Drivers build but are not installed in Fedora29 (Kernel 5.0)
Postby mollcons » Sun Mar 31, 2019 9:30 pm
I am running Fedora29 now with a recently installed kernel (5.0.4-200) and had successfully installed and run my MythTV application under kernel 4.2.15-200.
I am using the installation method descibed in https://github.com/tbsdtv/linux_media/wiki and testing the install with the commands in https://www.linuxtv.org/wiki/index.php/ ... stallation. In the latter, the first command run after reboot dmesg | grep -i saa716 responded with nothing, meaning that the installation of the drivers had clearly NOT worked.
How do I resolve this issue? Do your installation instructions need updating (I guess if they do, it will be because of the new kernel).
mollcons
Re: Drivers build but are not installed in Fedora29 (Kernel
Postby xiaocao » Thu Apr 04, 2019 9:30 am
hi ,
please add skype jack_2431 and setup teamviewer .
best regards!
xiaocao
Postby mollcons » Thu Apr 04, 2019 6:32 pm
I have setup both on my Linux PC. However, this PC does not currently have sound available, and also, it does NOT have a camera available. For Skype to work properly I will have to use my Windows10 Laptop which has all features.
I have just noticed that Teamviewer will NOT work because it does NOT support Wayland which is the default provided by Fedora 29.
mollcons
