i am using DiSEqC 4 ports
before months Diseqc was working normal , i do not know which mistake cause there is no response right now
i am using win7 x64 with last ver:2.0.0.6
i tried with DVB-Dream / Creazy Scan / EBS pro / Prog Finder / DVB Dream oem>> All of these programs lead to same result
i tried plug/unplug usb as well power off but no benefit
i downgraded driver lower 2.0.0.3 and 2.0.0.4 but not affect
only port 1 works even i tried with port 2 or even 3 , it force shows signal for port 1 only
i can see command inside log !
- Code: Select All Code
23:58:05 - 21/12/2019 StreamReaderEx BDA Ver:1.2.4.52-commited (Feb 3 2018, 19:08:52)
23:58:05 - 21/12/2019 Log level = 1
23:58:05 - 21/12/2019 DLL_PROCESS_ATTACH hModule = 693D0000
23:58:05 - 21/12/2019 CheckForDVBEx(0x012A9150)
23:58:05 - 21/12/2019 Power-off LNB on exit: ENABLED
23:58:05 - 21/12/2019 SendDiSEqC use 2 repeats
23:58:05 - 21/12/2019 Default modulation: AUTO
23:58:05 - 21/12/2019 Default spectral inversion: AUTO
23:58:05 - 21/12/2019 Default pilot: AUTO
23:58:05 - 21/12/2019 Default rolloff: AUTO
23:58:05 - 21/12/2019 Preffered BDA device type: AUTO
23:58:05 - 21/12/2019 Allowed IF Freq 950-2150 Mhz
23:58:05 - 21/12/2019 Inverted LOF<6000 and >21000 Mhz
23:58:05 - 21/12/2019 Available BDA-devices:
23:58:05 - 21/12/2019 Device 0
23:58:05 - 21/12/2019 Name: TBS 5925 DVBS2 Tuner
23:58:05 - 21/12/2019 Type: DVB-S/S2
23:58:05 - 21/12/2019 Index: 0
23:58:05 - 21/12/2019 StartDVBEx(0)
23:58:05 - 21/12/2019 Device_ID: 0
23:58:05 - 21/12/2019 Use Device 0
23:58:05 - 21/12/2019 Tuner filter: TBS 5925 DVBS2 Tuner
23:58:05 - 21/12/2019 Capture filter: TBS 5925 DVBS2 Capture
23:58:05 - 21/12/2019 Input num 0
23:58:06 - 21/12/2019 Tuner IC: STB6100
23:58:06 - 21/12/2019 Frontend/demod IC: STV090X (cut 3.0)
23:58:06 - 21/12/2019 TBS STB6100/STV090X direct control used !
23:58:06 - 21/12/2019 BBGain = 8 dB
23:58:06 - 21/12/2019 Turbosight (QBOX - Cypress FX2 based) BDA extension used !
23:58:06 - 21/12/2019 + Turbosight BlindScan support with STV09XX
23:58:06 - 21/12/2019 + Turbosight I2C access support
23:58:06 - 21/12/2019 + Turbosight fast LNB control support
23:58:06 - 21/12/2019 + Turbosight SignalEx support
23:58:06 - 21/12/2019 + Turbosight SignalInfo support
23:58:06 - 21/12/2019 + Turbosight MIS filtering support
23:58:06 - 21/12/2019 + Turbosight PLS control support
23:58:06 - 21/12/2019 + Turbosight MODCODE filtering support
23:58:17 - 21/12/2019 SendDiSEqC (2, f7)
23:58:17 - 21/12/2019 MISSel(0,0x00,0x00)
23:58:18 - 21/12/2019 ModSel(0x45A4D8, 0)
23:58:18 - 21/12/2019 PLSSel(0,0x01)
23:58:23 - 21/12/2019 StopDVB()
23:58:23 - 21/12/2019 LNB power-off ok !
23:58:23 - 21/12/2019 DLL_PROCESS_DETACH hModule = 693D0000
important note: when i try with other STB i notice DiSEqC works normal, so what is the mistake!
