TBS Linux driver v130506 availabe
Re: TBS Linux driver v130506 availabe
Postby updatelee » Thu May 16, 2013 1:10 am
Well it's a Perl issue with your system then. That code comes from v4l not TBS.
Skip the rmmod and goto rminstall then install and reboot
Postby ragamesh » Thu May 16, 2013 2:17 am
The same issue...
sudo make rminstall
sudo make install
sudo reboot
dmesg | grep frontend
[ 10.801035] videobuf_dvb: disagrees about version of symbol dvb_frontend_detach
[ 10.801037] videobuf_dvb: Unknown symbol dvb_frontend_detach (err -22)
[ 10.801047] videobuf_dvb: disagrees about version of symbol dvb_unregister_frontend
[ 10.801049] videobuf_dvb: Unknown symbol dvb_unregister_frontend (err -22)
[ 10.801053] videobuf_dvb: disagrees about version of symbol dvb_register_frontend
[ 10.801054] videobuf_dvb: Unknown symbol dvb_register_frontend (err -22)
:shock:
ragamesh
Postby updatelee » Thu May 16, 2013 3:56 am
You change kernels recently? you must do a distclean if you switch.
sudo make distclean
sudo make menuconfig
sudo make
sudo make rminstall
sudo make install
sudo reboot
Sometimes though the old media modules just will refuse to let go, esp if the folder structure isnt identical.
cd /lib/modules/$(uname -r)/kernel/drivers
sudo mv media media.bak
then go back to the tbs source and do a
sudo make install
sudo reboot
Postby ragamesh » Fri May 17, 2013 12:47 am
Yes I upgrade from 12.10 to 13.04 last week and a new kernel was installed..
Now I've tried your last instruction but nothing change... I tried also media to media.bak but nothing..
dmesg | grep frontend stil give the same error message...
aaarrrhh... before upgrate it's work perfectly!!!
Help me please... :)
Thank you again!
ragamesh
Postby updatelee » Fri May 17, 2013 1:29 am
do a uname -r to confirm your running the kernel version you think you are. I assume you are, but it would suck to be doing all this work and find its as simple as that lol
is your /usr/src/linux sym link pointing to the same kernel version that uname -r states?
do a
sudo updatedb
locate videobuf-dvb.ko
where does it show?
after doing a sudo make distclean, when you do the make step it spits out a few lines
Code: Select all
[email protected]:~/src/tbs/tbs-linux-drivers_v130509$ uname -r
3.9.0
[email protected]:~/src/tbs/tbs-linux-drivers_v130509$ sudo make
[sudo] password for updatelee:
make -C /home/updatelee/src/tbs/tbs-linux-drivers_v130509/v4l
make[1]: Entering directory `/home/updatelee/src/tbs/tbs-linux-drivers_v130509/v4l'
No version yet, using 3.9.0
make[1]: Leaving directory `/home/updatelee/src/tbs/tbs-linux-drivers_v130509/v4l'
scripts/make_makefile.pl
Updating/Creating .config
Preparing to compile for kernel version 3.9.0
as you can see the tree is picking up correctly that Im using 3.9.0 (match's uname -r)
does yours?
Postby ragamesh » Fri May 17, 2013 1:54 am
uname -r
3.8.0-21-generic
Code: Select all
/home/ernesto/Scaricati/tbs-linux-drivers_v130506/linux-tbs-drivers/v4l/.videobuf-dvb.ko.cmd
/home/ernesto/Scaricati/tbs-linux-drivers_v130506/linux-tbs-drivers/v4l/videobuf-dvb.ko
/lib/modules/3.8.0-21-generic/kernel/drivers/media/v4l2-core/videobuf-dvb.ko
/lib/modules/3.8.0-21-generic/kernel/drivers/media/video/videobuf-dvb.ko
the last make lines:
Code: Select all
ake[2]: Leaving directory `/usr/src/linux-headers-3.8.0-21-generic'
./scripts/rmmod.pl check
found 516 modules
make[1]: uscita dalla directory "/home/ernesto/Scaricati/tbs-linux-drivers_v130506/linux-tbs-drivers/v4l"
I think that it's correct kernel linked.. what do you think?
ragamesh
Postby ragamesh » Fri May 17, 2013 1:57 am
I tried now to reinstall... nothing same error..
ragamesh
Postby updatelee » Fri May 17, 2013 2:30 am
see, here's mine
/home/updatelee/src/tbs/tbs-linux-drivers_v130506/v4l/.videobuf-dvb.ko.cmd
/home/updatelee/src/tbs/tbs-linux-drivers_v130506/v4l/videobuf-dvb.ko
/lib/modules/3.9.0/kernel/drivers/media/v4l2-core/videobuf-dvb.ko
youve got a second copy in drivers/media/video
I would hazard a guess thats the one loading, therefore causing the disagreement. are they identical?
md5sum /lib/modules/3.8.0-21-generic/kernel/drivers/media/v4l2-core/videobuf-dvb.ko
md5sum /lib/modules/3.8.0-21-generic/kernel/drivers/media/video/videobuf-dvb.ko
Postby ragamesh » Fri May 17, 2013 7:38 pm
md5sum v4l2-core/videobuf-dvb.ko
0137b8c993eb3d14da68f41e30e6f0e6 v4l2-core/videobuf-dvb.
md5sum video/videobuf-dvb.ko
a4e607928b14ad776475c1d07f2f911c video/videobuf-dvb.ko
They'are differente!!!
What can I do?
ragamesh
Postby updatelee » Fri May 17, 2013 8:06 pm
I dont think the move cmd you used eariler worked then. Or you didnt move it out of /lib/modules, it must be moved right out of here else its just renamed and will still be loaded. If your up for a more permanent solution just delete the media folder, then sudo make install
PreviousNext
