No 6928 mentioned in 130927
Re: No 6928 mentioned in 130927
Postby updatelee » Wed Nov 20, 2013 9:04 am
well w_scan just scan's (I cant get it todo anything on any of my tuners) but thats what its designed for. Not recording.
Are you looking a a simple recording app or a full multimedia centre app ?
My tune-s2 / demux app will tune a tp and record a show. Its a console app so its super simple and easy to use in a script. But its no multimedia app, its pretty basic.
Postby wa7kgx » Thu Nov 21, 2013 5:24 pm
Is w_scan supposed to scan? Seems logical.
But w_scan -v -v -v -v -v -fs -S105W0 just sits there doing nothing.
It complains about defaulting to UTF-8 but there are no other messages.
Is the board defective? Both TBSViewer and DVBDream crash and burn under 64 bit Win7
on a system that is quite stable when not using the TBS card.
wa7kgx
Postby wa7kgx » Thu Nov 21, 2013 5:31 pm
I would like to have an app under Linux comparable to DVBDream.
At the moment I'd be happy if I can just record NASA Select HD without
the TBS card crashing the machine.
The previous card worked fine for NASA Select before it died
but the 6928 has never worked reliably.
wa7kgx
Postby wa7kgx » Fri Nov 22, 2013 9:36 am
I got the tbs Linux driver(s) installed, but the 6928 driver is brain damaged:
dmesg | grep front
[ 9.978231] SAA716x TBS 0000:06:00.0: DVB: registering adapter 0 frontend 1953724787 (TurboSight TBS 6928 DVBS/S2 frontend)...
[ 952.995835] SAA716x TBS 0000:06:00.0: dvb_frontend_ioctl_legacy: doesn't know how to handle a DVBv3 call to delivery system 176
szap -x -l C-BAND NASA
reading channels from file '/root/.szap/channels.conf'
zapping to 1 'NASA':
sat 0, frequency = 3760 MHz V, symbolrate 28068000, vpid = 0x0111, apid = 0x0115 sid = 0x0065
frontend device is not a QPSK (DVB-S) device!
wa7kgx
Postby updatelee » Fri Nov 22, 2013 10:41 am
Thats cause its using v3 dvb api, which is stupid old.
Its a nightmare to support both v3 and v5. everyone supports v5 pretty much no one supports v3
Postby wa7kgx » Fri Nov 22, 2013 1:57 pm
Tried with szap-s2:
[root@stereo tbs]# szap-s2 NASA
sat 0, frequency 3760 MHz V, symbolrate 28068000, coderate auto, rolloff 0.35
vpid 0x0111, apid 0x0115, sid 0x0065
Killed
[root@stereo tbs]#
dmesg:
[12701.579760] kernel tried to execute NX-protected page - exploit attempt? (uid: 0)
[12701.580321] BUG: unable to handle kernel paging request at ffff880213686000
[12701.580847] IP: [<ffff880213686000>] 0xffff880213685fff
[12701.581384] PGD 1fe5067 PUD 1fe8067 PMD 211896063 PTE 8000000213686163
[12701.581916] Oops: 0011 [#1] SMP
[12701.582483] Modules linked in: nf_conntrack_netbios_ns nf_conntrack_broadcast ipt_MASQUERADE bnep ip6t_REJECT bluetooth xt_conntrack cfg80211 rfkill ebtable_nat ebtable_broute bridge stp llc ebtable_filter ebtables ip6table_nat nf_conntrack_ipv6 nf_defrag_ipv6 nf_nat_ipv6 ip6table_mangle ip6table_security ip6table_raw ip6table_filter ip6_tables iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack iptable_mangle iptable_security iptable_raw tbsfe(OF) coretemp kvm_intel kvm crc32_pclmul crc32c_intel ghash_clmulni_intel snd_hda_codec_hdmi snd_hda_codec_realtek ir_lirc_codec(OF) lirc_dev(OF) ir_mce_kbd_decoder(OF) ir_sony_decoder(OF) ir_jvc_decoder(OF) rc_tbs_nec(OF) snd_hda_intel snd_hda_codec saa716x_tbs_dvb(OF) tbs6982fe(POF) tbs6680fe(POF) tbs6923fe(POF) tbs6985se(POF) tbs6928se(POF)
