CI+ Module
Re: CI+ Module
Postby gligi » Fri May 23, 2014 3:37 am
it works like a charm. thank you very much.. :D :D :D
if only vdr <-> dvbapi support would be like yours :lol: :lol:
gligi
Re: CI+ Module
Postby smirnof » Thu May 14, 2015 4:21 pm
I have the same problem but with card 6991-SE how can i get it working? any help please..
MAXtv module CI+ and card.
Regards
smirnof
Re: CI+ Module
Postby smirnof » Fri May 15, 2015 8:25 pm
Well, i made a changes to the driver, but still have the same problem! it's not working.
The changes i made to the driver tbsci.c:
case 0x68:
             if (state->mode == 8) {
                printk("tbsci: Initializing TBS 6991 MAXTV\n");
                state->mode = 4;
            data = 0;
            tbsci_i2c_write(state, 0xd0, &data, 1);
            data = 0;
            tbsci_i2c_write(state, 0xcc, &data, 1);
            data = 0x01;
            tbsci_i2c_write(state, 0xcd, &data, 1);
            data = 0x08;
            tbsci_i2c_write(state, 0xce, &data, 1);
             } else {
                printk("tbsci: Initializing TBS 6680 CI slot\n");
                        break;
From dmesg i get this:
[   13.101692] tbsci: Initializing TBS 6991 MAXTV
[   13.102112] tbsci: Adapter 0 CI slot initialized
[   13.493060] tbsci: Initializing TBS 6991 MAXTV
[   13.493501] tbsci: Adapter 1 CI slot initialized
i recieve this error
Info:  CAM:  No CAM initialization in 30s, WE FORCE A RESET. try 1 on 5.
Info:  CAM:  The CAM isn't in a good state after reset, it will probably don't work :(
Any help please??
smirnof
Re: CI+ Module
Postby lucluc » Sat Jun 25, 2016 5:00 pm
Hi all. I have the same module and TBS6991SE card. All work perfect but only with 3 channels. Is there any option to stream more than 3 channels at the same time. Look like this ci module have some kind of protection because if I start fourth channel, have error something like I am not subscribed for that package... Thanks
lucluc
Re: CI+ Module
Postby agata » Tue Feb 13, 2018 6:29 pm
hello,
I have 2 modules as above and I'm not able to decode more than 10 chan per module per transponder .
The CI+ seems 96Mpbs enabled in tvh.
Transponders that I use are DVBS2 65.3 Mbps with 25-30 chans but any chan after 10th makes errors : #4001 Continuity counter error (total 18) and no descrambling.
What do you think is hw CI+ limitation or could be the TBS drivers limitation of my TBS6910 2xCI+ ?
I cannot confirm because there is no stable softcam but from my tests it seems suffers same limitation on 10 pids.
Agata
agata
Re: CI+ Module
Postby steven » Fri Aug 31, 2018 2:06 pm
Hi agata
Do you have any other card such as TBS6590 ? what about the transponder data rate how much it is ?
and for 6910 which driver you are using ?
Re: CI+ Module
Postby macery » Thu Oct 11, 2018 4:05 pm
I'm also using SmarDTV’s SmarCAM-3.5 CI Plus module (same as above) with TBS6590 and I don't know how many PIDs/channels is it capable to decrypt, but the fact is that by default it can decrypt 3 channels and with applied patch it decrypts up to 12 channels (depending which transponder I use.). And now I can't tell if more than 12 is CAM limit or TBS driver limit? Thank you.
macery
Re: CI+ Module
Postby steven » Thu Jan 03, 2019 11:24 am
for CI+ support you can find answer here :
viewtopic.php?f=86&t=25089&p=54425#p54425
:D
Re: CI+ Module
Postby dam72 » Fri Jan 07, 2022 2:52 am
Hi Steve, the link doesn´t work: Can you provide the information where to find the info?
dam72
Re: CI+ Module
Postby steven » Mon Jan 17, 2022 11:39 am
dam72 Wrote:Hi Steve, the link doesn´t work: Can you provide the information where to find the info?
Hi Sir
we have service to help setup with CI+ please check this
https://www.tbsiptv.com/index.php?route=product/product&path=199&product_id=164
You can have a try
Previous
