As above Fedora 22 x86_64 Kernel 4.1.10-200 (latest this weekend).
Using driver V150728
Machine has both a 6280 and a 6284 card fitted......new build
TBS driver build went as expected with no issues reported........however upon reboot dmesg report:-
[ 17.367221] ------------[ cut here ]------------
[ 17.367228] WARNING: CPU: 1 PID: 482 at lib/kobject.c:675 kobject_put+0x60/0x70()
[ 17.367230] kobject: '(null)' (ffff88020d788260): is not initialized, yet kobject_put() is being called.
[ 17.367231] Modules linked in: saa716x_tbs_dvb(OE+) tbs6982fe(POE) tbs6680fe(POE) tbs6923fe(POE) tbs6985se(POE) tbs6928se(POE) tbs6982se(POE) tbs6991fe(POE) tbs6618fe(POE) tbs6983fe(POE) snd_hda_codec_realtek snd_hda_codec_hdmi snd_hda_codec_generic saa716x_core(OE) intel_rapl tbs6922fe(POE) tbs6928fe(POE) tbs6991se(POE) tbs6290fe(POE) iosf_mbi snd_hda_intel snd_hda_controller stv090x(OE) dvb_core(OE) snd_hda_codec rc_core x86_pkg_temp_thermal eeepc_wmi snd_hda_core snd_hwdep coretemp snd_seq asus_wmi sparse_keymap rfkill snd_seq_device iTCO_wdt kvm raid456 iTCO_vendor_support crct10dif_pclmul async_raid6_recov async_memcpy async_pq async_xor crc32_pclmul mxm_wmi xor crc32c_intel snd_pcm async_tx ghash_clmulni_intel snd_timer raid6_pq lpc_ich tpm_infineon snd i2c_i801 tpm_tis soundcore mfd_core mei_me
[ 17.367261] shpchp wmi mei tpm nfsd auth_rpcgss nfs_acl lockd grace sunrpc 8021q garp stp llc mrp i915 i2c_algo_bit drm_kms_helper drm serio_raw e1000e ptp pps_core video
[ 17.367274] CPU: 1 PID: 482 Comm: systemd-udevd Tainted: P OE 4.1.10-200.fc22.x86_64 #1
[ 17.367275] Hardware name: ASUS All Series/MAXIMUS VI GENE, BIOS 1603 08/15/2014
[ 17.367277] 0000000000000000 000000003922fb2e ffff88021493f948 ffffffff8179a79d
[ 17.367279] 0000000000000000 ffff88021493f9a0 ffff88021493f988 ffffffff810a16aa
[ 17.367281] ffff88021493f9a8 ffff88020d788260 ffff8800364b3400 ffff88020d788000
[ 17.367283] Call Trace:
[ 17.367289] [<ffffffff8179a79d>] dump_stack+0x45/0x57
[ 17.367293] [<ffffffff810a16aa>] warn_slowpath_common+0x8a/0xc0
[ 17.367295] [<ffffffff810a1735>] warn_slowpath_fmt+0x55/0x70
[ 17.367297] [<ffffffff813aff30>] kobject_put+0x60/0x70
[ 17.367301] [<ffffffff814e7ee7>] put_device+0x17/0x20
[ 17.367305] [<ffffffff815c9d1b>] input_free_device+0x2b/0x70
[ 17.367308] [<ffffffffa04c4652>] rc_free_device+0x22/0x50 [rc_core]
[ 17.367313] [<ffffffffa05f977b>] saa716x_input_init+0x19b/0x1f0 [saa716x_tbs_dvb]
[ 17.367316] [<ffffffffa05f9251>] saa716x_tbs_pci_probe+0x271/0x320 [saa716x_tbs_dvb]
[ 17.367321] [<ffffffff813faf75>] local_pci_probe+0x45/0xa0
[ 17.367324] [<ffffffff812abd62>] ? sysfs_do_create_link_sd.isra.2+0x72/0xc0
[ 17.367327] [<ffffffff813fc2d9>] pci_device_probe+0xf9/0x150
[ 17.367330] [<ffffffff814ed0f9>] driver_probe_device+0x209/0x4b0
[ 17.367332] [<ffffffff814ed47b>] __driver_attach+0x9b/0xa0
[ 17.367335] [<ffffffff814ed3e0>] ? __device_attach+0x40/0x40
[ 17.367337] [<ffffffff814eacc3>] bus_for_each_dev+0x73/0xc0
