About PCI-Express compatibility issues
Re: About PCI-Express compatibility issues
Postby ittroll » Wed Oct 28, 2015 9:55 pm
I think I have just hit the very same issue with a TBS 6285 in an Asus H170M-E D3.
ittroll
Postby thunderm » Mon Dec 14, 2015 3:34 pm
Another compatibility issue with Supermicro X11SAE and TBS 6205:
Every 5 minutes i get this in dmesg log:
[367380.966212] pcieport 0000:00:1c.7: AER: Corrected error received: id=00e7
[367380.966227] pcieport 0000:00:1c.7: PCIe Bus Error: severity=Corrected, type=Data Link Layer, id=00e7(Transmitter ID)
[367380.966236] pcieport 0000:00:1c.7: device [8086:a117] error status/mask=00001000/00002000
[367380.966243] pcieport 0000:00:1c.7: [12] Replay Timer Timeout
thunderm
Postby ittroll » Wed Dec 23, 2015 5:39 pm
ittroll wrote:I think I have just hit the very same issue with a TBS 6285 in an Asus H170M-E D3.
Following several emails to ASUS support they added the feature to the H170 BIOS to allow you to specify Gen1 PCI-E speed. So ASUS have to come to the rescue to fix a problem in another manufacturer's product.
ittroll
Postby Souldream » Sun Mar 13, 2016 1:33 am
The most sad in this story is ... where are the answer from TBS ?
Souldream
Postby updatelee » Mon Mar 14, 2016 12:27 am
I wouldn't say its a TBS problem at all. Motherboard manufacturers are supporting PCIe 1.0 is not a TBS issue, its a motherboard manufacturer issue. TBS has basically given up on motherboard manufacturers and developed their own PCIe bridge to resolve an issue not with them at all. I think that pretty incredible of TBS and far far beyond what I would have expected of them. Pretty incredible imo. If you are unhappy with TBS, I cant possibly think of why you would be, then goto another manufacturer of DVB devices. You wont find service like this anywhere else though I'll warn you.
Postby thunderm » Tue Mar 15, 2016 6:23 pm
thunderm wrote:Another compatibility issue with Supermicro X11SAE and TBS 6205:
Some more info:
Cards are working without any problems, so no errors in reception at all, you can disable this message if you put pci=noaer to your kernel boot line, noaer means no advanced error reporting.
I have four QUAD cards without any problems, one month uptime.
I tried also to force PCI GEN1 instead of Auto detect to all PCIE slots with no success.
thunderm
Previous
Return to News
