TBS6928, tvheadend and oscam
Re: TBS6928, tvheadend and oscam
Postby BeMax » Tue Jun 25, 2013 1:55 pm
Will this setup use the card for SW cam (oscam) and HW cam at the same time ? Then I'm also interested...
BeMax
Postby bkipper » Fri Jun 28, 2013 11:05 pm
That's my understanding yes. But configuring this on my own is quite impossible I think. Help from anybody possible?
bkipper
Postby roleksak » Tue Jul 02, 2013 1:08 pm
I have the same problem, could you please publish manual here? thanks
roleksak
Postby jpg333 » Fri Jul 05, 2013 5:45 pm
Hi all,
I try to do it by myself, but without success, could you send info in PM to me
Many Many thanks in advance
JP
jpg333
Postby bkipper » Thu Jul 11, 2013 3:18 am
Did somebody here asking the config files actually received them?
bkipper
Postby BeMax » Wed Jul 31, 2013 3:54 pm
bkipper wrote:Did somebody here asking the config files actually received them?
Nothing yet....
BeMax
Postby demax » Tue Aug 06, 2013 7:15 pm
Guys,
Just for the record, I did not receive any oscam config yet. I solved my case with mp tv-server. However, i'm back on the oscam and tvheadend track again since mp tv-server and my tbs card is extremely unstable and theres no offical support within mp-tv server.
demax
Postby bkipper » Sat Sep 14, 2013 1:25 am
I wanted to let you guys know I also solved my problems by leaving TvHeadend and using VDR. The cam works great and channels get decrypted.
bkipper
Postby rodnheli » Wed Apr 08, 2015 10:35 pm
has anybody received infos about using the internal CAM modul with OSCAM??
bought my tbs6928 one week ago - currently using the card with oscam + tvheadend + easymouse 2 - but would like to make it work with the TBS reader...
nobody seems to answer via mail form TBS support - problably someone from TBS could answer in this post...
thank you very much!
best regards,
helmut
rodnheli
Previous