[12701.585031] tbs6982se(POF) tbs6991fe(POF) tbs6618fe(POF) saa716x_core(OF) tbs6922fe(POF) tbs6928fe(POF) tbs6991se(POF) stv090x dvb_core snd_hwdep snd_seq r8169 snd_seq_device snd_pcm iTCO_wdt ppdev ir_rc6_decoder(OF) ir_rc5_decoder(OF) ir_nec_decoder(OF) rc_core(OF) microcode mii iTCO_vendor_support joydev i2c_i801 serio_raw parport_pc shpchp lpc_ich parport snd_page_alloc snd_timer snd soundcore mfd_core acpi_cpufreq mperf nfsd auth_rpcgss nfs_acl lockd sunrpc binfmt_misc ata_generic pata_acpi nouveau pata_it8213 video mxm_wmi firewire_ohci wmi firewire_core i2c_algo_bit drm_kms_helper crc_itu_t ttm drm i2c_core
[12701.587853] CPU: 0 PID: 2796 Comm: szap-s2 Tainted: PF O 3.11.8-300.fc20.x86_64 #1
[12701.588862] Hardware name: Gigabyte Technology Co., Ltd. P55A-UD3/P55A-UD3, BIOS F11 08/10/2010
[12701.589891] task: ffff8801f13544a0 ti: ffff8801ec0c8000 task.ti: ffff8801ec0c8000
[12701.590916] RIP: 0010:[<ffff880213686000>] [<ffff880213686000>] 0xffff880213685fff
[12701.591969] RSP: 0018:ffff8801ec0c9d98 EFLAGS: 00010286
[12701.593014] RAX: ffff880213686000 RBX: ffff880213686010 RCX: 0000000000000000
[12701.594066] RDX: 0000000000000000 RSI: ffff8801f67901e0 RDI: ffff880213686010
[12701.595135] RBP: ffff8801ec0c9de0 R08: 0000000000016f00 R09: ffffffffa038a1ff
[12701.596205] R10: ffff8801f67901e0 R11: 0000000000000000 R12: ffff8801f67901e0
[12701.597281] R13: 0000000000000000 R14: ffff8801f67901e0 R15: ffff8801ec0c9e08
[12701.598348] FS: 00007f71931d4740(0000) GS:ffff88021fc00000(0000) knlGS:0000000000000000
[12701.599428] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[12701.600514] CR2: ffff880213686000 CR3: 00000001f66f9000 CR4: 00000000000007f0
[12701.601600] Stack:
[12701.602681] ffffffffa038a287 ffffffff811aa2fe ffff8801ec0a1300 ffff8802133439c0
[12701.603783] 00000000fffffff2 0000000000000001 0000000000000000 ffff8801ec0c9e08
[12701.604894] 0000000040106f52 ffff8801ec0c9eb8 ffffffffa037fa55 ffffffffa038a080
[12701.606008] Call Trace:
[12701.607138] [<ffffffffa038a287>] ? dvb_frontend_ioctl+0x207/0x1280 [dvb_core]
[12701.608254] [<ffffffff811aa2fe>] ? put_filp+0x4e/0x60
[12701.609369] [<ffffffffa037fa55>] dvb_usercopy+0x115/0x190 [dvb_core]
[12701.610480] [<ffffffffa038a080>] ? dvb_register_frontend+0x1c0/0x1c0 [dvb_core]
[12701.611601] [<ffffffff811b81da>] ? do_filp_open+0x3a/0x90
[12701.612734] [<ffffffffa037faf3>] dvb_generic_ioctl+0x23/0x40 [dvb_core]
[12701.613857] [<ffffffff811ba00d>] do_vfs_ioctl+0x2dd/0x4b0
[12701.614992] [<ffffffff811b34d2>] ? final_putname+0x22/0x50
[12701.616117] [<ffffffff811b36db>] ? putname+0x2b/0x40
[12701.617242] [<ffffffff811ba261>] SyS_ioctl+0x81/0xa0
[12701.618367] [<ffffffff81652959>] system_call_fastpath+0x16/0x1b
[12701.619475] Code: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 <38> 8b 06 11 02 88 ff ff 60 8e 41 a0 ff ff ff ff 54 75 72 62 6f
[12701.620691] RIP [<ffff880213686000>] 0xffff880213685fff
[12701.621897] RSP <ffff8801ec0c9d98>
[12701.623063] CR2: ffff880213686000
[12701.631633] ---[ end trace 678795462b2df4a8 ]---
wa7kgx
Previous
