Firmware V1.1
A release date? An update? Different versions? ... keep you informed.
Firmware V1.1
Postby warumnix » Mon Apr 22, 2013 9:25 am
Hello ;)
Firmware V1.1 for MOI has been release, please get it from
http://www.tbsdtv.com/download/document ... e-code.zip
The following were added:
- Change the time zone.
click "setTimeZone " button on the WUI under "MOI Setting" and change the tiem information - Moth/ Day/ Year/ Hour/Minute/ Second,
and then click "getTimeZone" button to synchronize the time of MOI.
- Add SD/MMC and USB mount.
When you insert usb or mmc/sd ,it will be mount in the /mnt/usb dir or /mnt/usb dir.
- Add nfs Network Support.
warumnix
Re: Firmware V1.1
Postby jowski » Mon Apr 29, 2013 5:56 am
I downloaded 'tbs-moi-dvb-s2-streaming-box-2900-firmware_v1.1.zip', unzipped it, then tried to 'unyaffs2 MOI2900_fs.bin fs'. All that happened was an empty directory named 'fs' was created. I'm reluctant to try and update my MOI if I can't be sure that the file I intend to update it with might not be good. I also would like to look over the tree that will be installed when I update.
Please advise,
Jim
jowski
Re: Firmware V1.1
Postby marcelp1 » Sat May 04, 2013 9:03 pm
has anyone managed to update their MOI box with this firmware?
marcelp1
Re: Firmware V1.1
Postby guacharaca » Mon May 06, 2013 9:34 pm
Yes, installed without a problem. I have not tried the USB.
guacharaca
Re: Firmware V1.1
Postby marcelp1 » Tue May 07, 2013 7:43 am
Does the update delete all the data from the MOI on firmware upgrade?
marcelp1
Re: Firmware V1.1
Postby gfi » Wed May 08, 2013 6:02 am
marcelp1 Wrote:Does the update delete all the data from the MOI on firmware upgrade?
Yes.
gfi
Re: Firmware V1.1
Postby marcelp1 » Wed Jun 05, 2013 5:00 pm
I have just upgraded to v1.1
all settings have been lost (would it be advisable to back up settings in /.hts/ folder before upgrade?
http://192.168.1.188/moi-setting.html
getTimeandZone still does not work (SeaMonkey 2.17.1)
marcelp1
Return to Announcements
