No channels when CA-module inserted
Postby Borschen » Mon Jan 20, 2014 3:12 am
Hi!
Installed hardware/drivers and when I searched for channels the search came up empty. Started to troubleshoot and discovered it all work fine when I take out the CA-modules. Now it finds all channels, but the second I try to use the CAM the pictures freezes and the signal is lost.
Tried different viewers but the problem is the same. Dvb viewer, Dvb dream, windows media center, dvblink all the same. Tried different CA-modules as well. Don't got CI+.
Doesn't help to reinstall. In DVB Dream the signal strength and quality is good even with the CAMs inserted, but the channels won't show up.
My main setup is windows 8 media center with dvblink. Got a asus mb, amd cpu.
Kind of out of ideas what to do.
Borschen
