I'm watching on my recivier all channels are working without problem.
But when i try on mumudvb it says " Channel "beIN SPORTS 1 HD" is now highly scrambled (100% of scrambled packets). Card 0 "
How can i fix thath problem.
HERE IS MUMUDVB CONFIG
- Code: Select all
#------------ TUNING -------------
card=0
freq=11096
pol=h
srate=29900
coderate=2/3
lnb_type=universal
modulation=8PSK
lnb_lof_low=9750
lnb_lof_high=10600
lnb_slof=11700
autoconfiguration=full
autoconf_radios=1
autoconf_sid_list=410 411
#autoconf_unicast_start_port=4250
#--------- NETWORKING --------------
#common_port=1234
# multicast_ttl=2
#Do we want to send the announces ?
#sap=1
#sap_interval=1
# ---------- PAT REWRITING ----------
#rewrite_pat=1
#rewrite_sdt=1
#sort_eit=1
#unicast=1
#port_http=4242
#ip_http=88.255.248.169
#unicast_max_clients=2
#scam_support=1
#ring_buffer_default_size=16384
#decsa_default_delay=500000
#send_default_delay=1500000
# ---------- SCRAMBLED CHANNELS ----------
cam_support=1
autoconf_scrambled=1
#cam_number=0
HERE IS MUMUDVB CONFIG DEBUG
- Code: Select all
WARN: CAM: You have enabled the support for conditionnal acces modules (scrambled channels). Please report any bug/comment
Info: Main: Full autoconfiguration, we activate SAP announces. if you want to deactivate them see the README.
Info: Main: Full autoconfiguration, we activate PAT rewriting. if you want to disable it see the README.
Info: Main: Full autoconfiguration, we activate SDT rewriting. if you want to disable it see the README.
Info: Main: ========== End of configuration, MuMuDVB version 1.7.2_release is starting ==========
Info: Autoconf: The autoconfiguration auto update is enabled. If you want to disable it put "autoconf_pid_update=0" in your config file.
Info: Main: Streaming. Freq 11096000
Info: Tune: Using DVB card "TurboSight TBS 6991SE DVBS/S2 frontend" tuner 0
Info: Tune: Tuning DVB-S to Freq: 1346000 kHz, LO frequency 9750000 kHz Pol:H Srate=29900000, LNB number: 0
Info: Tune: LNB voltage 18V
Info: Tune: DISEQC SETTING SUCCEDED
Info: Tune: FE_STATUS:
Info: Tune: FE_HAS_SIGNAL : found something above the noise level
Info: Tune: FE_HAS_CARRIER : found a DVB signal
Info: Tune: FE_HAS_VITERBI : FEC is stable
Info: Tune: FE_HAS_SYNC : found sync bytes
Info: Tune: FE_HAS_LOCK : everything's working...
Info: Tune: Event: Frequency: 11096000 (or 8404000)
Info: Tune: SymbolRate: 29900000
Info: Tune: FEC_inner: 2050
Info: Tune: Bit error rate: 67108863
Info: Tune: Signal strength: 30150
Info: Tune: SNR: 65535
Info: Main: Card 0, tuner 0 tuned
Info: Autoconf: Autoconfiguration Start
Info: CAM: CAM Application type: 01
Info: CAM: CAM Application manufacturer: 4a60
Info: CAM: CAM Manufacturer code: 0001
Info: CAM: CAM Menu string: MODULE RETAIL
WARN: Autoconf: Warning : No NIT found before timeout
Info: Autoconf: Autoconfiguration done
Info: Autoconf: Diffusion 2 channels
Info: Autoconf: Channel number : 0, name : "beIN SPORTS 1 HD" service id 410
Info: Autoconf: Multicast4 ip : 239.100.0.0:1234
Info: Autoconf: Channel number : 1, name : "beIN SPORTS 2 HD" service id 411
Info: Autoconf: Multicast4 ip : 239.100.0.1:1234
Info: Main: Channel "beIN SPORTS 1 HD" is now highly scrambled (100% of scrambled packets). Card 0
Info: Main: Channel "beIN SPORTS 2 HD" is now highly scrambled (100% of scrambled packets). Card 0