[ 17.367340] [<ffffffff814ec9be>] driver_attach+0x1e/0x20
[ 17.367342] [<ffffffff814ec570>] bus_add_driver+0x180/0x250
[ 17.367346] [<ffffffffa05f9480>] ? load_config_tbs6923+0x10/0x10 [saa716x_tbs_dvb]
[ 17.367348] [<ffffffff814edc74>] driver_register+0x64/0xf0
[ 17.367351] [<ffffffff813fa80c>] __pci_register_driver+0x4c/0x50
[ 17.367354] [<ffffffffa05f94a3>] saa716x_tbs_init+0x23/0x30 [saa716x_tbs_dvb]
[ 17.367357] [<ffffffff81002128>] do_one_initcall+0xb8/0x200
[ 17.367360] [<ffffffff811ee862>] ? __vunmap+0xa2/0x100
[ 17.367364] [<ffffffff8120baa9>] ? kmem_cache_alloc_trace+0x1b9/0x240
[ 17.367366] [<ffffffff817999e9>] ? do_init_module+0x28/0x1cb
[ 17.367368] [<ffffffff81799a21>] do_init_module+0x60/0x1cb
[ 17.367372] [<ffffffff81127e8e>] load_module+0x209e/0x26f0
[ 17.367375] [<ffffffff811238d0>] ? store_uevent+0x70/0x70
[ 17.367378] [<ffffffff81231260>] ? kernel_read+0x50/0x80
[ 17.367381] [<ffffffff8112874e>] SyS_finit_module+0xbe/0xf0
[ 17.367383] [<ffffffff817a0d6e>] system_call_fastpath+0x12/0x71
[ 17.367385] ---[ end trace 6684ea9dc2a851ca ]---
[ 17.367388] DVB: registering new adapter (SAA716x dvb adapter)
[ 18.277293] TurboSight TBS6280 DVB-T2 card MAC=ff:ff:ff:ff:ff:ff
[ 18.277296] DVB: registering adapter 0 frontend 0 (TurboSight TBS 62x0 DVBT/T2 frontend)...
[ 18.277400] DVB: registering new adapter (SAA716x dvb adapter)
[ 18.325234] TurboSight TBS6280 DVB-T2 card MAC=ff:ff:ff:ff:ff:ff
[ 18.325236] DVB: registering adapter 1 frontend 0 (TurboSight TBS 62x0 DVBT/T2 frontend)...
[ 18.333377] ------------[ cut here ]------------
[ 18.333382] WARNING: CPU: 2 PID: 482 at lib/kobject.c:675 kobject_put+0x60/0x70()
[ 18.333383] kobject: '(null)' (ffff8800cf458260): is not initialized, yet kobject_put() is being called.
[ 18.333383] Modules linked in: tbs62x0fe(POE) saa716x_tbs_dvb(OE+) tbs6982fe(POE) tbs6680fe(POE) tbs6923fe(POE) tbs6985se(POE) tbs6928se(POE) tbs6982se(POE) tbs6991fe(POE) tbs6618fe(POE) tbs6983fe(POE) snd_hda_codec_realtek snd_hda_codec_hdmi snd_hda_codec_generic saa716x_core(OE) intel_rapl tbs6922fe(POE) tbs6928fe(POE) tbs6991se(POE) tbs6290fe(POE) iosf_mbi snd_hda_intel snd_hda_controller stv090x(OE) dvb_core(OE) snd_hda_codec rc_core x86_pkg_temp_thermal eeepc_wmi snd_hda_core snd_hwdep coretemp snd_seq asus_wmi sparse_keymap rfkill snd_seq_device iTCO_wdt kvm raid456 iTCO_vendor_support crct10dif_pclmul async_raid6_recov async_memcpy async_pq async_xor crc32_pclmul mxm_wmi xor crc32c_intel snd_pcm async_tx ghash_clmulni_intel snd_timer raid6_pq lpc_ich tpm_infineon snd i2c_i801 tpm_tis soundcore
[ 18.333404] mfd_core mei_me shpchp wmi mei tpm nfsd auth_rpcgss nfs_acl lockd grace sunrpc 8021q garp stp llc mrp i915 i2c_algo_bit drm_kms_helper drm serio_raw e1000e ptp pps_core video
[ 18.333414] CPU: 2 PID: 482 Comm: systemd-udevd Tainted: P W OE 4.1.10-200.fc22.x86_64 #1
[ 18.333415] Hardware name: ASUS All Series/MAXIMUS VI GENE, BIOS 1603 08/15/2014
