open+0x3a/0x90 [ 8.499587] [<ffffffffa0347ab3>] dvb_generic_ioctl+0x23/0x40 [dvb_core] [ 8.499610] [<ffffffff811cb6f8>] do_vfs_ioctl+0x2d8/0x4a0 [ 8.499629] [<ffffffff811c3d32>] ? final_putname+0x22/0x50 [ 8.499649] [<ffffffff811cb941>] SyS_ioctl+0x81/0xa0 [ 8.499667] [<ffffffff81695f69>] system_call_fastpath+0x16/0x1b [ 8.499687] Code: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 <38> 8b da 32 02 88 ff ff e0 4e 3f a0 ff ff ff ff 54 75 72 62 6f [ 8.499815] RIP [<ffff8802321ab000>] 0xffff8802321ab000 [ 8.499836] RSP <ffff880224233d98> [ 8.499848] CR2: ffff8802321ab000 [ 8.507691] ---[ end trace 6b50086737a7e118 ]--- [ 9.742756] ALSA sound/usb/mixer.c:2266 status interrupt: c0 0e [ 9.806636] ALSA sound/usb/mixer.c:2266 status interrupt: c0 0e [ 9.870631] ALSA sound/usb/mixer.c:2266 status interrupt: c0 0e [ 9.934635] ALSA sound/usb/mixer.c:2266 status interrupt: c0 0e [ 9.998633] ALSA sound/usb/mixer.c:2266 status interrupt: c0 0e [ 10.062753] ALSA sound/usb/mixer.c:2266 status interrupt: c0 0e [ 10.126752] ALSA sound/usb/mixer.c:2266 status interrupt: c0 0e [ 10.190639] ALSA sound/usb/mixer.c:2266 status interrupt: c0 0e [ 10.254754] ALSA sound/usb/mixer.c:2266 status interrupt: c0 0e [ 10.318649] ALSA sound/usb/mixer.c:2266 status interrupt: c0 0e [ 10.382763] ALSA sound/usb/mixer.c:2266 status interrupt: c0 0e [[email protected] ~]#
Neula
Re: Card can't be accessed
Postby limiteddi » Fri Apr 04, 2014 3:12 am
Did you manege to fix it? I seem to be having a very similar issue
limiteddi
Postby drc38 » Wed May 28, 2014 3:06 pm
I have the same issue, with both TVheadend and VDR using the 140425 drivers and Openelec CrazyCat 4.0.2 build. It has got to be something to do with how the drivers are presenting the TBS6982se to the backend as after tuning to a channel with szap the following produces a recording of the video stream to file.
Code: Select all
cat /dev/dvb/adapter0/dvr0 > tvchannel.ts
I haven't tried LJalves drivers yet but I believe they fix the issue https://github.com/ljalves/linux_media. It would be nice if TBS could incorporate the bug fixes into their next release as providing linux drivers that don't work with the most popular linux backends is not very helpful!
drc38
Postby drc38 » Wed May 28, 2014 4:36 pm
In case it helps the TBS driver developers, this is the dmesg output when the driver saa716x_tbs_dvb verbose logging is enabled:
Code: Select all
[    9.178612] saa716x_pci_init (0): found a TurboSight TBS 6982SE PCIe card
[    9.183672] SAA716x TBS 0000:02:00.0: irq 43 for MSI/MSI-X
[    9.183727]     SAA7160 Rev 3 [6982:0002], irq: 43,
[    9.183730]     SAA7160 64Bit, MSI Enabled, MSI-X=32 msgs
[    9.193499] saa716x_i2c_hwinit (0): Adapter (c000) SAA716x I2C Core 0 RESET
[    9.193591] saa716x_i2c_hwinit (0): Adapter (b000) SAA716x I2C Core 1 RESET
[    9.260221] input: saa716x IR (TurboSight TBS 6982SE) as /devices/pci0000:00/0000:00:04.0/0000:02:00.0/rc/rc1/input9
[    9.260290] rc1: saa716x IR (TurboSight TBS 6982SE) as /devices/pci0000:00/0000:00:04.0/0000:02:00.0/rc/rc1
[    9.267952] input: MCE IR Keyboard/Mouse (saa716x) as /devices/virtual/input/input10
[    9.268068] DVB: registering new adapter (SAA716x dvb adapter)
[    9.308941] rc rc1: lirc_dev: driver ir-lirc-codec (saa716x) registered at minor = 0
[    9.430048] saa716x_tbs6982se_frontend_attach (0): Probing for TBS6982SE Frontend 0
[    9.807191] saa716x_tbs6982se_frontend_attach (0): TBS6982SE Frontend found @0x60
[    9.839234] saa716x_tbs6982se_frontend_attach (0): Done!
[    9.839408] DVB: registering new adapter (SAA716x dvb adapter)
[   10.023367] saa716x_tbs6982se_frontend_attach (0): Probing for TBS6982SE Frontend 1
[   10.396704] saa716x_tbs6982se_frontend_attach (0): TBS6982SE Frontend found @0x68
[   10.397498] saa716x_tbs6982se_frontend_attach (0): Done!
[ 1288.465049] saa716x_i2c_send (0): TXFIFO not empty after Timeout, tried 1000 loops!
[ 1288.465060] saa716x_i2c_send (0): I2C Send failed (Err=-5)
[ 1288.465065] saa716x_i2c_xfer (0): Data send failed
[ 1288.465076] saa716x_i2c_hwinit (0): Adapter (b000) SAA716x I2C Core 1 RESET
drc38
