My program for TSBviewer has stopped working.
On double clicking the shortcut or the .exe file the prog will start up with a TV prog in the background, then display that 'DVB application has stopped working' Windows is trying to find a solution. The solution never appears. I have uninsalled cleaned out any reference to the prog from the registry, then reinstalled many times, all to no avail.
This problem arose about three monthe ago and I am wondering if a windows update file could be the reason.
I am running Windows Home Premium 64bit. If I do a clean install and it seems to be OK.
