TBS6991SE & Digital Devices Cine S2
Postby stambeto » Mon Oct 20, 2014 9:00 pm
Hi i have these cards , when install drivers for TBS all is OK . when install Digital Devices Cine S2 TBS card stop working .
Are these cards using same modules can i install both on same pc if yes how thanks to all
stambeto
Re: TBS6991SE & Digital Devices Cine S2
Postby updatelee » Mon Oct 20, 2014 11:02 pm
The DD CineS2 probably uses a driver that TBS doesn't have in their tree.
I'm not sure what tuner/demod are used in the 6991se. It shouldn't be to hard to add support for open source for it. Unfortunately it's a $185 card, kinda out of my budget to pick one up just to add support.
Postby stambeto » Tue Oct 21, 2014 5:52 am
Currently kernel 3.16 support dd cine s2 , may use directly without compile drivers , but wneh try to install tbs dd cine s2 stop working
stambeto
Postby updatelee » Tue Oct 21, 2014 11:54 am
Yes, as stated the TBS driver must not support cine s2