[ 18.333416] 0000000000000000 000000003922fb2e ffff88021493f948 ffffffff8179a79d
[ 18.333417] 0000000000000000 ffff88021493f9a0 ffff88021493f988 ffffffff810a16aa
[ 18.333419] ffff88021493f9a8 ffff8800cf458260 ffff8800d2cd7700 ffff8800cf458000
[ 18.333420] Call Trace:
[ 18.333425] [<ffffffff8179a79d>] dump_stack+0x45/0x57
[ 18.333428] [<ffffffff810a16aa>] warn_slowpath_common+0x8a/0xc0
[ 18.333430] [<ffffffff810a1735>] warn_slowpath_fmt+0x55/0x70
[ 18.333431] [<ffffffff813aff30>] kobject_put+0x60/0x70
[ 18.333434] [<ffffffff814e7ee7>] put_device+0x17/0x20
[ 18.333437] [<ffffffff815c9d1b>] input_free_device+0x2b/0x70
[ 18.333440] [<ffffffffa04c4652>] rc_free_device+0x22/0x50 [rc_core]
[ 18.333443] [<ffffffffa05f977b>] saa716x_input_init+0x19b/0x1f0 [saa716x_tbs_dvb]
[ 18.333446] [<ffffffffa05f9251>] saa716x_tbs_pci_probe+0x271/0x320 [saa716x_tbs_dvb]
[ 18.333449] [<ffffffff813faf75>] local_pci_probe+0x45/0xa0
[ 18.333452] [<ffffffff812abd62>] ? sysfs_do_create_link_sd.isra.2+0x72/0xc0
[ 18.333454] [<ffffffff813fc2d9>] pci_device_probe+0xf9/0x150
[ 18.333456] [<ffffffff814ed0f9>] driver_probe_device+0x209/0x4b0
[ 18.333458] [<ffffffff814ed47b>] __driver_attach+0x9b/0xa0
[ 18.333459] [<ffffffff814ed3e0>] ? __device_attach+0x40/0x40
[ 18.333461] [<ffffffff814eacc3>] bus_for_each_dev+0x73/0xc0
[ 18.333462] [<ffffffff814ec9be>] driver_attach+0x1e/0x20
[ 18.333464] [<ffffffff814ec570>] bus_add_driver+0x180/0x250
[ 18.333466] [<ffffffffa05f9480>] ? load_config_tbs6923+0x10/0x10 [saa716x_tbs_dvb]
[ 18.333468] [<ffffffff814edc74>] driver_register+0x64/0xf0
[ 18.333469] [<ffffffff813fa80c>] __pci_register_driver+0x4c/0x50
[ 18.333471] [<ffffffffa05f94a3>] saa716x_tbs_init+0x23/0x30 [saa716x_tbs_dvb]
[ 18.333474] [<ffffffff81002128>] do_one_initcall+0xb8/0x200
[ 18.333476] [<ffffffff811ee862>] ? __vunmap+0xa2/0x100
[ 18.333479] [<ffffffff8120baa9>] ? kmem_cache_alloc_trace+0x1b9/0x240
[ 18.333481] [<ffffffff817999e9>] ? do_init_module+0x28/0x1cb
[ 18.333482] [<ffffffff81799a21>] do_init_module+0x60/0x1cb
[ 18.333486] [<ffffffff81127e8e>] load_module+0x209e/0x26f0
[ 18.333488] [<ffffffff811238d0>] ? store_uevent+0x70/0x70
[ 18.333491] [<ffffffff81231260>] ? kernel_read+0x50/0x80
[ 18.333492] [<ffffffff8112874e>] SyS_finit_module+0xbe/0xf0
[ 18.333495] [<ffffffff817a0d6e>] system_call_fastpath+0x12/0x71
[ 18.333496] ---[ end trace 6684ea9dc2a851cb ]---
[ 18.333498] DVB: registering new adapter (SAA716x dvb adapter)
[ 18.985408] TurboSight TBS6284 DVB-T2 card port0 MAC=ff:ff:ff:ff:ff:ff
[ 18.985410] DVB: registering adapter 2 frontend 0 (TurboSight TBS 62x0 DVBT/T2 frontend)...
Edited for message size reasons...port1-port3 are registered as above
The cards and frontends do load and are usable, however there's a huge performance hit on the box and it looks like it's causing problems during a reboot as drives are not getting written to properly (I suspect this is perhaps a cache related issue rather then actual).
Ideas?
